TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Salvage 3 stage Intake manifold
      03-07-2020, 02:03 PM   #1
Skoidat69
Secret Squirrel
Skoidat69's Avatar
280
Drives: 2007 BMW 328ix E91
2007 BMW 328XI  [0.00]
I pulled my $100 3SIM and I know that the big Disa flap is busted. The donor vehicle is a '06 330i with 193k.. I would like input as to either build with aluminum flaps, buy Chinese Disa for same price as rebuild kit Or pony up $$ and get real deal Disas
No good sea story starts with Cookies and Milk
      03-10-2020, 11:19 AM   #2
SonicBlueStage2
Drives: 2011 BMW 328i xDrive
I'll weigh in... I tried to rebuild both disa valves and ended up buying OEM in the end. I started trying to use epoxy to reseal, but after a drive around the block, the oil inside the disa valve (necessary to the proper function of the motor) crept into the seam and the back of the valve fell off. Attempt 2, I ordered formic acid and tried again with a second set of salvage valves and the rebuild kit. I cleaned meticulously, used clamps, waited overnight, etc. They still wouldn't stay closed for more than a couple days of aggressive driving.
My two cents is just suck it up and buy the OEM units from FCP euro. Return them for free replacements after 50k miles. The peace of mind that these valves are permanently welded shut is worth it to me after these two failed attempts.
      03-10-2020, 11:22 AM   #3
Skoidat69
Secret Squirrel
Skoidat69's Avatar
280
They are both Fk'd..
      03-11-2020, 09:41 AM   #4
b1aze
Just one more taste...
b1aze's Avatar
566
Drives: 2013 128i 6MT MSport
All of the chinese versions I’ve seen or used have been garbage. If you care about it working well, the only option is OEM
      03-11-2020, 01:51 PM   #5
yupetc
390
Drives: 2015 X535i
Rebuild it in aluminum flaps is the way to go. This is the only viable option where flaps won't fall off its cage. Even the new OEM units will eventually fail and start dropping pieces further into the manifold.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP
2017 540i - MHD2+, VRSF DP, TU Pump
      03-11-2020, 02:09 PM   #6
Blueeyesredpanda
Blueeyesredpanda's Avatar
401
Drives: E90 / F30
I have a set aluminum flaps rebuild kit for the large and small disa. Lmk if you are interested
      03-22-2020, 04:30 PM   #7
E92William
1998
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
Man you should have shopped around I got a manifold for 25 bucks from the junkyard for a 530xi with two rock solid disas. I think I would give a try to some amazon disas or whatever worst case they got warranty. rebuild seems like a pain with these and with 193k those already served their purpose internally and externally with the flap part
      03-22-2020, 05:06 PM   #8
nsjames
2440
Drives: 08 328xi Touring
multiple reports of amazon disas opening when commanded to close and vise versa.
      03-23-2020, 03:05 PM   #9
E92William
1998
Oof. I did notice that some of the disas sold there and on ebay look like they're in the wrong position when not powered in the picture. Idk if this is just randomly the position they are shut off at. I know mines are open when off both of them and they're mahle looking OEM
      03-24-2020, 11:22 AM   #10
Soravia
114
Drives: 2011 E91 Silver xDrive 6MT
Are there different versions of OEM that works better?
Like on newer model 3.0iS cars like Z4 X3 etc? Vs 330i?
      03-24-2020, 05:45 PM   #11
Blueeyesredpanda
401
Drives: E90 / F30
You ship them yet?
Yes!
3IM . Okada Plasma Direct . Euro Ram Intake . AA header (Pending) . PE . 2nd Cat Delete . F30 340mm 6 pot . EBC Yellow Stuff . StopTech SS Brake Line . BMW Performance CF Strut Bar. 219M . PSS
      03-25-2020, 10:51 AM   #12
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
2214
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
Just buy new official DISA valves from FCP Euro. It really isn't worth the hassle considering you could rebuild the flap and the electronics could be dying.
Source: I've bought and rebuilt plenty of these
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded
Instagram @Andreys_128i and @Honda.Bito
