03-16-2020, 11:17 AM | #1 |
16
Rep 66
How to reset the adaptive transmission
Anyone know how to reset the adaptive transmission? I’m getting a relatively rough downshift and was hoping the adaptive transmission reset improved this rough downshift. I’ve read through the forum about other bmws and holding down the gas pedal past the point of resistance for 30 secs but I’m not sure if that did anything
03-16-2020, 02:59 PM | #2 |
4446
Rep 7,488
You're correct...that doesn't do anything...other than indicate that there's a possible aggressive driver behind the wheel...so any thing engineered to accommodate an aggressive driver will be initiated until that behavior ceases or the engine is turned off.
That procedure is one of the biggest misinformed pieces of crap posted on BMW forums that seems to never die. If you do have adaptive transmission programing...turning on the ignition (or ready state in the new F & G series)...then you press & hold the accelerator pedal past the kick-down point...you are imitating an aggressive driver (flooring the pedal)...so the system/control modules will interpret that accordingly and initiate transmission shifting for that type of individual behavior.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
04-05-2020, 03:38 PM | #4 | |
Rep 6
04-06-2020, 05:56 AM | #5 |
1115
Rep 2,072
How do you activate diagnostic mode? Mine goes into that mode when I start up Bimmercode but I don't know how to do it manually.
04-06-2020, 07:04 AM | #6 |
1053
Rep 1,952
04-06-2020, 10:17 AM | #7 | |
1699
Rep 2,609
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
04-06-2020, 04:07 PM | #8 | |
1115
Rep 2,072
What is happening there? |
04-06-2020, 04:51 PM | #9 | ||
1699
Rep 2,609
That was NOT the case in the past, but appears to be the case now. I am on iOS Bimmercode 3.5. Considering that users probably often forgot to be in Diagnostic Mode, it is an important feature that Bimmercode was able to add. Cool. Apologies for misinformation, but that's the reality of software-updatable systems — they can change behaviour.
04-07-2020, 04:26 AM | #10 | |
1115
Rep 2,072
LexxM31698.50 |
