BMW X5
      03-06-2020, 03:35 PM   #1
mrjoed2
210
Drives: '14 650 M Sport Edition
Radar detector hard wire.
Just picked up my M50i on Wed. She is gorgeous.
Will post more pics this weekend.
Question: wish to run a hardwire for my Max360c detector. It will be mounted to dash with sticky cup - does anybody know where the easiest location is to tap power for a power cord behind the dash?
I know there is a 12v socket in front console, but don't know if that would be best source - or closest fuse block.
Thanks
      03-06-2020, 03:48 PM   #2
scottjays
Starfleet Command
scottjays's Avatar
315
Drives: 2020 X5 M50i
I used Blendmount for under mirror mount and mirror tap. Had a prof install in Delray Beach. easy fast and looks great. I would not use sticky cup for sheer look of it.
2020 X5 M50i Phytonic Blue w/ Black Merino
22" 747M wheels,
      03-06-2020, 04:20 PM   #3
BMWZ4
BMWZ4's Avatar
1910
Drives: '23 X1/'23 Allroad Progressiv
Agreed Mirror Tap is a solid solution
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
      03-06-2020, 04:58 PM   #4
speuk
Registered user
78
Drives: G05 3.0d MSport / F23
2010 f07 SE GT  [0.00]
Or if on dashboard just use a fuse tap in the footwell fuse box. There are switched and constant supply fuses in there. If you search for dash cam installation threads there are photos and fuse numbers. Just can't remember fuse numbers of the top of my head.
Easy to run cable behind trim by door rubber and along back of dash
      03-06-2020, 07:39 PM   #5
mrjoed2
210
Thank very much, I will do a search.
      03-06-2020, 07:42 PM   #6
mrjoed2
210
Appreciate the info. I did check with my installer ( which I have used previously did great job) advising had issues with mirror taps throwing codes, will do it but no warranty the job. Other downside of the blendmount is your in for a new one whenever you change detectors I believe.
      03-06-2020, 08:59 PM   #7
scottjays
Starfleet Command
scottjays's Avatar
315
I have the Max 360 as well...it's big I def prefer it under the mirror...I toyed with idea of Uniden R7. Blendmount has an adapter so no need to replace the whole blendmount. but in reality, now that I've used the blendmount across 3 BMW's and 2 Vettes I can never go back...it's the price to play. if I need to replace or change out. minimal cost in comparison to return, imo. have used mirror tap over 10x and never had codes thrown. Back to the Uni R7, my Max 360 was going off so often that I was intrigued with the perf of the R7...however and really researching correct settinings for the Max, it works great now. very silent and very few false alarms.
22" 747M wheels,
      03-07-2020, 02:39 AM   #8
speuk
Registered user
78
Picked up power from front fuse box F27 constant and F72 switched. Both were unused in mine. F72 is one of several for usb power, I don't have the travel and comfort pack so guess that might be why it is unused.
screamace303.50
      04-03-2020, 08:45 AM   #9
radmjk
radmjk's Avatar
No_Country
241
Drives: 2024 X5 M60i, 2020 RRS SE, 201
Thanks
Congrats on new ride! Please see the below link. I just used mirrorTap for my escort 360c in my M50i.
It was a very simple process, literally taking about 25 minutes.
https://g05.bimmerpost.com/forums/sh...1656049&page=2
RADMJK
2024 BMW X5 M60i Brooklyn Gray Metallic
2020 Range Rover Sport SE White
2017 BMW 530i xDrive Black
2005 BMW Z4 2.5i Jet Black
      04-03-2020, 07:23 PM   #10
mrjoed2
210
Thanks my installer did the hard wire along with a front window tint & PPF. I did go with the dash mount as I'm used to it there. My Max 360c is working fine there. Installer told me there were no instant off fuse slots, detector powers down after 5 mins along with gearshift LED.
Only PIA with a detector in either spot is it must come down to put sunshade up, but with magnetic mount not too big a deal
      04-11-2020, 09:32 AM   #11
radmjk
radmjk's Avatar
No_Country
241
You know, probably would not have to remove the detector with the blendmount when placing the sunshade. Here's mine now with the blendmount.
https://g05.bimmerpost.com/forums/sh...2&postcount=26
RADMJK
      04-11-2020, 09:48 AM   #12
Skilly
40
Drives: 2020 BMW X5 M Sport
sorry to detour the thread - I ordered the same interior choice for leather as you did (Ivory/Navy Blue). In the config it shows an Ivory dash with both full and extended option. Yours is black which surprised me!
Was that a custom choice you made?
      04-11-2020, 10:32 AM   #13
TurtleBoy
TurtleBoy's Avatar
13275
Drives: 2019 X5 40i,2021 M340i
It looks like they made a change (at least on the build) to the lower dash for the extended Ivory/Blue. It used to be black Sensatec but now it looks like it is ivory Sensatec. The full Ivory/Blue looks like it is using the Ivory leather has it had been.
One other difference is the lower part of the console appears to be ivory in the current extended where it was black before as it is in all of the other extended options.
      04-11-2020, 11:50 AM   #14
Skilly
40
I did my build back towards the first week of March - If I'm reading your explanation correctly, it sounds like it might be a config change for the extended leather option rather than full? These photos made me pause to wonder what to expect - I picked this color combo in part because of the Ivory lower dash but sounds like its only the extended option that might be going through an update...whew!
I've had BMW do these quirky unannounced 'tweaks' with a couple of my past builds; especially when they are getting closer to an MY change over.
      04-11-2020, 12:52 PM   #15
TurtleBoy
TurtleBoy's Avatar
13275
That is correct as far as I can tell, the Full seems to be the same as it was in the beginning of the model year with the stitched Ivory lower dash and the blue upper dash and door tops.
Skilly40.00
      04-11-2020, 01:48 PM   #16
Skilly
40
thanks for the info - really helpful!
      04-11-2020, 06:27 PM   #17
mrjoed2
210
In looking at it, I think you would still have to remove the detector with the blendmount. The sunshade fits pretty tightly against the rear mirror- and the entire windshield actually.
      04-11-2020, 06:29 PM   #18
mrjoed2
210
Nope- photos in configurer showed black lower dash with the Ivory/Blue extended Merino option.
Looking now they changed it to Ivory lower. I actually prefer the black.
      04-12-2020, 10:34 PM   #19
ggindy500
Drives: 2015 X35d
Thanks
What brand/model do most people use?
      05-23-2020, 11:55 AM   #20
ProPhoto24
Drives: X5 M50i
Ivory Blue seats
Placing my order today with the dealer. Have it built out with same ivory and blue seats. Do you like, love, or hate them? Scared the white will show everything. Dealer told me about some $700 sealer they use on the seats and exterior, if it gets permanent scuff they replace the seat for you I guess? Thx for any insight.
      05-23-2020, 12:11 PM   #21
Marty in NY
Marty in NY's Avatar
2723
Drives: 21 X5 40i, 18 GTi, Snowblower
You sure you want our opinions? I would not go with any light color, I keep my cars too long for light colors to continue looking good and I'm not a believer in buying dealer sold protection of any kind. Way too much markup in most cases, if I want some sort of protection, I'll source it aftermarket. However, if you like what they are offering and you have it in writing that they will replace your seats if this or if that happens, I hope you are a lawyer and read between the lines of their protection guarantee so you don't end up with a battle on your hands when you go to use it
xbimmers
