02-05-2020, 06:17 PM | #1 |
92
Rep 233
Drives: '18 M2 LCI
Black Hood Insulator removal?
Does anyone know if there any implications for removing this insulator under the hood? I noticed all the M cars don't have it, but non-M cars do. I want to remove it to hear a little more engine upfront, but don't want to remove it if there will be any issues. I could be wrong, but I believe BMW added these to the non-M cars to reduce cabin noise.
Appreciate any input!
'18 M2 LCI 6spd
02-06-2020, 03:28 AM | #2 |
97
Rep 373
if you want to hear a bit more engine just remove the engine cover
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
02-06-2020, 08:33 AM | #5 |
221
Rep 445
Mogki34.00 theserbatron36.00 |
02-06-2020, 06:50 PM | #6 |
92
Rep 233
Drives: '18 M2 LCI
I'd prefer to keep the engine cover on. I was mainly worried about the paint on the hood.
'18 M2 LCI 6spd
02-06-2020, 11:29 PM | #7 |
97
Rep 373
i do it for track driving engine does run slightly cooler lol every bit counts on these motors
02-07-2020, 07:16 AM | #8 |
221
Rep 445
02-07-2020, 07:41 AM | #9 |
832
Rep 674
Just removed my monday, pops out with clips, to clean compartment. Need to be careful with Xcross metal pieces underneath, if they get too hot, they can warp and pull down on hood, creating small warp indentation in hood. (this was from body shop and I confirmed with a BMW service guy.)
Exhaust/downpipe replaced ? Hear more growl there |
02-07-2020, 10:29 AM | #10 |
5559
Rep 5,374
I removed mine over a year ago. I also removed the engine cover and made a custom cover using a single valve cover from a E39 5 series to cover the coil packs, injectors, and exposed wiring.
I removed the hood insulation and heavily insulated big engine cover to reduce under hood heat entrapment in hopes of reducing degradation of various gaskets, hoses, fittings, plastics, and wiring, especially within the cylinder head area. As noted earlier, the M2/3/4 cars don't come with the hood insulation so there really is not risk to the hood paint. Also, the S55 equipped M2/3/4 have a very very tiny engine cover that only covers the front half of valve cover. The primary purpose of the heavily insulated engine cover on the N55 is to speed the engine warm up process, both on cold start and short drives. This improves efficiency but the downside is it locks in heat, which over time, degrades components. The cover also reduces injector noise to some extent. I notice a little more mechanical noise with all these insulating components removed under heavy acceleration. At all other times, I notice no real perceivable difference in sound.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
02-07-2020, 12:36 PM | #11 |
832
Rep 674
Good points jets, but the Xcross is different on 2 series, I believe. Don't think paint is risk, but BMW service rep noted the warp of the cross metal and slight indentations.
Just one guys/reps thought (M2 doesnt have one I think, but the compartment is different and the Xcross is not there. concave yes ? ) Anyways, not a big deal but consideration when pulling |
02-07-2020, 12:45 PM | #12 | |
5559
Rep 5,374
02-07-2020, 05:00 PM | #13 | |
832
Rep 674
https://f87.bimmerpost.com/forums/sh....php?t=1386255 Those cross beams are attached to the metal hood, and under extreme heat will warp and pull down and create a small indentation in the hood. The BMW service rep showed me a 2017 M2 vs my 2016 235i. Maybe its changed since 2017, but even the parts (see above thread) are different. I'll try and post pics later of both at the dealer when I get home. OP - if concerned chat with BMW folks |
02-12-2020, 12:34 PM | #14 | |
5559
Rep 5,374
https://f87.bimmerpost.com/forums/sh...1&postcount=68 Also, a simple search of realOEM shows that all 2 series cars, except for the M2 Competition, use the same hood: https://www.realoem.com/bmw/enUS/par...&q=41007373899 There are no concerns with warpage. I live in an area that routinely sees 90-105 degree summers. I haven't have any issues and why should I? It's the same hood as the N55 M2 The M2 Competition has the same glued on underside frame, but there is a slight change in the very back of the frame to clear the water/air top mount intercooler/intake manifold.
02-23-2020, 02:02 PM | #16 |
92
Rep 233
Drives: '18 M2 LCI
Update:
I have removed the insulator. I notice a slight increase in cabin noise and can hear more of the Dinan CAI
'18 M2 LCI 6spd
470MR104.00 |
02-23-2020, 02:37 PM | #17 |
3077
Rep 5,577
Do you think that under hood stamping design is for pedestrian impact protection ? I think the plastic engine cover are also utilized so skulls don’t impact the top of the engine |
02-23-2020, 08:23 PM | #18 |
5559
Rep 5,374
Nope. The S55 motor in the M2 Competition has the same hood and hardly any engine cover.
08-01-2021, 01:59 AM | #20 | |
201
Rep 425
Any specific tool that was you used? |
08-01-2021, 08:54 AM | #21 |
5559
Rep 5,374
BMWF87Melb201.00 |
08-03-2021, 02:01 AM | #22 |
201
Rep 425
Thanks for that - I do have a set of basic plastic trim removal tools, so will give them a try.
