2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning widest tire that will fit on my setup
      03-24-2020, 01:11 PM   #1
lixiang7349
lixiang7349's Avatar
284
Drives: customE50Tune
Guys, Help needed.
I got a set of 18 x 8.5" ET35 (square) rims fitted with 235/40/18 4s tires.
I was told only 225/40/18 would fit but I went with 235 ones and they fit so I wonder where the line is.
Would 245/40/18 fit? I have stock suspension.
Is there a calculation that can tell me for sure?
How can I tell the margin I have for my current setup?
Do I turn my wheels and watch somewhere to see current margin?
      03-24-2020, 05:14 PM   #2
230iZTR
230iZTR's Avatar
316
Drives: Signal Orange wrapped 230i THP
By measuring! I swear I spent half the winter on the ground in the garage with a bunch of rulers and squares, calculating and recalculating a super aggressive fitment on 17x9 with 255/40/17 tires. I'm cambered and rolled with a 1" drop so there was no tried and true fitment to copy.
Heres a website I found useful:
http://www.42draftdesigns.com/wheel-offset-101/
17x9 APEX Arc8-R, 255/40/17 RE71RS, Vorshlag Plates, Swift Spec-R Springs, m-Performance Bumpstops, Dinan ShockWare, Paragon 2-piece rotors, Carbon lip, custom 3" alumalite splitter, GTS wing, FTP Intake and Charge pipe, BootMod3 Stage 1 OTS
      03-24-2020, 05:56 PM   #3
lixiang7349
284
Thanks for the reply. I read another forum and the answer is clearly no.
      03-25-2020, 03:56 PM   #4
vandridine
66
Drives: 2017 M240 xDrive
https://support.apexraceparts.com/hc...-Fitment-Guide
      03-26-2020, 05:02 PM   #5
NISFAN
NISFAN's Avatar
3489
Drives: BMW M2
Probably will fit on the fronts with some fender rolling. I have 245's on 8J ET40, with M4 arms which push the wheel out a good 12-15mm at the top. It's tight, but works.
The rear will cause rubbing I think. I have some room to fit lower ET, but probably not the extra 11.4mm an 8.5J ET35 will bring.
      04-03-2020, 06:12 PM   #6
Hpirx
255
Drives: 2022 M240 xDrive, BGM
I have the same wheels and tire size for my summer set.
Potenza PP S04's. No drop, no additional camber, only the extremely rare rub on a particular high speed compression dip.
A little pokey, but I like the look.
Took them off my old E90, and they fit!
Maybe too much tire for most driving but mad grip at speed.
I was wondering what I was going to replace the Potenza's with, they're almost done.
Or do I get rid of them and go for the standard Apex 18" with 235's of some sort. (boring, but more mainstream look) I guess I know my answer.
Retired: '08 335xi E90. "Long may you run."
Retired: '19 M240xi "You also"
230iZTR315.50
2addicts
