Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > N53 Oils
      03-03-2020, 02:37 AM   #1
8303otte
Drives: BMW 325i E90
N53 Oils
Hi
Probably been done to death but does anyone know definatley the oils required for the engine, gearbox and the diff in my car? and the amounts.
2008 325i 3.0?
I'm pulling my hair out!
      03-05-2020, 01:23 AM   #2
BudVlad
Old Geezer
BudVlad's Avatar
Czech_Republic
360
Drives: 08 E92 N53B30
2008 E92 N53B30  [10.00]
Engine 6.5l I’m using: Millers CFS 10W60
Gearbox 1.5l Millers CRX 75W90
Diff 1.3l Millers LSD 90
Appreciate 2
      03-05-2020, 07:14 AM   #3
Phil325i
Phil325i's Avatar
616
Drives: E92 325i MSport Coupe
You'll probably get a different answer from everyone who responds. For the engine any fully synthetic marked as BMW LL04 compliant will be fine. For the gearbox and diff there are loads of options. Opie Oils website is a good starting point...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      03-22-2020, 04:35 PM   #4
E92William
1998
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
Originally Posted by 8303otte View Post
Hi
2008 325i 3.0?
go to the 540rat blogpost look it up and find yourself a high film strength motor oil. if you have q zf 6 speed automatic use only zf lifeguard 6 fluid. if you got a manual then bmw 75w90. got a gm 6l45 use valvoline maxlife. differential just use bmw fluid. one bottle is enough
      03-27-2020, 01:01 AM   #5
Soravia
114
Drives: 2011 E91 Silver xDrive 6MT
Don't put GEAR oil in your transmission. Gear oils are for diffs and don't come with synchro additives to save your synchro. Get MTF branded stuff. ACDelco 10-4055 is one I'd use for cold conditions.
      03-28-2020, 05:44 PM   #6
8303otte
Thanks all, I keep getting recommended to use ATF in a Manual gearbox. surely if that was the case they wouldn't be different in the first place?
