Rail plausibility errors
02-12-2020, 02:23 PM | #1 |
671
Rep 1,442
I have the Jarek 2.8 tune and all of a sudden I have started getting rail plausibility error codes if I floor it. Any ideas?
02-22-2020, 09:50 AM | #4 |
671
Rep 1,442
02-25-2020, 07:30 AM | #7 |
274
Rep 1,054
Why do you think it's the fuel rail that's bad? Did you check both rail sensors front and back?
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
Chief Orman671.00 |
02-25-2020, 07:59 AM | #8 |
3058
Rep 3,910
Those codes are rail pressure sensor plausibility, and rail pressure sensor short to b+.... Sounds like your pressure sensor is dead.
The rail itself is just a piece of pipe (with a few fittings), so there's no reason to replace it unless it's leaking...which it probably isn't. Most (all?) diesel tunes raise the fuel pressure in order to increase power and maintain efficiency, so they put a lot of extra strain on the fuel system components. Pressure sensor, pressure regulator, and HPFP failures result. |
Chief Orman671.00 |
02-25-2020, 08:08 AM | #9 | |
274
Rep 1,054
Chief Orman671.00 |
02-25-2020, 08:39 AM | #11 | |
274
Rep 1,054
Oh and if you had a jbd I would check the front rail sensor since I remember a connection between jbd and premature rail pressure sensor failure.
Chief Orman671.00 |
02-25-2020, 09:07 AM | #12 |
3058
Rep 3,910
Definitely look up newtis.info for the correct procedure and torque specs. You don't want those things going wrong at 1600BAR!
Running the hpfp is all that will push air out of the rail. You need to crank the engine to do that. I crack off an injector line (loosen slightly, not remove!) then crank the engine until the joint gets wet. Be sure to give the starter plenty of rest so it doesn't overheat, and maybe keep your battery on charge too. Once there's fuel moving, tighten the injector line and start it up. It's likely to take more cranks than normal to build pressure, until all the air has been purged from the system. It will self-bleed as it runs. |
RL18273.50 Chief Orman671.00 |
03-02-2020, 10:13 AM | #13 | ||
671
Rep 1,442
03-02-2020, 10:45 AM | #14 |
274
Rep 1,054
I would imagine they are able to. My indy shop is able to do those things. As far as erasing your tune I would talk with your indy shop about it.
Chief Orman671.00 |
03-02-2020, 12:08 PM | #15 |
3058
Rep 3,910
Chief Orman671.00 |
03-27-2020, 08:52 PM | #16 |
19
Rep 69
If you are able to download and install ISTA, you can reset adaptations first. Usually, you'd want to do some data logging to see what is throwing the code(s) instead of just throwing money at the car to see which sensor is going bad.
2013 X5 35i
2011 335d - Deleted and Tuned by BRR 2008 Toyota Tundra SR5 Double Cab |
