Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Bimmercode - BDCU With Veepeak adaptor?
      03-13-2020, 02:18 PM   #1
SigurWes
Drives: 2019 330i
Getting a message that says I can't access this module with this adaptor. That's weird. Anyone know anything about it? Can I get around it?
      03-13-2020, 02:37 PM   #2
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
You’ll need a unicarscan, obdlink or enet adapter I believe. Some modules can’t be coded with other adapters because they don’t have enough memory or something like that.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      03-15-2020, 10:03 AM   #3
SigurWes
Drives: 2019 330i
Can anyone confirm? I've already wasted like 40$ on this adaptor because it was the top recommended by bimmercode.
      03-15-2020, 10:24 AM   #4
Pasty187
Drives: 2020 BMW 330i; 2016 M235i
If you have the app and you look at the purchase adapters under settings you will see which adapters work for which model. If you have g20 you will not be able to access all areas with veepeak. Return and get e sys cable and lightening adapter. Same price and can be used with bimmercode and e-sys
ewanmac188.50
      03-17-2020, 01:46 PM   #5
Beam330
Beam330's Avatar
29
Drives: 2019 BMW 330i xDrive M Sport
Did you use an ENET cable + lightning adapter to code?
      03-18-2020, 10:15 AM   #6
Fpgiuliano
Fpgiuliano's Avatar
Italy
43
Drives: Bmw 320d Touring xDrive Msport
Hi,
I had the same problem (but with uniscan) and I solve - thanks to BimmerCode support - so:
- engine running
- click 3 times start button to enter in the diagnostic mode
- now try to connect with bimmer app
Ps make sure that u disconnect Bluetooth phone from car (https://bimmercode.app/quick-start-guide/)
On the site vepeek is no more compatible
Bye
Francesco
      03-18-2020, 06:48 PM   #7
Pasty187
You will not be able to access everything in Bimmercode without the approved adapters. I too reached out to Stephan who is the developer and until I got the Ethernet and lightning adapter I was not a able to program sport + and a few other items with my veepeak. Again this is just tied to G20s
g20
