03-16-2020, 02:01 PM | #1 |
253
Rep 179
Speedometer is off? Four miles per hour higher then GPS/Phone
Does anyone else have this issue?
Taking my car to BMW Tomorrow for them to check it out. |
03-16-2020, 02:25 PM | #2 |
81
Rep 173
Drives: BMW M340i xDrive
What country are you based in?
03-16-2020, 02:26 PM | #3 |
Petrolhead
1943
Rep 3,521
Mine shows exactly 2 MPH higher (always) than my phone’s GPS as well as the roadside speed warning signs that show what speed you’re traveling at. Doing a bit of reading, I found out that that’s how BMW codes the speedometer. The correction can be turned off in older cars to show the exact speed. It should be doable in the G20s too.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
03-16-2020, 03:37 PM | #4 |
BMW Client Advisor
3458
Rep 2,504
Drives: 2020 M340i
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
03-16-2020, 04:03 PM | #6 |
Petrolhead
1943
Rep 3,521
Yup. It’s done on purpose.
Current:
03-16-2020, 04:08 PM | #7 | |
Grumpy Old Git
443
Rep 923
Drives: BMW G20 330i RWD M Sport
Or put another way (from a U.K. website) To ensure that they comply with the law and make sure that their speedometers are never showing less than true speed under any foreseeable circumstances, car manufacturers will normally deliberately calibrate their speedos to read ‘high’ by a certain amount. As your satnav is not the designated device by which a car’s speed is measured, it does not need to incorporate any fudge factoring.
Retired:
F10 520D M Sport E60 520D SE Volvo S60 type R |
Weiner0123416.50 |
03-16-2020, 04:09 PM | #8 | |
6659
Rep 15,858
Appropriate regulation.... 3. For all true speeds of between 25 mph and 70 mph (or the maximum design speed if lower), the difference between the indicated speed and the true speed shall not exceed— V / 10 + 6.25mph where V = the true speed of the vehicle in mph. |
03-16-2020, 06:44 PM | #10 |
345
Rep 751
You can code it to be accurate, I have done mine
03-17-2020, 06:26 AM | #11 |
X3M Comp is a beast
89
Rep 171
sometimes my M340I is accurate. However using Waze its sometime 4 to 6 mph off. Showing lower than the speedo. Makes me wonder if I am going slow. Could be why drivewise from Allstate does not catch all my over 80 incidents.
03-17-2020, 08:38 AM | #12 |
239
Rep 714
This is no different from my E90 and was also programmed to be about 75 MPH (by gps) while driving at 80 by indication.
03-26-2020, 04:43 AM | #14 |
6659
Rep 15,858
03-27-2020, 07:05 AM | #15 |
286
Rep 299
[QUOTE=JoCamp;25969488]What did you use to code it out?https://g20.bimmerpost.com/forums/sh....php?t=1697373
