I think my turbos are whining...
02-28-2020, 11:11 PM | #1 |
1044
Rep 1,667
So I’ve got a 2007 335i with 96k miles...no wastegate rattle...hits boost targets...turbos spool well...tuned for 5k miles. I was on mhd 1+ v7.0 and I started to hear a whine at part throttle starting around 2,500 rpm. When the throttle is full open the drivetrain noise is too loud to hear it. I know the turbos sometimes start to whine when they’re on their way out...but does 96k miles seem a little early for that?
I retuned to stage 0 today and don’t hear any whine...is it possible I’m just hearing the turbos spooling to a higher rpm on stage 1+? Or do y’all think my turbos are going??? |
02-29-2020, 02:50 PM | #2 |
1933
Rep 1,532
Do a boost leak check, change your oil often, and don't worry about it sir.
JM98391.00 Bimmer_Engineer1043.50 |
02-29-2020, 03:15 PM | #3 |
1044
Rep 1,667
Chris@VargasTurboTech1933.00 |
02-29-2020, 03:41 PM | #4 |
27
Rep 87
With your car running look at the belts turning on the pulleys, particularly the belt tensioner. Notice any wobbling or do the belts spin straight and true?
02-29-2020, 08:35 PM | #6 | |
27
Rep 87
Or maybe not. It's hard to pinpoint. As long as you're not excessively hard on the car I wouldn't worry. |
03-01-2020, 09:03 AM | #7 |
352
Rep 2,050
My turbos have a slight whine when cold which is more profound with DPs installed. It still hits boost well and I have no leaks that I know of.
Once the oil temps are up, the whine becomes more suttle. So it might be normal as plenty ppl on the forum have whining turbos. Now a siren is different esp with white smoke lol
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
03-01-2020, 06:01 PM | #8 |
1044
Rep 1,667
What does the siren indicate? White smoke out the exhaust? I’ve had a smoking issue before...cleared up with some at205 added to the oil.
What I was hearing sounded like spool noises just louder than before...it could have been described as a very faint siren... |
03-01-2020, 06:30 PM | #9 |
391
Rep 532
Mine have been whining for a year. As long as they aren't smoking too bad and hold boost, they are fine. Save up for the inevitable turbo replacement but I wouldn't worry about it meanwhile.
Chris@VargasTurboTech1933.00 Bimmer_Engineer1043.50 |
