Bimmerpost
4 Series
Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications How does JB4 work?
      03-08-2020, 03:01 PM   #1
M40iSFR
Drives: Z4 M40i
How does JB4 work?
Does anyone have the technical facts, not vague descriptions, of how JB4 works?
      03-08-2020, 03:02 PM   #2
possible335i2008
166
Drives: 335i
Check out n54tech.com; the developer and his team moderate that website they can answer all your questions there
      03-08-2020, 08:43 PM   #3
chenry
2355
Drives: BMWs
+1
      03-09-2020, 11:14 AM   #4
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
24029
Drives: 07-335/12-328/18-M4/21-M4CP
It tricks the ECU to make changes to some parameters (boost, AFR, timing,etc...)
It also connects to Canbus which gives it the ability to add features like boost by gear, boost by RPM, safety failsafe,etc...
https://x-ph.com/sale/
Phone number 702-494-9435
      03-09-2020, 11:26 AM   #5
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
Can the jb4 work without the obd connection? I read somewhere were they say it can and the obd connection is only for the gauge control thing. Like switching using the built in stalks and speedometer gauge
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      03-09-2020, 02:26 PM   #6
M40iSFR
Drives: Z4 M40i
Yes, I was looking for the figures, or there abouts, of what is changed for each map.
      03-09-2020, 02:41 PM   #7
mike@x-ph.com
24029
Map0: Stock tuning, fully disable JB4
Map1: Additive map with peak of 3psi over stock added (91 octane)
Map2: Additive map with peak of 4psi over stock added (91-93 octane)
Map3: Additive map with peak of 6psi over stock added (93+ octane)
Map4: Additive map with peak of 6.5psi over stock added (93+ octane)
Map5: Additive map with peak of 6psi over stock added & more aggressive timing profile for higher octane fuel (experimental, 93+ octane, bolt on modifications)
Map6: Custom tuning map allowing both additive (below 10psi) and absolute (above 10psi) targeting
Map7: WMI map (boost varies based on WMI additive and map settings)
Map8: VALET / Low Boost Map
      03-09-2020, 03:27 PM   #8
M40iSFR
Drives: Z4 M40i
Hi Mike
Thanks for the continued replies. I've seen those figures, but, maybe I'm reading them wrong here, is the 3psi for Map1 just in increase in turbo pressure - no change to timing or anything else?
The reason I ask is, I had my old car remapped - reprogrammed ECU. The gearbox spat a tooth shortly after.
I'd like to get a better understanding of what is actually changed before I risk the same decision again. I know the B58 in my G29 Z4 M40i can do a lot better though!
      03-11-2020, 10:55 AM   #9
mike@x-ph.com
24029
Hi Mike
You might want to ask Burger Tuning directly for a better answer but from my understanding yes you are correct. Map 1 will pretty much add 3 psi of boost to stock
      03-11-2020, 11:27 AM   #10
possible335i2008
166
Drives: 335i
Hi Mike
Why don't you got to n54tech and ask the guy who makes it? I mean that's the real source of info, unless you trying to not get the best source of info?
      07-17-2020, 11:16 AM   #11
carbon428i
carbon428i's Avatar
68
Drives: 2014 BMW 428i M Sport
Does anybody know what's needed for Map 4? Is it ok to run on a stock 2019 m340i? Looking for max power without upgrading anything.. thanks
2014 Black Sapphire Metallic F32 428i xDrive M Sport | Gloss Black Striped Dual Slat Kidney Grills | CF M4 Style Mirror Caps | CF M4 Style Trunk Spoiler | CF Rear Diffuser | Rohana RFX5 Gloss Gold 20" | CF Wrapped Interior | BM3 Stage 2 93 Agg Tune | VRSF Catless Downpipe | Evolution Racewerks Chargepipe | Pheonix Racing Intercooler | K&N Drop In Filter|
      07-17-2020, 01:03 PM   #12
Fuel-It!
550
Drives: M4, M5, M2C, X4M, 440i, etc...
The JB4 includes full diagnostics in the app so record ad JB4 log and post it here and I can tell you if it looks safe or not. The map used has mostly to do with the octane being used and what the factory software is.
      07-17-2020, 02:35 PM   #13
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Will you be kind enough to do that for a measly 330i as well? I’m running map 2 now with ~E30 mix. I wanna know if map 3 is better because sometimes, I feel map 3 is better and at other times, map 2 seems to pull harder. No other mods other than a JB4.
Current:
      07-17-2020, 03:54 PM   #14
Fuel-It!
550
Sure post it up
      07-17-2020, 06:41 PM   #15
M340_pilot
88
Drives: 2020 M340i
Can I manipulate the oil and coolant temperatures and/or disable the cold start procedure with the JB4?
Sold: 2020 M340i, BM3, VRSF catted dp, MPE, Dinan springs
nola2atx124.00
      07-17-2020, 07:01 PM   #16
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Sure post it up
I just realised you can't post .csv here
Current:
      07-18-2020, 07:00 AM   #17
lucasmiller2015
76
Drives: 2020 M340i
2011 BMW 335i  [0.00]
Sure post it up
Get an account on datazap.me, upload the csv there (make sure it's set to public), and post the link here
2020 M340i | Mineral Grey Metallic | Premium | Exec | Adaptive M Suspension | Harmon/Kardon
Previous: 2011 E90 335i | Black Sapphire Metallic | 2007 E90 335i | Monaco Blue Metallic
      07-18-2020, 12:29 PM   #18
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Yes sir. Will do
Edit - https://datazap.me/u
Let me know if that works
Edit 2 - https://datazap.me/u/vipinlj/logging-run?log=0&data=1-4
https://datazap.me/u/vipinlj/logging...log=0&data=1-4
Current:
      07-18-2020, 05:37 PM   #19
Fuel-It!
550
Do a log on map4 also, which is an absolute target map around 20psi target, close to what you're hitting on map2 here.
      07-18-2020, 06:49 PM   #20
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Yes sir. Will do. I’ll post that up as soon as I get logs
Current:
      07-18-2020, 07:47 PM   #21
Shmoked
Drives: 2020 M340
Any1 running the jb4 currently? is it worth it? Just picked up my car last week trying to decide what route to take
      07-18-2020, 09:48 PM   #22
Fuel-It!
550
It's been out since 2008 lol. If you want a lot of power and features without having to void warranty with a flash the JB4 is the best way to get there. If you want exhaust pops and bangs you're going to have to bite the bullet and reflash it.
Search this Thread:
Advanced Search
g20
