Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Lack of power in corners
      09-09-2008, 09:17 AM   #1
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Drives: Green Bastard
Anyone suffer from a huge dip when attempting to power out of corners with less than a half tank?
      09-09-2008, 09:49 AM   #2
S4to335
434
Drives: 2014 Audi A4 / 91 Track Miata
you sure its not traction control taking over? Totally disable DTC and then try it again.
Car is now gone .... :-(
      09-09-2008, 10:12 AM   #3
Bubbles
Bubbles's Avatar
Cayman Islands
2753
I should have specified in my initial post that the lack of power occurs with traction control on and off (DTC and completely disabled).
      09-09-2008, 10:56 AM   #4
leftcoastman
52
Drives: 335i
Yes. Yes. Yes. Yes.
The car gets massive fuel starvation at anything under a third of a tank.
It could also be high coolant temps cutting your boost. You build up all this heat prior to the corner, slow down in the corner and the radiator doesn't work as well...coolant crosses the 244 degree magic number...and boost is cut. You could test that by logging coolant temps. But if the problem goes away on a full tank....it's likely just starvation.
      09-09-2008, 08:13 PM   #5
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Originally Posted by leftcoastman View Post
Yes. Yes. Yes. Yes.
That's the problem! Hopefully a new fuel pump will stop the madness.
(I never run too hot coolant-wise)
      09-11-2008, 10:42 AM   #6
leftcoastman
52
Drives: 335i
Bubbles - got my new fuel pump installed yesterday. Apparently they finally released the third gen pumps since up until now, the service campaign had been on hold. This gybes with Orb's experiences with BMW Canada.
The midrange torque is MONSTEROUS now. Seriously, I was taken aback when I finally found an empty road and got to go full throttle. I'm scheduled for 4 more track days this month, so I'll comment on corner exit power issues when I get back.
I got the pump and not the 29.2 update. Win win!
      09-11-2008, 12:32 PM   #7
S4to335
434
Fuel pick up has nothing to do with a pump..if it cant pull gas out of the tank..then you get no gas to pump. How about putting baffles in the bottom of the gas tank...or putting in a fuel cell.
      09-11-2008, 02:15 PM   #8
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
if it makes you feel better i have lack of power issues in all sections of the track. i think the issue is the 200ftlb torque the motor makes
      09-11-2008, 05:56 PM   #9
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Very nice, I look forward to your review.
      09-11-2008, 05:57 PM   #10
Bubbles
Bubbles's Avatar
Cayman Islands
2753
      09-11-2008, 05:58 PM   #11
Bubbles
Bubbles's Avatar
Cayman Islands
2753
I feel better now, thanks Nick.
      09-12-2008, 10:02 AM   #12
Dascamel
Dascamel's Avatar
48
Drives: 2008 e92 M3, 2010 e91 328i
Or the lack of traction due to no LSD
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options
2007 Montego Blue 335i (retired)
      09-18-2008, 09:23 AM   #13
Bubbles
Bubbles's Avatar
Cayman Islands
2753
I wish....nothing like feeling dead in the water around turns.
      09-23-2008, 03:36 PM   #14
DetailAddict
41
Drives: 2008 BMW 328i
fuel starvation... happened to me couple of times... it sucks BIG time.
