Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > NOX Sensor faults
      02-25-2020, 11:33 AM   #1
8303otte
Drives: BMW 325i E90
NOX Sensor faults
Hi All,
Would any of you mind looking at these fault codes?
I think it means the Nox sensor has had it.
I am right?
Cheers
      02-25-2020, 12:42 PM   #2
W37V
[Oo=||=oO]
No_Country
1103
Drives: e92n52 & f15n57
Nox sensors do tend to fail. Errors do indicate that the your 1st nox failed.
      02-25-2020, 03:08 PM   #3
8303otte
excellent. I've got a 3 month warranty as I've just bought the car
Noir883.00
      02-26-2020, 03:00 AM   #4
8303otte
Another thing I have noticed is a really bad hunting idle at cold, as soon as I have driven a few mile and she is all warmed up, she runs like a dream.
Is this a symptom of the nox sensor? I don't get any issues whatsoever, I will try and get a video later
      02-26-2020, 07:18 AM   #5
S.H
Drives: e93 325i-n53, f04 750i/ah7-n63
Check out bimmerprofs dot com. I have had nox emulator for a couple of years and the engine has never been better.
      02-26-2020, 10:09 AM   #6
8303otte
I would but it is getting fixed under warranty and I doubt I can get that out of them
      02-27-2020, 06:04 AM   #7
8303otte
Hi again.
Just had these scanned at the garage and they reckon all it needs is a cat regen. This doesnt sound right does it?
      02-27-2020, 11:46 AM   #8
S.H
It could be. According to bimmerprofs (and BMW) desulphation happens when you drive 110km/h for 25 minutes with more than 50% fuel (!). So if you never drive on autobahn, it will get glogged: https://bimmerprofs.com/30ea-nitric-...r-sulphurized/
Since the NOX converter anyway will go bad with mileage, I believe the cheapest solution is an emulator. Easy replacement.
      02-28-2020, 01:52 AM   #9
8303otte
Originally Posted by 8303otte View Post
Hi again.
I genuinely can't believe this but I forced a regen with ISTA and the codes have gone and not returned!!
I will look at the emulator in time but I only have 80k at the moment
      01-28-2021, 03:59 PM   #10
AUDELA
AUDELA's Avatar
Drives: BMW 325i N53 3.0L (E93) 6MT
Hi again.
Hi - just wondering if the clearing of the codes worked permanently or if you had to eventually swap out your nox sensor?
      02-11-2021, 01:44 AM   #11
8303otte
Hi again.
morning,
very sorry this notification never came through.
it came back almost immediately but has no effect on the running of the car and does not bring up anything on the dash.
the car hunts on cold but only after an initial movement which I put down to the vanos as I cleaned them a few months back and the hunting stopped, so they need replacing I think
