Bimmerpost
4 Series
Technical Topics Cosmetic and Lighting Modifications (exterior & interior) Rhino ramps and front lip
      03-09-2020, 09:40 PM   #1
possible335i2008
166
Drives: 335i
Anyone with a front lip able to use rhino ramps? Just checking before I buy a lip, I do oil changes in between recommended intervals and was wondering if this is an issue?
      09-21-2020, 10:35 AM   #2
UnluckySaxon
62
Drives: BMW 330e G20
I have the same question.
What happened here? Did you get em or what?
Any good and all that
      09-21-2020, 11:00 AM   #3
possible335i2008
166
Drives: 335i
You will need extenders or race ramps, rhino ramps won't work
      09-21-2020, 03:01 PM   #4
UnluckySaxon
62
Mine is just a standard m sport pro g20, is yours more modified than a lip at the front?
      09-21-2020, 05:58 PM   #5
danahmedG20
danahmedG20's Avatar
28
Drives: 2020 BMW M340i xDrive
I used regular ramps and when backing out, the lip flexed upwards and luckily it was plastic so nothing major happened but I can imagine if it was a CF lip it would've been a goner...
Safe to say I returned the ramps the next day as there wasn't enough clearance with the lip installed
      09-21-2020, 07:10 PM   #6
SoFlo M340i
126
I use standard rhino ramp style ramps with a lip and have had no issues. I make sure to go slow both up and down. But I'm not lowered. If I was, it would be a no go.
'20 Portimao Blue M340i – Current
'17 Dark Graphite 530i – Retired
'14 Alpine White 328i – Retired
      09-21-2020, 07:29 PM   #7
possible335i2008
166
Drives: 335i
I tried the same with my lip and it was rubbing way before I was a quarter up and I'm stock height
      09-21-2020, 07:37 PM   #8
SoFlo M340i
126
That's odd. I've checked it at 1/2 way and 3/4 the way up and been okay. Close. But okay. But all ramps are made a bit different so maybe I have one with a less steep angle.
      09-21-2020, 10:02 PM   #9
possible335i2008
166
Drives: 335i
Which model do you have mine are kinda old?
      09-22-2020, 06:16 AM   #10
Cabby
340
Drives: 2019 X740i
2020 BMW M340xi  [0.00]
2019 BMW X7  [0.00]
I used Race Ramps - Yes, you need the extender ramps or you will scrape the front getting off post lip install - these are very expensive but worth every penny if you dont have lift available:
https://www.raceramps.com/garage-ser...ace/p/RR-56-2/
https://www.raceramps.com/garage-ser...rs/p/xtenders/
https://g20.bimmerpost.com/forums/sh...3#post26711153
      09-22-2020, 08:17 AM   #11
SoFlo M340i
126
Mine are SUPER old. I bought around 2010 for $40 from an auto parts store. I can send you a pic if you want, but they are regular old ramps and ive been up and down them with my lip a few times, no issue.
      09-22-2020, 09:39 AM   #12
UnluckySaxon
62
Whats the lip clearance, though?
on my g20 its like 7 inch which apparently leaves an approach angle of 11.2 degrees max. I like the race ramps, but theyre super expensive and not sure if I can get the ones I need here in UK
      10-26-2020, 07:13 AM   #13
cnichols138
X3M Comp is a beast
89
Drives: 2022 BMW X3M Comp
My ramps wont work with my lip. So I just jack up the car and put the ramps backwards under each wheel. Its up a little extra work but no chance destroying the lip. Which I have never scraped.
      10-29-2020, 05:48 PM   #14
Voodoo_G80
97
Drives: G
Rhino ramp will not work with a front lip. The lip touches the ramp before the wheels even touch it. Wasted my time and money on it. You would need something more lowered car friendly.
g20
