02-12-2020, 11:41 AM | #1 |
16
Rep 71
(UK) Putting number plate on lower front grille?
Saw a bmw today with the numberplate on the lower front grille think it looked pretty neat!, wondering If I can do this too or would it be blocking airflow? placing numberplate in the yellow dotted box in photo.
my car is a 2018 340i. |
02-12-2020, 02:15 PM | #3 |
1002
Rep 2,223
At least your plates are often stuck on with double-sided tape vs. requiring holes to be drilled in the bumper cover! I used the Skene Design bracket to avoid the obvious holes - could work for you:
https://skenebrackets.com/pages/euro
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
02-13-2020, 07:49 AM | #4 | |
16
Rep 71
great thanks!
If I got the car brand new, I'd of said that I'll attach the front plate as I wouldn't want the front bumper drilled. heavy duty velcro pads would be my way. but yeah I just wanted too see if moving the plate to the lower grille would be possible since it looked pretty slik. |
04-26-2020, 10:18 AM | #5 |
Rep 34
Is your plate stuck directly onto your bumper?
My plate is stuck to a plastic mounting bracket. I was wondering if anyone knew what this mounting bracket was fixed to the car by - it has been on the car from new - UK car. |
04-26-2020, 03:07 PM | #6 |
BMW CCA Member
491
Rep 808
Sounds like double stick tape if you cannot eye a bracket holding it on. If you have some WD40 and a plastic spatula, you might be able to *GENTLY* pry it away.
04-27-2020, 05:16 AM | #7 | |
16
Rep 71
best part is taking of the bracket and finding the 100 drill holes where they messed up aligning it the first 99 times. |
