ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > Regional Forums > USA - Southeast
  TireRack
      03-21-2020, 02:29 PM   #1
CrazyOneToo
1999 E46, 2002 E53, 2007 E85....all in progress
Drives: 2007 Z4 3.0Si Roadster
Need info for installing alarm on 2007 Z4 roadster
Hello all.....I am wanting to install an alarm on my 2007 Z4 3.0i roadster that did not come
with an alarm from factory. It does however have S5GAA - Preparation alarm system.
It does have the clown nose and the lights flash when locking and unlocking.
I am trying to find what part are needed. I have found several cars being salvaged but I'm not sure
which part numbers are interchangeable.
I know I will need a siren/tilt sensor and a hood open switch and brackets for both but I think
I also need a module of some sort!?!?!? Any thoughts on this???
Thanks
Alan
      03-22-2020, 10:53 AM   #2
Kanstulman
Kanstulman's Avatar
13
Drives: 2007 Z4 M Roadster
Attached are the Installation Instructions for the Alarm Retrofit Kit (with MSS) P/N 65 73 0 309 944
File Type: pdf Z4 Alarm with Sensor Installation Instructions.pdf (997.0 KB, 742 views)
      03-22-2020, 06:29 PM   #3
CrazyOneToo
Thanks. That should help!! But I've been looking for the black motion sensor connector for an hour now.
I assume when they say the connector for it is under the console they really mean way under it.
To bad I can't get the console out.
      03-23-2020, 01:11 PM   #4
Kanstulman
Kanstulman's Avatar
13
Attached is a photo of the wire that's in the center console for the MDD Sensor.
      03-23-2020, 01:55 PM   #5
CrazyOneToo
The only one I can find is a white connector that I'm pretty sure goes to the BMW assist. Does the connector you're showing have four or five wires in it ?
      03-23-2020, 03:25 PM   #6
Kanstulman
Kanstulman's Avatar
13
Looks like 4... I installed mine 4.5 years ago ... It's in there. You just have to reach around...
      05-02-2020, 06:53 PM   #7
CrazyOneToo
I found it finally. The previous owner had bent it into a loop down under the console and taped the plug to the wire itself.
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress.....
Search this Thread:
Advanced Search
zpost
