02-25-2020, 11:13 AM | #1 |
51
Rep 443
X5 45e Winter Battery Range in EV Mode
Hi All:
For those who are driving there 45e's in colder climates, what is the range you are getting in EV only mode on 45e ? Just wanted to check and see if it will work for me, since where I live we have temp hitting -15 to -20 for 2 months at least. TIA! |
02-25-2020, 02:58 PM | #2 |
1091
Rep 2,420
I haven't encountered that low temperatures. In Belgium it is around 5 degrees. My range is between 60-65 km. If you pre condition you will be around 60 I think.
02-25-2020, 03:03 PM | #4 |
60
Rep 80
Not been too cold in the UK this winter either, but I have been getting an indicated 39-44 miles of range when fully charged overnight and if you have watched the HArry’s Garage review, you really do get the range that is shown
02-26-2020, 12:27 AM | #5 |
166
Rep 199
No real winter in Southern Finland either, first time in my life. So no freezing temperature test results to share. In the -3 to +3 degree morning temperature range that has been the norm here, my usual range is from 55 to 65 km.
02-26-2020, 01:39 AM | #6 |
98
Rep 183
For some reason I get only 50-55 km of range in pure electric. 5-10 degrees here in Belgium.
Seems like I am at the low end of the range... What's your avg kwh/100km? I get 42 more or less... |
02-26-2020, 06:27 AM | #7 |
1091
Rep 2,420
02-26-2020, 09:23 AM | #9 |
51
Rep 443
Thank you everyone for sharing the range details.
Hoping someone living in in northern europe will chime in, since they probably have same temperature as Quebec, Canada |
02-26-2020, 09:25 AM | #10 |
51
Rep 443
Another quick question, does X5 45e have automatic pre-conditioning feature where it can be pre conditioned i.e. heated up (battery as well as the internals of the car)?
I have a covered garage but since it is not heated, in winter it can still be around -5 Celsius inside the garage. |
Zeee3.50 |
02-26-2020, 09:41 AM | #12 |
51
Rep 443
02-26-2020, 09:42 AM | #13 |
98
Rep 183
Mine quotes a range of 55 or so but i typically dont make it that far on electricity. (My default is full electric)
The quoted range doesnt matter much, the effective one is what counts for me. |
02-26-2020, 01:40 PM | #14 |
105
Rep 182
I always use precondition in the morning. Daily traject is 40 km. Less then 10 km highway. I use full electric mode. In the morning I mostly have under 30kw usage. In the evening 10 kw higher...
Overall average 33kw/100km. I mostly see 65km range but saw 75 also, see pictures, when it was 12 degrees C. Car is always outside.. 20" bmw winter wheels When I had longer highway trips I used sport mode to run in the ICE and prevent it from turning down. |
02-26-2020, 03:40 PM | #16 | |
1091
Rep 2,420
02-26-2020, 04:31 PM | #17 |
1091
Rep 2,420
I am in the alps now. -12 C. Range 26 km with cold battery charged 52%.
Can't charge here. Only use the battery to pre heat the cabin in the morning. I drive in battery hold to keep as much battery as possible. Fuel consumption is 14,5 l/100 km. Not representative at all for my normal driving at home where I charge as much as I can an drive electric all week and ICE in the weekend. |
02-27-2020, 05:03 AM | #18 |
166
Rep 199
Some more stats:
1. I am pretty high up (just over 60 deg North), but no real winter this year so no stats for -20 degrees C. 2. My consumption has mostly been close to 40, sometimes at best below 30 kW/100km; these numbers are in the -3 to +3 degree C temperature range. Note that these can be directly calculated from the 21 kWh capacity and observed kilometer range. 3. I use preheating daily with preset time and start with battery at 100% as the heating comes from the wallbox. 4. Preheating with battery is also fine and works even at less than 20% capacity at start -- previously some have suggested it needs to be at least 40-50% full. It uses maybe 5 to 10 % of max capacity, depending on how long you preheat. 5. I get decent results even with just a few minutes of heating, wallbox or battery. The air in the car is warm although the seats are still cold and need seat heating. |
02-27-2020, 07:38 AM | #21 | |
Rep 4
Leave house preconditioned with full battery and do exactly 30km trip to work using 41-50% of battery depending on traffic / temperature which ties in with what the trip computer reports ~28-33 kW/100km. return trip is a little longer and higher usage seeing as the cabin is not up to temperature. |
volodp198.00 |
