02-23-2020, 01:02 PM | #1 |
19
Rep 17
Inside of Exhaust Tips Peeling Off
I did a quick search and couldn't find anyone else having this issue, however, it appears to be an issue with other BMW models. The inside chrome coating of the exhaust tips has begun to peel off and looks terrible.
I first noticed it with less than 5K miles on the vehicle so I took in to my local dealership and they have agreed to replace them under warranty. I enquired as to whether I could have the chrome ones swapped out for the shadowline ones and they were unwilling to do so, however, they did state that if I ordered the shadowline ones, they would install for free and I could keep the new chrome ones that were being replaced under warranty. After enquiring about ordering the shadowline ones, I am told that they are on backorder and not currently available, so I was able to get some from IND for $530USD all in including shipping to Canada. I struggle with how a 3rd party distributor can have them in stock, but I can't order them directly from BMW. I was planning on swapping the chrome ones out at some point anyways, so at least I save on the labour.
Current - 19 BMW X5 50i, 18 Volvo XC 90 Inscription
Past - 14 BMW X5 35i, 11 BMW 550xi, 08 BMW 550i, 09 BMW 335i, 06 BMW 330i, 04 G35 Coupe |
02-23-2020, 01:36 PM | #2 |
1908
Rep 5,102
This happened on my 2019 M40i. I ended up using BBQ flat black paint to touch up. Took only a few minutes per side. Looked fine. That said I've since traded in that vehicle. In any event, looks like they never solved the flaking issue.
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
06-27-2020, 09:03 AM | #3 | |
135
Rep 372
06-27-2020, 10:07 AM | #5 |
135
Rep 372
06-29-2020, 11:14 PM | #6 |
216
Rep 296
Drives: M3 Competition (G80)
I saw another member with a similar issue on his X5. Dealer wouldn't replace but seems like warranty item to me.
Good luck on getting it fixed. |
07-08-2020, 07:05 AM | #8 |
48
Rep 106
I have exactly the same issue and it seems to be only the LHS too (guessing that's the exhaust that's always open). No service due yet, but when it is, I'll be asking the dealer to replace.
07-10-2020, 07:39 AM | #9 |
Rep 18
I had my left side replaced under warranty this week.
Instagram: https://www.instagram.com/tdot_f30/
07-21-2021, 08:56 AM | #10 |
Rep 1
Same issue for me around 16K miles
I had to take my X5 in for oil filter replacement - they told me the filter seperated and they have to order a new housing in - also they are looking at the exhaust peeling issue.
Originally i was going to paint myself but thought - wait - this is a BMW - paint shouldn't just come off. |
07-21-2021, 11:02 AM | #11 |
85
Rep 317
Drives: MY19 X5 40i
Happened to my 2019 X5 40i as well, left side started to peel off (97xx miles). I just use black marker to cover it up since is still minimal. Is less notice that way but if it get worst to a point like yours then I'll take it in. Even if is on back order, I'll have them order it and write it down on paper just in case. When the product arrived and the warranty expired, at least they can still honor it.
I did the same thing with my steeling column and is on back order. My warranty expired next year and god know how long this back order takes. :
Brandan
What?s next ? BMW X5 40i Audi Q3 Toyota Corolla S Nissan Murano |
06-24-2022, 08:01 AM | #12 |
25
Rep 37
Hey everyone — just a quick shout out to this thread and this forum. I leveraged the intelligence here, and, while taking my ‘21 45e in for regularly scheduled maintenance (engine oil, microfilter), I mentioned the flaking paint on the “Exhaust Pipe Embellisher” (actual part name). The service advisor noted they could paint or replace, and I urged replacement — all done under warranty with no charge. Thank you!
06-24-2022, 05:36 PM | #13 |
71
Rep 140
I had the same issue on my end too with my 2019 X5 with 18k miles. Since I'm still covered under warranty, local BMW dealer took care of it. Good luck!!
02-02-2023, 06:28 PM | #14 |
14
Rep 54
Reviving this thread --
Just brought my car to the dealer, replacement is covered by warranty, but just curious what others have experienced in terms of the replacement part. I have attached the replacement offered- shadow line trimmed on the outside and regular chrome on the inside. Compared to the old defective part -- the inside is painted dark gray. Just curious what replacement you guys were offered? My concern with the replacement is that the inside will not age well. |
02-03-2023, 07:50 AM | #15 |
71
Rep 140
My replacement part was identical to OEM-gray on the inside. I assume BMW may be using these chrome pieces as it may hold up better. Personally I like the gray pieces. Anyway-just frustrating….
02-03-2023, 10:44 AM | #16 |
352
Rep 441
I don’t understand why this is such a struggle for them. As I posted in another thread, I fixed our ‘19 by knocking off the loose paint with sandpaper and then hitting it with matte high temp paint and never had the issue come back. If a random guy with a spray can, masking paper and tape can figure it out, you’d assume they could identify a fix in manufacturing vs giving up and going with silver.
02-03-2023, 02:02 PM | #17 | |
33
Rep 49
02-07-2023, 09:35 AM | #18 | |
78
Rep 105
02-08-2023, 01:47 PM | #19 |
27
Rep 40
This is quick DIY fix with high temp spray paint and carefully tape-masking off paint/area to not overspray. I didn't bother to remove anything. Probably starts on the left side as you have more exhaust coming thru that side. Go slow, do a few layers, be patient. Spray the new gray/unpainted ones black, they'll look like crud soon.
I always paint all my vehicles' tail pipes black if they aren't already. Saves some elbow grease in the wash bay, and you don't see the sooty tips between washes. |
02-09-2023, 07:08 AM | #20 | |
Rep 14
My 2020 X5 has the same issue. It's terrible on the drivers side and starting on the passenger side. After a long trip and washing the car, my hose started spraying off more chunks on the drivers side. Will have to take it to the Stealership to get it done under warranty. |
