02-24-2020, 11:29 PM | #1 |
Rep 11
I8 coolant refill?
I had a low coolant warning come on so I watched a video on youtube on how to locate the coolant tank. I foolishly proceeded and added the coolant myself. I had no idea the system was under a vacuum. My engine overheated on the freeway but I made it back home alright.
What do I do now? How can I repressurize my high temperature cooling circuit? |
02-25-2020, 02:13 AM | #2 |
29
Rep 115
Not sure how adding some coolant would cause that? Never needed to add coolant.
Like one of Pat's youtube videos, a low coolant warning light could be the sensor under the vessel as long as the coolant is around the line. |
02-25-2020, 02:47 AM | #3 |
Rep 11
The low coolant warning went off after I added coolant so the sensor is good. Wasn't until I drove for 10 minutes that it overheated ): To add the coolant all I did was open the cap and pour to the line then close it. I don't know if I was supposed to use a special tool or what.
02-25-2020, 07:07 AM | #4 |
29
Rep 115
I doubt it's anything that you have done? First i've heard of a special way to add coolant!
Maybe someone else on here can advise but sounds like a co-incidence to me, was it really low to start with to need topping up? |
02-25-2020, 10:42 AM | #5 |
126
Rep 308
Drives: 2015 Crystal White Giga World
If coolant is disappearing from your coolant tank then you have a leak somewhere or a blown head gasket from overheating the engine.
You need to check for continuity of the system to hold pressure. If pressure bleeds down then there is a leak and air is in the system causing overheating. The leak must be fixed and the system vacuum bled. Just adding coolant to the tank is not a problem.... but if you need to add more than a few ounces of distilled water for normal minuscule evaporation over a period of years then there is a problem. |
02-25-2020, 03:32 PM | #6 |
Rep 9
Coolant tanks have been under pressure for many years and the i8 is no different. Should only top up with a cold engine. Coolant cap is a known problem and needed changing on my i8 as it was evaporating coolant when hot and under pressure.
Was topping up my coolant once a month because of low coolant warning. Been over 3 months since cap was changed and no warning as yet. Haven't checked the coolant but 90% sure my issue is gone. |
02-25-2020, 08:08 PM | #7 |
Rep 11
Looking like a leak as a result from the pressure tank sensor they changed a few months back. When I opened the coolant tank I did hear the sound of an air vacuum filling up as air rushed into the tank to equalize, not sure it that means anything. It's so odd to me that my engine decides to overheat after I add coolant and not when it was low on coolant.
So I will try cleaning up the tank cap and see if that does anything. I remember it was filthy with dry solids, that could possibly be the area of the leak. I may have to just bring it in to the dealership. I'm wondering does bmw warranty cover this problem if I bring it in? Low coolant warning and engine overheating. Does what I did by adding coolant void the warranty in any way? |
02-26-2020, 02:09 AM | #8 | |
64
Rep 195
02-26-2020, 05:32 AM | #9 |
patsgarageonline.com
101
Rep 170
According to the service manual, there is no special procedure to add coolant to the expansion tank. Merely topping it off with coolant is what is recommended:
https://www.newtis.info/tisv2/a/en/i...nce/1VnYI7MiDv It's very strange that the coolant system would be under vacuum when you released the cap on the expansion tank. Typically, a vacuum would be induced in order to bleed air off the system and then coolant added to replace air that was drawn out under vacuum. However, final adjustment to the coolant level would occur without any vacuum on the system because the expansion tank is a positive pressure device. When you first reached out, I had assumed a leak somewhere, but after hearing that you had the sensor replacement done, it sounds like the technician did not perform the bleeding procedure properly and that there was an air pocket in the system. If there is air in the system this would draw fluid out of the expansion tank. There are auxiliary coolant pumps at several locations on this car and one of them may have been trying to fight an air pocket. When you relieved the vacuum of the system to top up the coolant, that air pocket probably wandered through the system and found it's high point in the water jacket of the top of the engine. My assumption is that you did nothing wrong, based on the service manual link, above. I'd assume that the technician did not complete the bleeding procedure correctly or that all indications were that the system was fully bled down. A fully hot system, with the heater running, and cycling per the BMW diagnostic tool should have worked. However, I've read that others have had multiple visits to the dealer to bleed the system after receiving a high temp warning. They had major coolant system components replaced and that still didn't correct the issue. I don't know if the issue was ever resolved because the original poster never followed up on the thread: https://bmwi.bimmerpost.com/forums/s....php?t=1494518
I daily drive my BMW i8 and enjoy doing my own service. If you're interested, please follow along on my journey to maintain and improve my i8. http://patsgarageonline.com
02-27-2020, 04:19 PM | #10 | ||
Rep 11
02-27-2020, 04:26 PM | #11 |
Rep 11
One thing that has me worried is that I opened up the hood. Does the dealer care if I went through there? I'm not fully sure what to tell them. I don't want them telling me they won't fix it since I opened up the hood and that it is my problem now.
03-04-2020, 04:20 PM | #13 |
Rep 11
BMW service advisor told me they are replacing the coolant reservoir, sensor, and hardware tubes. Should be getting it back today (: So glad it is still under warranty until November. Renewing the warranty cost $5,800 they said, very hesitant on paying that much but looks like I may have to
