02-22-2020, 08:42 AM | #1 |
721
Rep 364
Bootmod3 N55 PWG172X OTS map update - Version 8.1
N55-PWG172X OTS map update version 8.1 is out!
Version 8.1, February 22, 2020: Boost/load control changed Power and torque increase We managed to get 1 psi more out of the PWG turbo across the RPM range Resulting in a nice HP and TQ bump Graphs attached are shown as HP/TQ, PS/NM. HP and PS alone to see the HP increase with a better resolution! |
02-22-2020, 10:34 AM | #2 |
Check out my Youtube @n55david!
1297
Rep 3,536
Drives: 2017 m240i, 2015 X3 x35i
Is this the same flash that would be used on the PWG f25 x3 n55?
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
02-22-2020, 12:36 PM | #3 |
77
Rep 175
I'm trying to reflash but I'm being told my OBD agent isn't up to date. I have updated in the app multiple times but every time it "successfully" updates to the newest version my connection drops out and will not re-connect. Once I turn everything off and connect I have to do this same process over.
13' 335xi PWG M-Sport 8spd - BM3, CTS Turbo FBO, H&R Sport Springs + Spacers, BMW MPE
02-22-2020, 02:05 PM | #4 |
BimmerPost Supporting Vendor
24322
Rep 191,063
Nice Halim
Halim@HCP720.50 |
02-23-2020, 04:48 PM | #5 | |
721
Rep 364
02-23-2020, 07:58 PM | #6 |
1086
Rep 2,361
How was this achieved? VANOS adjustments? I assume you were already running the turbo at full tilt?
Link to the logs?
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
02-23-2020, 09:06 PM | #7 |
168
Rep 474
Hello guys' I have the gts start up roar turned on with 8.1 and it doesn't sound as good as 8.0. I've flashed it back and forth, but don't realize anything different. Anybody else having this issue?
J. D. Cordier
02-24-2020, 09:45 AM | #8 | |
14
Rep 46
Just went for a short pull and the tune is running amazing, I was planning to custom tune when buying BM3 but have been very happy with OTS maps. thinking of either buying Stg2 AGG map or just going custom tune.
2012 f30 n55 6 M/T, RWD
VRSF Catless DP/CP, CSF FMIC, BM3 Stage 2, KW V3 |
02-24-2020, 03:23 PM | #9 | ||
168
Rep 474
J. D. Cordier
02-24-2020, 06:38 PM | #10 |
337
Rep 963
cross posting from FB group...
so I flashed this today and beat on the car for about an hour. got a couple WOT pulls also, but for some reason the data log start up kept lagging when I'd double click a gauge, so I was only able to get 1 usable log (if you trim it) http://www.bootmod3.net/log?id=5e545bd1d10b4323c83975ec first impression is that everything seems a little smoother. I no longer get the 3k-5k rpm hesitation blips (partial throttle) which seemed to coincide with the HPFP crashing vs target during WOT. in this log it looks like HPFP seems to hold up all the way through, but I seem to get a knock at 2900 RPM and the throttle cuts out immediately after. also seems like I'm not achieving target boost almost all the way through out. am I reading this correctly?
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
02-24-2020, 06:55 PM | #11 | |
272
Rep 529
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
02-24-2020, 07:43 PM | #12 | |
337
Rep 963
Are you saying that due to the wacky timing? Edit: damn I just remembered I ran some injector cleaner through the tank this last fill up and haven't completely gone through the tank yet. I'm guessing that would have an impact.....
02-24-2020, 07:58 PM | #13 | ||
272
Rep 529
Injector cleaner won't make any difference or negatively impact octane quality.
02-24-2020, 08:13 PM | #14 | |
4368
Rep 7,620
Knock at 2700 then 2900 (both after WOT). After the 2nd one, you overboost briefly (not too bad), but then throttle get closed down to 38%... you dont reach fully open throttle again until 6000 rpm. Despite throttle not being fully open, you drop below boost target shortly after the overboost and continue to deviate further and further below target until you are 7, yes 7psi below target, making only 9.5 psi compared with 16.5 psi target at the top end. Have you seen this before in your logs? That is a massive deviation. Maybe a bunch of WGDC got pulled because of the knock? Timing also looks pretty bad as noted. You really need to get a few solid 3rd/4th gear logs to make sure this is an anomaly and not normal behavior for the tune. |
02-24-2020, 09:07 PM | #15 | ||
272
Rep 529
That is the least of this guys concerns. The fact his timing is so terrible on the lowest octane map possible is the big problem.
02-24-2020, 11:22 PM | #16 | |
4368
Rep 7,620
02-25-2020, 03:53 AM | #17 | ||
272
Rep 529
02-25-2020, 08:46 AM | #18 | |
337
Rep 963
Other than trying different fuel, what else can I do about it?
02-25-2020, 09:21 AM | #19 | ||
272
Rep 529
02-25-2020, 09:52 AM | #20 | |
721
Rep 364
02-25-2020, 10:19 AM | #21 | |
337
Rep 963
Will have to try out some different gas stations as well. Looks like the Shell up the street from me sucks
02-25-2020, 11:03 AM | #22 | |
4368
Rep 7,620
If you really want to stick to 91, costco is generally the best. |
