03-06-2020, 06:31 PM | #1 |
47
Rep 163
Maximize Power on 93 Pump Gas Only
I am wondering if anyone knows what the most power people make on 93 pump only. I have read that the VTT GC gives ~520 and the Pure800 does ~585 (are these numbers accurate?). Reason I am looking at this is because I don't have access to E85 and I don't want to do anything with meth. What would you guys recommend for a setup? Currently I am running MHD stage 2 93 oct tune with a catless downpipe. Currently looking at doing dorch stage 1 pump with either VTT GC or Pure800. Anyone have recommendations or know of any setups that I might not know of/overlooking?
03-07-2020, 11:04 AM | #4 |
1161
Rep 3,189
I think 500-520whp is realistic/safe on either GC or Pure800 on 93. The higher Pure results were more from 95oct I think. Could probably get higher if you want to be on the edge of timing/glory run.
Chris@VargasTurboTech1933.00 |
03-07-2020, 11:36 AM | #5 |
47
Rep 163
I want something that's safe for DD and only runs on 93 pump. So maybe the VTT GC with Dorch Stage 1 is the way to go if no advantage from Pure?
03-07-2020, 11:50 AM | #6 |
BimmerPost Supporting Vendor
24289
Rep 190,975
We offer custom maps by Jordan Tuning; I suggest contacting him. He will let you know how much power you can get with the current setup
03-07-2020, 07:29 PM | #7 |
1161
Rep 3,189
03-09-2020, 08:26 AM | #8 |
Cheapskate
4450
Rep 4,995
You can always make more power with a bigger turbo, so this question is open ended. Pure800/Vargas GC are just hybrids. Big Boost is an actual big turbo kit and can make more with just 93 oct. Other kits like Doc Race will be coming in the future.
Our cars like timing but it's not the only way to make power. The bigger question is how much of an investment do you want to make. |
H4CK1NT05H24.50 |
03-09-2020, 01:46 PM | #9 |
64
Rep 412
The thing is that hybrids power can normally be used with a safe tune and keep the stock engine with a ''safe'' tune. Big boost option wih a stock engine makes no sense.
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
janea120728.50 |
03-09-2020, 03:21 PM | #11 |
225
Rep 677
You don't have to max out the turbo. You can run at 50% load as compared to 100% load on the hybrid turbos.
03-12-2020, 11:27 AM | #12 | |
1486
Rep 1,268
My apologies I am a noob at this; I don't know if budget was a factor in your decision to go with St1 or reliability/safety. |
03-12-2020, 12:42 PM | #13 |
47
Rep 163
From what I've heard is the stage 1 pump is enough to max out the VTT GC turbo on 93 pump gas. If you start getting into ethanol than that is different and you would probably need the stage 2.
03-12-2020, 01:12 PM | #14 | |
552
Rep 686
Drives: Your mom crazy
Garage List 2020 BMW M340i CURRENT [0.00]
2003 BMW 330i RIP [0.00] 2011 BMW 335i SOLD [0.00] 2016 BMW 340i SOLD [0.00] 2020 BMW X3M RIP [0.00] |
Ethanol is higher octane but also needs 30% more volume than gasoline to do the same work. That's where the bigger pumps come in.
2020 M340i
DAW UF-X; Wagner intake manifold/port injection; ID1050xds; Precision Raceworks St2.5 LPFP ECUTEK; Wedge Performance E70 tune KW V2; BC Forged EH173 |
03-12-2020, 01:23 PM | #15 | |
1486
Rep 1,268
03-12-2020, 01:28 PM | #16 |
552
Rep 686
There is a whole separate thread about the pumps I recommend switching this conversation to if you want to get additional details. But in short, they're all comparable, just have different flow rates
2020 M340i
03-12-2020, 01:40 PM | #17 | |
552
Rep 686
I think since you're limited to 93 octane, a slightly bigger turbo is going to provide you an advantage and possibly a better safety profile. I'm still learning this stuff too, so someone else may have a valid counterpoint. There's also cost to consider. Either way, I'd include the Supra pump as an option for reasons I stated above - without ethanol, flow is just not as big of a deal for these hybrid-sized turbos.
2020 M340i
03-12-2020, 01:44 PM | #18 | |
47
Rep 163
06-24-2020, 08:35 PM | #19 | |
246
Rep 483
06-24-2020, 09:01 PM | #20 |
316
Rep 420
I have VTT GS and Dorch 1. 98Ron. Now the power is the same as on stock turbo with E20 + WMI. 526hp. Since the time of 100/200 and 1/4 is almost the same. Later, when I’ll finish the setup, I’ll go to the stand and measure it for sure.
M140IX. Turbo Pure 800 Cast.
06-27-2020, 06:59 PM | #21 | |
193
Rep 452
That’s about a $400 difference in savings, more if you get it used. Basically covers a major chunk of the tune if you decide to go that route. |
Solid67187.00 |
