CIC iDrive Continually Restarting After Map Update
03-15-2020, 04:08 AM | #1 |
Rep 27
Just wondering if anyone might be able to help. I'd previously successfully updated to the 2018 Maps and have just tried to do the update to the 2020 Maps.
The update completed (although I did see it jump from around 70% to 100%) and restart like normal. But since that restart my iDrive now continually reboots every 30-45 seconds. Does anyone have any ideas or have something similar? I did the update whilst driving this time which is the only difference from when I completed the update but I didn't think this would cause an issue. Thanks |
03-15-2020, 01:12 PM | #2 |
242
Rep 1,354
Remove the hard drive and see if the CIC keeps rebooting after you start it.
If it stops doing, so you know what the issue is. Note many functions will not operate with the hard drive removed including navigation. |
04-15-2020, 06:23 AM | #3 |
Rep 27
The car would not co-operate very much which I think was partly down to the constant rebooting but in INPA I did notice that it was listing the following items that I thought were odd:
- Audio System Controller CCC - Computer / CCC (Application) - Gateway / MOST/CAN CCC - Navigation System / Japan I imagine the top 3 listed items should all say CIC given that my car is a CIC car and that navigation system should list Australia since my car was Australian delivered and the maps loaded were for Australia 2020. Would these be the cause and is it possible to re-code/correct these items? |
05-04-2020, 07:39 PM | #4 | |
Rep 27
05-12-2020, 08:19 AM | #6 | |
Rep 27
Is there a way to get the standard software? |
05-13-2020, 11:03 PM | #7 |
242
Rep 1,354
The best thing for you to do is to clone the drive.
Look for the thread about replacing the HDD with an SSD as that has all of the instructions. Typically the drive is starting to fail when you get to this point but can of then still be read outside of the CIC. It will be important for you to make sure the drive has ample power and is kept relatively cool as you clone it. That gives your computer the best change of reading all or almost all of the sectors. You should then install the new drive and perform a map update. |
05-14-2020, 10:47 AM | #8 |
866
Rep 5,450
I would try to clone your existing drive first, I have an image from mine I can share, but is for a US car, would need fully coded to your car as it would be just like buying a used one and coding it in and would need local maps uploaded to it, but if you need it pm me and I can share.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
05-17-2020, 03:46 AM | #9 |
Rep 27
So even though the drive appears to be fine, it may be failing? I would have thought a diagnostic scan would show bad sectors, etc if that was the case.
I'll need to track down a replacement drive so that I can do that then. The drive appeared to spin up fine but for now has been left out of the car to prevent further damage |
05-17-2020, 06:22 AM | #10 | |
242
Rep 1,354
At some point the CIC is hitting bad sectors which halt all IO to the drive as the drive's own mechanism keeps retrying to read those bad areas. The CIC keeps buffering reads or writes until an overflow error condition exists and the OS crashes causing a reboot. Diagnostics do not show these errors. Sometimes you'll get a good read of those failing sectors when the drive is cool and has not been in operation. A best case for you is that you get a 100% clone of the drive onto a new one. Next down, you'll get a somewhat extensive clone of the drive but you'll get errant sector reads. Since the navigation area on the drive is one of the largest, reloading the maps onto your new cloned drive can cure data errors that may arise. What you are hoping for is that the partition that has your FSC codes can be read to the point that all the permission data moves over to the new drive. If you can get the FSC containing partition, then at worst you can grab a drive image from someone else, write that out to your new drive, then restore the FSC partition over that same drive. Worst case is that you can recover little to no data and that can be problematic. I cloned my drive, kept the original have have the image on hand just in case the SSD I am running ever fails. |
05-18-2020, 05:33 AM | #11 | |
Rep 27
Is it possible to partition out the drive? I have a friend with another LCI E92 with a working iDrive so in theory could try recovering his navigation partition onto my drive and seeing if that rectifies the issue. |
05-18-2020, 06:10 AM | #12 |
Rep 27
I have also just purchased the following taking reference from Jagaer's thread and what I can manage to get in Australia at the moment:
- Ableconn IIDE-MSAT mSATA SSD to 2.5-Inch IDE Adapter Converter - Samsung 128GB SSD mSATA SM841 |
05-19-2020, 04:03 AM | #13 |
242
Rep 1,354
I not sure what you mean by the partition comment.
You can clone your own drive onto a new drive. At worst you may need to tell the cloning software to skip bad sectors. That can corrupt the data in one or more partitions but you may end up with a properly partitioned drive. If during that process you get all of your FSC code data, you don't really care if the navigation partition has bad data. At that point you would insert a USB drive with a map update and let the CIC fix the corrupt navigation data when it overwrites it. Grabbing a copy of a friend's navigation partition should only be tried if the above does not work but you may still have to update the maps... assuming your FSC partition is ok. If at worst your FSC partition is corrupt and unreadable then you'll need a copy of someone else's drive of the same vintage hardware and software. You will then have to deal with obtaining FSC codes. |
06-24-2020, 10:32 PM | #15 |
242
Rep 1,354
Ugh, so it may be that the donor drive's data is corrupt and causing the reboots, or there is a bigger issue with the CIC drive interface.
To help rule out the latter, reformat the SSD and make sure you write zeros to it to blank it out, then install it back into the car. The car should act as it did when you pulled the drive and started the car with no drive installed. If it does the CIC is ok and there are no electrical issues. You will not have NAV, etc. as before but the CIC should work otherwise. |
08-13-2020, 06:05 AM | #16 | |
Rep 27
The data I had used was from the original drive not a donor vehicle, been a bit difficult to get hold of the other car for long enough to do everything. So it seems likely that it is the drive that is at fault, is the data available anywhere? |
08-13-2020, 12:31 PM | #17 |
2440
Rep 4,330
since you have all the things to access the drive, I would put your image back on the ssd, then use the QNX virtual machine to run the QNX file system tool.
http://www.qnx.com/developers/docs/6...2Fchkfsys.html It may repair the damged file system data, if that's the problem. I could certainly drop you my CIC image, but that will definitely require some soft of hackery to make work. at best just FSC codes. At worst? Who knows. Maybe just using my images partition table and then copying over the relevant files for your CIC. I've not really looked into the file system passed what it took to expand the partitions to my SSD replacement. edit: I'm assuming you created a disk image when you cloned it, and still have that image. If you did a direct disk to disk clone, make an image. The less you mess with a failing drive the better. |
08-13-2020, 03:41 PM | #18 | ||
242
Rep 1,354
There is a CIC drive image there. |
08-22-2020, 02:05 AM | #19 | |
Rep 27
I haven't removed the image from it yet. I will try running the QNX file system tool and see how that goes. Thanks |
08-22-2020, 02:24 AM | #20 |
Rep 27
11-14-2020, 10:04 PM | #21 |
Rep 27
I just thought I would update the thread as I have now resolved this.
I made an image of my friend's working CIC that shared the same last working map data I had. Putting this onto a new drive worked and there was no need to re-enter the FSC code either. Thanks to all for their help |
