02-22-2020, 05:22 AM | #1 |
29
Rep 17
Dual Camera Dashcam Install in 2019 G05 X5
I've recently installed a Thinkware F770 dual camera Dashcam in my 2019 X5 30D M Sport (RHD) and this video may help others intending to do something similar (especially useful for running the rear camera onto the the tailgate).
radmjk238.00 polychromatic134.50 VTENGR1051.00 FreddyBMW94.50 Cooltones241.00 Dr. Jekyll209.50 GrussGott18116.50 |
03-04-2020, 08:40 AM | #2 |
1051
Rep 1,951
I want to remove the D-pillar trim because I think it's the source of a rattle when music is playing. I have some trim removal tools, but I'm chicken when it comes to removing trim because I don't want to break any clips, etc. and make matters worse. Any tips to removing this trim?
03-04-2020, 12:16 PM | #4 |
1051
Rep 1,951
04-10-2020, 05:30 AM | #7 |
Rep 50
Hello,
Thanks for the video. I took exactly the same way last year to install my Blackvue double channel in my G05. Otherwise, I prefered to took 12V in the trunk fuse box, much more easy to change the input power between car and external battery. It means just an additional cable between trunk and glove box where I installed a Multisafer to cut the power when the car battery reachs 12.1V. https://www.ebay.fr/itm/MS-MultiSafe...53.m2749.l2649 |
04-10-2020, 06:06 AM | #8 |
29
Rep 17
Thanks for your comments. As I explained in the intro to the video the rear fuse box was going to be my preferred option because (as you pointed out) access is easier than the front fuse box. In my case my Dashcam has a built-in power monitor and cut-off so I didn't need a separate battery voltage cut-off device but other readers may find your link useful if they need one so thanks again.
06-27-2020, 02:52 PM | #9 | |
101
Rep 205
Have you gotten any "battery low" messages due to the 10 minute delay of the ACC power after engine shutoff? |
barrowdad29.00 |
06-27-2020, 03:00 PM | #10 |
101
Rep 205
One mistake I DID make was in widening the wrong hole in the rear panel when routing the rear camera wire toward the rubber grommet hole. I accidentally widened the hole into which the panel clip inserts. Haven't driven her at speed yet to see if it rattles but I hope not!
SmartSaves460.50 |
01-06-2021, 09:59 AM | #11 |
174
Rep 307
Happened to come across your YouTube video a little earlier (before seeing this thread). Appreciate the post up!
It’s typical for the cams to be ‘professionally’ installed on this side of the globe, but they essentially ran the same line and equally complained about how hard it is to get the cables from the rear (D?) pillar into the tube that connects to the boot lid for this G05. Edit: sorry only realised afterwards this was a June thread... |
01-06-2021, 10:24 AM | #12 |
29
Rep 17
Hi, Thanks for the the comment. Also for some reason I missed the comment from cygnusecks and can't see how to reply directly to him but in case this reply is helpful to you and others I can confirm that on my previous X5 I did get 'Shutting Down Due To Low Battery' message from the dashcam but after nearly 12 months with it fitted to my GO5 I haven't had any such messages. I think this may be due to the fact that the GO5 versions have another battery fitted in addition to the main one.
01-25-2021, 12:12 AM | #13 |
IG @F30_MPE
257
Rep 703
Another option for the running the rear cable for those who don't feel comfortable making the hole larger or don't want to pop off the d-pillar panel is to go through the headliner. Peel down the headliner and you will see a round black rubber cap (similar to the one on the left side of the hatch if you pause the video at 8:30). Remove the round rubber cap, poke a hole through it and feed the cable through, then pop the cap back into place. Also comes out the same place. If you have some sealant, you can seal the cap back up after all the cables have been run and you don't need to make any more adjustments.
2018 F30 340i | M Performance Edition Alpine White | Individual Black Merino Leather |
02-26-2021, 02:42 PM | #14 |
152
Rep 217
I installed by BlackVue 2ch 750s last night. I used the passenger kick panel fuses F27 which was empty and F72 which was also empty. F72 is a micro-fuse, that's a switched source and F27 is a ATC fuse battery power. I run the Power Magic Pro for parking mode control. There is a ground screw right there as well, so it's a cake-walk to use the passenger kick for the install.
I ran down the A-pillar behind the airbag into the passenger kick panel. For the rear camera I ran in the headliner, then used the factory rubber grommets into the upper hatch. Took some fishing, but everything is in the factory run paths and obviously a very clean install. I did not have to cut or poke holes into anything. I just popped the rubber guide out of the hatch and car, then fed from the car out, then through the grommet and then into the hatch itself. If you use one of the wire grabbers this like this, it's super easy to get it through things like the factory wiring paths and around the airbags. |
03-09-2021, 12:00 AM | #15 |
541
Rep 1,730
This is one of the best videos. Just a question on the fuses, you mentioned 38 and 61. Were those empty fuse slots, and which one is switched? I only need switched fuse in the front. Thanks!
03-22-2021, 06:23 PM | #17 |
541
Rep 1,730
Thanks but earlier you mentioned F27 is battery power, so it's constant. I need switched only to prevent battery drain (dumb camera setup) you mentioned F72 is microfuse, does this mean smaller fuse?
03-22-2021, 06:49 PM | #18 |
152
Rep 217
Sorry maybe I mixed up which one is which. One is a standard ATA fuse and the other is a micro, there is also a mini but for these it’s micro and standard.
03-22-2021, 06:51 PM | #19 |
152
Rep 217
You can grab a fuse tap from autozone or the like, if you only need one it’s worth paying the extra. If you think you will need more then order from Amazon or something to get a pack of them.
03-25-2021, 01:16 AM | #20 | |
541
Rep 1,730
My dashcam hard wire came with a fuse at the end, so all I need to do is just plug it into an empty slot. Fuse taps I saw have a pigtail that I would need to wire. It means I have to cut the fuse off the hard wire kit? This is what I have: https://www.amazon.com/Rexing-Mini-U.../dp/B01LXC2329 It comes with 10 Amp mini fuse hard wired to the kit.
03-25-2021, 08:26 AM | #21 |
152
Rep 217
Yes the fuse taps allow you to piggyback on the fuse spot and keep the original fuse.
The main issue I see is they didn’t give you much room with that short ground lug. So you will have to cut some of that shrink tubing or whatever to get some more length on that ground wire. There is a ground lug below the fuse box you can use. |
03-26-2021, 12:16 AM | #22 | |
541
Rep 1,730
Oh yes, that's exactly what I did, I cut the casing(?) and then used electrical tape to secure it at ideal length. I am seeing several empty fuse slots, instead of cutting this and doing tap (I don't want to mess with existing fuses), can I just use one of the empty slots, preferably one that has optional equipment that I don't have, and switched power.
Tags |
dashcam, g05, thinkware |
