2011 328xi won’t start, makes a weird noise help
03-04-2020, 09:17 PM | #5 |
Rep 8
Update #1
scanned the car and got back the following codes! P052B & P054B (CURRENT) P0304 (CURRENT) P13B6 (CURRENT) P052B P054B (PENDING) P0016 - CRANKSHAFT BANK 1 P0016 SENSOR A P0012 & P052B PERMANENT |
03-10-2020, 11:50 AM | #7 |
Rep 8
Update #2
Replaced the crankshaft sensor, camshaft sensor and cleaned out the solenoids Left with the following codes P052B permanent P0012 permanent I’ve been searching online and can’t find any video that makes a similar sound to what my car doing. Any advice? |
03-10-2020, 02:03 PM | #8 |
231
Rep 5,691
So you replaced the starter because? Just trying to figure out what all happened here.
Car stalled and wouldn’t restart. Sounded like this the whole time? Sounds like the timing is off for any number of reasons. |
03-10-2020, 02:43 PM | #9 | |
Rep 8
It started fine before this. After it stalled, it sounded like this. It had a misfire in cylinder 4. Could this be due to low compression? I’m going to try to do a compression test today. I’m also going to swap the solenoids for new ones today |
03-10-2020, 08:53 PM | #10 | |
231
Rep 5,691
03-11-2020, 11:23 AM | #11 | |
Rep 8
Yea I noticed the valve cover is leaking so I’m going to take a look under it tonight and see if there is anything off with the cams |
