03-16-2020, 09:06 AM | #1 |
13
Rep 17
330e "battery control" mode?
Didn't know where else to post this, but I have a quick question about the battery control mode in the hybrid version of the 3 series (which I guess could equally apply to all plug-in hybrids) for anyone that knows or has tested it.
When battery control is engaged does the battery get charged at a constant rate while active, or does the charging speed vary depending on driving style (e.g. current speed, engine revs etc)? |
03-16-2020, 11:43 AM | #3 |
13
Rep 17
I understand that but I'm asking more about the speed of the charging itself when the system is actively charging the battery to your set level, e.g. how long would it take to recharge from (nearly) flat to 70% if you set the battery control to 100%, and would it take the same length of time regardless of how you drive?
03-17-2020, 09:33 AM | #5 |
3086
Rep 4,210
Here is one report but it doesn't say whether the battery charges at a single rate no matter the speed or conditions:
Finally, there's Battery Control, which allows you to specify a state of charge percentage that you want the battery to maintain—anywhere from 30 to 100 percent. In this mode, the 530e will run on internal combustion alone if the battery is below the specified level, and it will use the electric motor as a generator to charge the battery. This is useful if you're going to be cruising at freeway speeds; I found the 530e was able to fully recharge the battery in the time it took to drive from downtown Washington, DC, to Dulles airport and back again (a roughly 60 mile round-trip at 55-60mph). |
03-12-2021, 01:38 AM | #7 |
New to Hybrid
Rep 1
With a daily round trip journey of 22 miles, how should I set my 330e op so I don't have to use any petrol?
My driving style for the daily commute is fairly laid back so no heavy use of the accelerator |
03-12-2021, 03:41 AM | #8 | |
161
Rep 619
Hybrid mode will use petrol even if you are 'using' electric only since ICE would charge battery up to xx % that you set
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud Alpine White F10 M Sport - Gone to Stud |
03-12-2021, 08:45 AM | #9 | |
3086
Rep 4,210
Using the car as a generator is less efficient than using the ICE and plugging in later. I only use mine that way in the summer when the temperature goes over 100 F and I am going to a golf course and want to preserve electrons for remotely starting the AC so the car will be comfortable when I get back to it. |
03-13-2021, 06:20 AM | #10 |
Rep 4
It may be my imagination, but in Battery Control mode, the fuel consumption increases. So much so i think Sports mode uses less fuel.
(I’d like to be corrected by somebody with facts instead of feelings) |
03-13-2021, 06:27 AM | #11 |
161
Rep 619
AndrewC198910931.00 ovesund82.00 |
05-27-2021, 06:36 PM | #12 |
1509
Rep 5,089
Is G20 330e's battery control mode worse than, say, Prius Prime's?
Prius Prime's gas tank is slightly bigger than 330e(11.3 vs. 10.6 gallons), but Prius Prime can go 640 miles vs. G20 330e's 350-ish miles(both full charge + full tank). What does Prime do differently versus 330e? Prime is 600-ish lbs lighter than 330e, is that the primary reason of reduced 330e range? |
05-27-2021, 07:11 PM | #13 | |
3086
Rep 4,210
bavarianride1509.00 |
05-27-2021, 07:30 PM | #14 | |
1746
Rep 1,352
The 330e has significantly more power, sound deadening, creature comforts, stiffer chassis, etc. Prius Prime was designed with efficiency as the top priority. The 330e was designed to be a luxury car first, with efficiency being a secondary objective. |
05-27-2021, 08:03 PM | #15 | |
1509
Rep 5,089
Comparing Prius Prime, 330e, and 330i, it looks like 330i is a reasonable choice for a blend of comfort and competence(at the expense of gas-only). |
05-27-2021, 08:08 PM | #16 | |
1509
Rep 5,089
I haven't seen any tech talk about Prime's electric motor@91HP(not too small), but its 0-60 in 11 seconds is not in the same class as 330e. |
05-27-2021, 08:17 PM | #17 | |
1746
Rep 1,352
The 330i, on the other hand, is already a very efficient gas car, has plenty of power, and tons of range. The 330e only makes sense in a very specific set of circumstances. The 330i is a much more well rounded vehicle. |
05-28-2021, 01:21 AM | #18 |
82
Rep 170
Well, I think the 330e makes sense in many ways unless all your driving is made on longer distances. At least where I live.
You pay a lot less in tax, fuel consumption is great even with the occasional longer trip thrown into the mix and it feels a little like a classic inline 6 to drive since the electric assistance masks turbo lag and gives a lot of torque already from the start. If you are able to charge at home then the economy is great, and no, it's not like a 320 when battery is depleted. You have a lot more torque and you should be able to cram out the 252hp even then, just no extraboost with 292hp. I can at least not feel any difference even at the end of a long trip compared to the beginning. Then again, I don't live near an Autobahn so the battery will have a chance to recover somewhat during normal driving. The only problem, and this is not an unsignificant issue, is the very limited trunk space. I really don't regret getting a 330e but a touring (G21) is of course much more practical. |
05-28-2021, 10:20 AM | #19 |
1509
Rep 5,089
A G21 touring with same engine + battery but extra 200lb(?) will further hurt efficiency(battery range/mpg) and 50/50, right?
05-30-2021, 11:57 PM | #20 |
82
Rep 170
Well, sure, but it is still a much more usable car. And the extra weight is not that noticeable in the energy consumption.
It's still a lot better than anything that starts with an X in that regard |
07-26-2021, 09:33 AM | #21 |
Rep 34
In my experience, charging from zero to 100% takes about 50 minutes during highway driving. This is MUCH faster than using a charger. The engine is working harder too, and fuel consumption increases significantly. I tried doing the math once, and ended up with approx. 5 USD worth of petrol for a full charge. Especially during winter I like arriving with a full battery so that I can pre-heat the cabin before using the car, and this battery control feature is very handy.
