BMW X5
      02-27-2020, 07:01 AM   #1
eRiggs5
eRiggs5's Avatar
299
Drives: 18 M3 CS
Retrofit Tow Hitch?
Is it possible to retrofit the tow hitch if it's ordered without? I found an x5 I like however, it didn't come with a hitch that I really need...
-> 2018 M3 CS <- follow IG: eriggs05_m3cs
2020 Grand Cherokee Summit: Wife's
2016 BMW M3: Gone
2008 Lexus IS: Gone
      02-27-2020, 07:36 AM   #2
VTENGR
1053
Drives: 2020 X5 M50i
There's an aftermarket one, invisihitch/stealth hitch, which you may look into. Probably would be cheaper to go this route then to do a retrofit. The added benifit is when the hitch isn't in use, you won't have the eye sore that is the current hitch setup.
eRiggs5298.50
      02-27-2020, 08:19 AM   #3
cesimeone
cesimeone's Avatar
59
Drives: 2020 X5 MSport, 2018 330i
2018 BMW 330i  [0.00]
2020 BMW X5 40i  [0.00]
I wouldn't mess with aftermarket hitches on the X5
-C
      02-27-2020, 09:33 AM   #4
cesimeone
cesimeone's Avatar
59
I've had 2 X5s both with factory hitches...my F15 was the BMW optional tow pack and my G05 was ordered with.
My best friend is a BMW master tech and let me know how many "screw ups" he's seen with aftermarket kits, not the mechanical side of the kit (I.e mounting, bolting, chassis etc.) but the electronic bit. The towing module communicates with the car quite a bit for the PDC system, display for trailer lighting notifications, rear air ride for auto leveling, driver assistance features for limited functionality when the trailer is connected. Needless to say, quite a bit.
Considering how flooded these cars are with tech, having Joe Saturday from the town hitch shop down the street install my stuff on a vehicle he really doesn't know.....wasn't a chance I was willing to take.
This doesn't mean the BMW Stealership gets it right every time but at least they have the resources to do so if they f*** it up.
-C
      02-27-2020, 09:54 AM   #5
denaliman
denaliman's Avatar
470
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
Stealth Hitch is the way to go.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      02-27-2020, 04:35 PM   #6
James_G0540i
Australia
446
Drives: 2021 X5 G05 40i M Sport
I've got the after-factory BMW OEM towing hitch and it's awesome.
It all comes down to how often you tow, what you anticipate towing and aesthetics (looks).
If you're towing every day, or a heavy load (> 6,000lbs) or maybe both - I'd probably get the factory option. Its rated up to 7,700lbs (3,500Kgs).
If you tow occasionally or only several times a year, the after-factory hidden/stealth is a great option, however you need to remember that the towing limit is reduced to ~6,000lbs (2,700Kgs).
The other consideration is aesthetics.
The factory option uses a different rear bumper setup with the rear diffuser missing. Some say it looks OK, but in my opinion it looks ugly, especially if you've got the M-Sport package. It looks like someone has rear-ended the rear-low bumper.
The after-factory OEM uses a removable hidden (Stealth) hitch setup, and all you see is the normal rear bumper & diffuser, when not in use.
There is no advantage (other than towing weight) in getting the factory installed hitch. Both options are coded into the vehicle's ECUs so that Safety and Electronics features behave properly when towing.
Westfalia make the after-factory OEM tow hitch, and you can buy it and get it installed by a 3rd party - but my advice is to get the dealer to install the OEM after-factory tow pack, as they know how to code the towing setup into the vehicles ECUs, which also means it does NOT impact the factory warranty.
The G05 X5 has some seriously advanced electronics and technology, and I wouldn't let anyone mess with it other than a qualified service dealer.
Good luck
      02-27-2020, 05:07 PM   #7
Multimodal
2896
Drives: 2019 X5 50i, 2018 911 T
I used an Invisihitch on my E70 X5 for 4 years with no problems. I bought a Stealth Hitch for my G05 X5. Both are rated at 7,700 lbs.
BMW says the G05's towing capacity is reduced to 6,000 lbs if you don't get the factory hitch but I don't believe that is anything but marketing. There are no changes to other equipment on the vehicle when you get the factory hitch so there is no reason for the towing capacity to vary.
With a Stealth Hitch I am viewing my X5's towing capacity as 7,700 lbs with a 600 lb max tongue weight.
Current garage: 2023 Rivian R1S Adventure Forest Green/Ocean Coast, 2018 Porsche 911 T Carrara White Metallic/Black, 2019 Ram 2500 Big Horn Diamond Black/Diesel Gray
Archived: 2019 BMW X5 50i M Sport Mineral White/Full Black,2019 Ford GT350 Ford Performance Blue/Dark Slate, 2012 BMW X5 50i Alpine White/Black, 2014 BMW 320i M Sport Melbourne Red/Black, 2009 BMW DINAN3 Alpine White/Black, 2008 BMW 335xi Alpine White/Black, 1998 BMW 328is Avus Blue/Tan
      02-27-2020, 05:54 PM   #8
James_G0540i
Australia
446
That's probably true.
The Westfalia (BMW OEM) site that lists their stealth G05 X5 tow-hitch says 7,700lbs (3,500Kgs).
I only tow something in the 3700-3800lbs (~1600-1700kgs) range, so not an issue for me, but if something happens while towing something heavier on the non-factory hitch, it will be interesting to see what BMW's position would be.
      02-27-2020, 08:10 PM   #9
James_G0540i
Australia
446
Here you go, pics with the tow on and off.
      02-28-2020, 05:16 AM   #10
bqvalen
52
Drives: 2019 G05, 2016 F15, 2019 XC60
Why? I did mine in my garage in 2 hours. Cost 1/5 bmw one. And when aftermarket you get to keep the kick to open feature.
      02-28-2020, 06:57 AM   #11
James_G0540i
Australia
446
I can think of one BIG reason - CODING.
Have you coded (or programmed) your car for towing?
Coding ensure sensors, safety features, transmission and engine recognize that you are towing, and modify their behavior accordingly. For example, two important features:
- Disabling of PDC/Parking sensors when you have a trailer attached, else the cars safety features could kick in while you're reversing with whatever your towing.
- Additional Transmission cooling. Transmissions come under more stress and heat during towing, so earlier cooling is required.
Do you have "Towing mode" in your General > Settings?
As the name implies this enables the cars systems for towing, and can be selected manually via iDrive7 before attaching a trailer, or automatically as the system normally recognises I have attached a trailer and enables it.
You may have saved some $ going DIY, but you risk damaging your car, or worst having a driving incident or accident associated with the car's safety systems kicking in when they shouldn't.
      07-12-2021, 09:15 PM   #12
EUPremier
Ireland
65
Drives: 2020 X5 M50d
Stronger cooling fan (1000W) & bigger wiring harnesses on vehicles equipped w/Tow hitch. Standard fan is 650W for all but the the most powerful variants.
Currently driving 2016 F10 M5 & 2017 G11 730d.
Note: Taxes on vehicles in Ireland are bananas!
Previously
2019 G05 X5 M50D, 2016 F36 430d, 2012 F10 520d, 2006 E60 M5, 2005 E60 530D
xbimmers
