Accessing Shark Fin Antennas
04-08-2006, 03:05 PM | #1 |
13
Rep 142
Does anyone know a way to install an additional antenna (for wifi for a carputer) inside the shark fin antenna housing? I guess this would require a) removing and reinstalling the actual antenna and b) finding a way to feed wires into it from the interior. ANybody know?
SmellyGas |
04-08-2006, 04:53 PM | #2 |
1312
Rep 10,185
The inside of the fin is completely filed with a sealed unit containing the tiny recievers for the OEM system.
I doubt there is space for anything else
BMW if you are reading, I need a job, Please. |
04-08-2006, 05:04 PM | #3 |
Vroom Vrrooooom
300
Rep 3,146
Drives: 330i
Fleet, what receivers are in the fin?
-Dmitriy
06' BMW 330i & 03' Suzuki GSX-R600 SG | Beige Dakota | Poplar || iDrive w/MP3 | PP | SP | CWP | PDC | Comfort | Shades || 40% Tint | Black Line Tail Lights | Hardwired V1 |
04-08-2006, 05:10 PM | #4 | |
1312
Rep 10,185
Depends on your options, but can include 1) GPS antenna 2) Telephone Antenna 3) Sirius Radio Antenna ( USA Only ) 4) I believe the new Digital radio reciever is also housed inside Interestingly they say the ones with Sirius antenas are slightly bigger than the ones without
04-08-2006, 05:26 PM | #5 |
Vroom Vrrooooom
300
Rep 3,146
Drives: 330i
Thanks...
-Dmitriy
04-21-2006, 08:23 PM | #7 |
Moderator
318
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
Is that correct, E90Fleet, Sirius equipped cars have bigger shark fins?
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
04-21-2006, 11:58 PM | #8 |
86
Rep 1,166
can i add the fin ? drill a hole on the roof?
325i Arctics M-Sport, Gray Leather with Alu Trim, ///M DCT Paddleshift, ///M Gear Knob, BBS LM-R 19", Michelin PS2, KW V2, H&R Anti Roll Bars, BMW Performance Air Intake System, 3D Front Lip, ACS Roof Spoiler, OEM Boot Spoiler, Osram 6000K, Brex White Ring, PIAA 6200K HID Fog, PIAA License Plate LED, BMS Powerbox
04-22-2006, 06:26 AM | #9 | |
BlackBerry King
41
Rep 184
Drives: 2009 BMW 335i
90% off the cars are prewired for all 4 and it doesnt matter what country you are in. I have a 325I, in canada, and am prewired for all 4. The wires lead to the trunk where the nav unit and sirius unit would normally be mounted. Where the spare tire well is in normal vehicles. The plugs for these are generic and would plug into a wifi antenna/gps antenna and most likely work I had an aftermarket gps unit and XM radio running off these a while ago. as long as your car is sirius prewired or nav prewired you will have these. find them in your car configuration.
2009 BMW 335i /6 SPD Fully Loaded Saphire Black on Black Dakota Leather |
04-22-2006, 12:46 PM | #10 | |
586
Rep 2,106
They seem to offer different internals based on the config. http://www.realoem.com/bmw/showparts...40&hg=65&fg=30 |
04-24-2006, 05:33 AM | #11 | |
13
Rep 184
That would interest me a lot if true - though there seems to be some arguement here as to whether all have or not. I'm particuarly interested in the GPS antenna - as I have a pda satnav system - connected to a bluetooth gps unit in the back - and that is hooked up to an external antenna which I sit next to the window - if I could plug my Globalsat GPS unit into the cars external antenna - I'd be very happy! BUT - I don't have Sirrus or SatNav option - only phone bluetooth connectivity option - so reckon I'm out of luck? Any advice or exactly where and what to look for in the boot area?? Thanks. |
04-28-2006, 01:05 PM | #12 | |
Vroom Vrrooooom
300
Rep 3,146
Drives: 330i
Revoce the trunk covering piece by lifting and puliing it backwards out of the car. Look for a set of wires with about 6 inches of velcro wrapping on them. Unwrap the velcro and examine.
-Dmitriy
07-03-2006, 10:33 AM | #14 |
26
Rep 197
Hi What type of connector is required to tap into the GPS antenna connection in the boot/trunk?
Any suggestions as to where to purchase one? Thanks
E91 335i M Sport
01-15-2007, 06:59 PM | #15 |
Rep 180
Sorry to being an old thread back...
Was anyone able to use the GPS connector in the back as an external antenna for a GPS receiver, e.g. Holux 236 Guess, Do you have pictures of your setup? |
01-22-2007, 01:11 PM | #18 |
Rep 42
None of them. C is the Bluetooth antenna, A and B are telephone antenna and telephone backup antenna.
The GPS antenna should be "under" the blue box, right of the backup antenna plug. In cars with nav the cable is not there.
03-17-2007, 04:34 AM | #19 |
Rep 29
Hi,
Does anyone know which wire/s is the following connections, from the wires lead to the trunk where the nav unit and sirius unit would normally be mounted (Where the spare tire well is in normal vehicles). 1) 12Volts (constant 12V) => wire color? 2) 12 volts (only with ignition on) => wire color? 3) Ground => wire color? 4) Reverse gear engage (if available) => wire color? Cheers |
08-06-2008, 05:48 PM | #21 |
16
Rep 463
08-06-2008, 05:58 PM | #22 |
26
Rep 1,826
Drives: E92 335i
yikes
