04-13-2021, 03:21 AM | #111 | |
558
Rep 1,179
You need the Driver Assistance Professional for the lane change and traffic light assistant. |
04-13-2021, 05:31 AM | #112 |
Rep 22
Thanks for the info. Would you be able to share the location of comfort plus also? I don't have the Driver Assistance Pro so maybe another time lol..
Is there a cheat sheet for Gxx that I just can't find? I can only seem to find Fxx ones |
04-13-2021, 05:45 AM | #113 | |
558
Rep 1,179
BDC_BODY3 - CAFD_00007083 - ComfortWorldMode1 - Ausgelesen = ComfortPlus HU_MGU - CAFD_00003E52 - FES_COMFORT_PLUS - Ausgelesen = activ - ECO_CONF_STEERING_COMFPLUS - Ausgelesen = activ - ECO_CONF_ATTENUATION_COMFPLUS - Ausgelesen = activ |
04-23-2021, 03:36 PM | #117 |
558
Rep 1,179
I've not heard of anyone having any issues. I've coded my last few BMW's and Audi's and not had any issues. Some of the ones on my Q7 were really obvious too e.g. beep on lock and never had any problems.
05-05-2021, 03:41 AM | #118 |
Rep 4
Hi all, Is there a way to code the exhaust flap always open on the new F40 ?
i have already coded some things, but i could not find a way to let the flap open all the times. |
05-05-2021, 05:06 AM | #119 | |
558
Rep 1,179
HU_MGU - CAFD_00003E52 - DISPLAY_MENU_CONFIGURATION_ENGINE_SOUND - Ausgelesen = enabled (was disabled) - DISPLAY_CONFIGURABILITY_ENGINE_SOUND - Ausgelesen = aktiv (was nicht_aktiv) |
05-05-2021, 08:09 AM | #120 | |||
227
Rep 344
Coding the active sound design does not open the exhaust valve. |
05-05-2021, 09:31 AM | #121 |
558
Rep 1,179
Is this a limitation on the F40? On my G21 it is opening the exhaust valve and you can clearly hear the difference with the door open. You can hear the switch on the valve and change in exhaust tone, not just what is piped through the speakers.
05-05-2021, 01:34 PM | #122 | |
227
Rep 344
05-05-2021, 01:47 PM | #123 | |
227
Rep 344
Exhaust valve https://f44.bimmerpost.com/forums/sh....php?t=1738690 |
05-05-2021, 02:04 PM | #124 | |
558
Rep 1,179
I just put the iPhone under the exhaust to be 100% sure (even though I could clearly hear it opening and the exhaust note changing). On the recording you can clearly see the valve activating. Edit: Seen a few other posts that perhaps it is a different behaviour for the M340i. So maybe the same is true for the 128ti and M135i? Last edited by srbs73; 05-05-2021 at 02:12 PM.. Reason: Updated |
05-05-2021, 02:21 PM | #125 |
66
Rep 478
Hi
What software / App are you guys using to code F40, At the moment I have carly app and adaptor Gen2 which I sued to use to code my F31 without problem. I can't use this with my F40 it's not doing it don't know why, is there another dongle I need to use? Also what sort of coding I can do with my M135i. Thanks. |
05-05-2021, 02:25 PM | #126 | |
558
Rep 1,179
05-05-2021, 06:02 PM | #128 |
558
Rep 1,179
05-06-2021, 03:38 AM | #129 |
Rep 4
05-06-2021, 05:20 AM | #130 |
227
Rep 344
11-11-2021, 03:52 AM | #132 | |
Rep 5
There is however between the mentioned and eco pro, eco is definitely softer. But I do notice there's a difference between sport and comfort - the turbo seems to be working more diligently. When in comfort mode it gave most power between 2000 - 3000rpm; where as in sport mode it kicks in earlier and lasts longer, between 1500 - 4000rpm. The engine also seemed to work differently, can tell from oil consumption lol. Under similar traffic (mixed with congestions and freeways), comfort can do around 7-8.XL/100Km, sport can do 8-9.XL/100Km. I've even seen it reached 10L/100Km when in sport plus, am not entirely sure about that coz I didn't put in sport plus for long. From other readings I also learnt that sport plus is just simply a sport standard with DSC off, in that sense there should be no difference in terms of engine performance whatsoever. |
