new to the forum with a 335d that knocks
02-09-2020, 12:03 PM | #1 |
Rep 41
Hello, I'd like to introduce myself as a new forum member with a recent purchase of a 2011 335d. You will all think I'm crazy...but I bought this car from auction without any inspection.....the price was right. (Copart out of Detroit)
I'm also the owner of a 2001 330xi and have owned a couple of e30's in the past. I'm not a great mechanic but comfortable with wrenching on my own stuff. I've really enjoyed reading the forum and learning. But difference from my e46...its so much simpler than this machine. I had the car shipped to me and immediately saw it needed tires...the ones on it are done, the battery was done and the windshield is cracked. No biggie...only $ to fix. The more concerning thing was the presence of an engine knock. From idle right up to higher rpm. Pulled all the covers off to get access and ultimately found with a rubber hose in my ear that the noise was most obvious directly underneath the harmonic balancer at the front of the motor. 1. I pulled the belts off - knock still there 2. pulled the harmonic balancer off and the knock is gone (its not the original) 3. put it back on and it seems there is some wobble...but visually its in really good condition. 4. The passenger motor mount looks to be collapsed when comparing to the drivers side. I can move the motor by hand with not a lot of effort. 5. I am going to get an oil analysis done before I do much else to maybe get an idea what I'm working with Any thoughts on this scenario or any further troubleshooting steps anyone might suggest? Will probably wait to get the oil analysis back before investing in any replacement parts. (and upgrades/deletes) Here are two videos - balancer off - knocking with balancer on Looking forward to being able to drive this beast and contributing to the forum. Tim Last edited by tshandonay; 02-09-2020 at 06:26 PM.. Reason: video content |
02-09-2020, 12:55 PM | #2 | |
274
Rep 1,054
If the motor mount is collapsed then it could be making noises from the metal on metal contact. Also any codes?
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
02-09-2020, 01:13 PM | #3 |
3058
Rep 3,910
Balancer and engine mounts are both common and simple enough to replace. Fingers crossed that's all your woes, but even if it is you should double down on the preventative maintenance!
02-09-2020, 02:47 PM | #4 | |
Rep 41
Its a Corteco, not fluidamper. OEM equivalent. only codes are related to low voltage from bad battery and having the MAF disconnected. |
02-09-2020, 03:33 PM | #7 | |
Rep 41
Anyway....I did look at the filter and didn't see any obvious signs of metal in it. Oil analysis will hopefully rule out the bearings and I can then order motor mounts and a different harmonic balancer. Even though I can't visually find any sign of this one being deteriorated. |
02-09-2020, 03:48 PM | #8 |
Rep 62
A rod bearing will definitely knock...up and down with engine speed of course. That was my first thought, but when I read it went away by taking off the balancer....Hmmm...honestly not sure what to make of that.
Makes me suspect the balancer itself, but that sounds a little weird as well. |
02-09-2020, 03:55 PM | #9 |
Rep 62
Hey I was thinking since you had the balancer off you would have had the belt off as well. So maybe it's coming from a tensioner?
Or did you run it with balancer on and no belt? |
02-09-2020, 03:57 PM | #10 |
Rep 41
02-09-2020, 06:28 PM | #12 |
Rep 41
I put a couple videos on you tube if anyone wants to listen and chime in. I'm not sure how this motor is really supposed to sound.
- balancer off sounding normal? - knocking noise Last edited by tshandonay; 02-09-2020 at 06:28 PM.. Reason: added links to videos |
02-10-2020, 07:53 AM | #14 |
Rep 41
I'm someone that just can't let go of a problem until I get it resolved. So I'm sitting at my desk thinking about this car that I somewhat recklessly purchased and I may have just put the pieces together.
I read the carfax again last night and noticed the oil pan gasket was replaced very recently at in independent garage. I've not read about the process to replace the oil pan gasket, but I'm guessing it involved supporting the motor in some way. I'm giving it about a 76% chance the the motor was jacked up or held by the harmonic balancer which resulted in it being warped or bent. Wishful thinking?? Anyone have a spare they'd be willing to ship me? Last edited by tshandonay; 02-10-2020 at 08:10 AM.. |
02-10-2020, 08:53 AM | #15 |
Rep 62
The motor would be supported by it's mounts...unless there's something really different going on there. The better question might be; why did they have the oil pan off in the first place?
I don't have a spare... Back of the balancer you have look like this? |
02-10-2020, 09:16 AM | #18 |
Rep 41
to answer your question...that's pretty much what it looks like. But it looks much newer.
And...I've been making some calls this morning. Waiting for the shop that serviced it to hopefully send me some information. Its not sounding positive. They're saying there was evidence of metal in the oil...which i can't see. Although its get very few miles on it since the last oil change so it may not have had enough time to accumulate any metal. Just can't get past it quieting down with the HB removed....makes no sense if there really is bottom end damage. |
02-10-2020, 09:43 AM | #19 | |
107
Rep 202
BRR Tuned
BB_cuda765.00 |
02-10-2020, 09:52 AM | #20 | |
142
Rep 634
Hard to tell from the video but the engine sounds pretty much the same as mine. However if metal is found in the oil filter that is obviously a very bad sign. |
02-10-2020, 10:01 AM | #21 | |
Rep 41
I'm curious....does your engine sound like mine in the video with the knock? I've never owned a diesel before and have no reference on what these motors *should* sound like. I'm going to have a hard time waiting for the oil analysis to come back. |
02-10-2020, 10:19 AM | #22 | |
142
Rep 634
I had a 540iT for many years. That engine also had a dull knock at idle. Someone else traced it down to something in the Vanos system and rebuilding their vanos eliminate the knock, for a while, only to have it return. I drove the car with the idle knock from 60K miles to 150K miles and other than being annoying, had zero impact on the operation of the car. Someone else is driving it today and to my knowledge, still no issues. |
