03-08-2020, 10:36 PM | #1 |
18
Rep 36
330i exhaust flap mod
Hi all,
I have seen this thread in the m340i section, just wondering if anyone has done this for their 330i? Cheers Last edited by shanknik; 03-08-2020 at 10:51 PM.. |
03-08-2020, 10:51 PM | #2 |
Petrolhead
1942
Rep 3,521
I think a few people have done it. I haven't done it yet because I don't know how to remove the connector. I wonder if there's a lock preventing me from doing it. I can't find any proper pics of the connector to see where the lock is.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
03-09-2020, 12:15 AM | #4 |
557
Rep 328
It is actually very simple. One of the first "mods" I did when I got my car. All you have to do is go down to the lower right tip of the exhaust. Look at the black wire that's connecting to the exhaust. Turn the car on and make sure it's in sport. Pull on the black wire and click on the tab on the black connector connecting the wire to the exhaust. Turn the car off and turn it back on. And there it should be ready! A lot of louder cold starts.
03-09-2020, 08:38 AM | #5 |
Petrolhead
1942
Rep 3,521
Is the button like thing on the top or the side of the connector?
Current:
03-09-2020, 06:06 PM | #7 |
Petrolhead
1942
Rep 3,521
Thank you very much! Can't wait to do it tomorrow
Current:
03-17-2020, 08:50 PM | #9 |
28
Rep 67
Can someone explain how the valve works?
I can audibly hear the valve pop open and close switching between sport/comfort while in park, but as soon as I put it in drive, I can clearly hear the valve close. Does it only open when necessary, such as full throttle? The car is warmed up and idles below 1k. Does locking the valve open by disconnecting the connection make it louder at lower RPMs? Any videos before/after? |
03-17-2020, 09:05 PM | #10 | |
557
Rep 328
Phippsy8178.50 |
03-17-2020, 09:31 PM | #12 |
28
Rep 67
03-18-2020, 06:38 AM | #14 |
79
Rep 138
I did this the other day... warmed up the car a little (the valve won't open immediately from a cold start) leave the car running then change to sport in idle, disconnect the plug. That's it.
Now you can turn the car off and you can physically see the valve still open on the RH exhaust. (330i) I then covered the plug & port with a finger end of a black latex glove and insulation tape. Zip tied the plug/lead to the side of the port on exhaust hanger. Very simple to do. It's louder on both cold start and when running in Comfort, but without so much of the burbles of Sport/Sport + (I expect that's down to throttle/Fuelling mapped for this mode) I'll try and get a photo and video later if possible and post back.
J
330i M Sport Plus Previous- 435D M Sport |
03-19-2020, 06:16 AM | #16 |
79
Rep 138
Agreed. It works for now, but I don't see it as being a great long term solution!
J
03-19-2020, 10:05 AM | #18 |
11
Rep 16
I have made a little 3d adaptor to avoid connection but maintaining it clean
https://g20.bimmerpost.com/forums/at...1&d=1584630217 it's not a perfect part, but it works |
03-20-2020, 01:29 PM | #19 | |
Rep 15
I´ve done the "mod" to my car and it´s noticeably louder in low RPMs (sounds the same in higher RPMs, because the valve would open anyways) and with the sound system Muted you might hear the exhaust drone a bit. Nothing that will bother you tho, as it didn´t bother me. Will try to upload some videos of it, but in the 330i it´s very hard to notice a difference on camera. Unplug it and have fun!
@g20_black on Instagram
Previous cars: 2016 BMW F20 120i (N20) |
VipinLJ1941.50 |
03-21-2020, 03:47 PM | #20 |
83
Rep 201
I can't seem to get mine to open at all, I've been for a hoon in Sport (xtraboost) and pulled up to unplug the connector to see the valve was closed.
Tried leaving the engine on for 5 or so mins in sport with no luck either? |
Phippsy8178.50 |
03-21-2020, 04:12 PM | #21 |
79
Rep 138
Odd?? When you switch from 'comfort' to 'sport/ Sport +' you should hear an audible creak (for want of a better word) as the flap opens?
J
03-22-2020, 03:44 AM | #22 | |
83
Rep 201
As soon as I open the door the gear lever automatically resets back to the right. Will check the connection to see if the plug is mated fully Last edited by -Nick; 03-22-2020 at 05:57 AM.. |
