02-04-2020, 01:18 PM | #1 |
278
Rep 379
Cracking Steering Wheel
Has any experienced cracking on their steering wheel? I have had this show up in a few locations on the wheel just recently. I'm nearly certain they are scratches, at least I hope, but if they are I'm clueless as to how they would have happened.
'01 M Roadster, '24 BSM M2
02-04-2020, 01:21 PM | #2 |
Flavor of the month
906
Rep 724
Drives: BMW F87 M2C
That's not cool, I'd def get that fixed by the dealer. Worse case, replace it with an upgraded M steering wheel with that alcantara covering.
Samuel of the Internet
2023 F98 X4M Comp 2023 F95 X5M Comp 2020 F87 M2 Comp |
02-04-2020, 01:57 PM | #4 |
2485
Rep 1,602
Damn! Do you park it outside and is there lots of sun? Just curious what could’ve caused this. I guess it could just be a manufacturing defect.
I scratched up the leather on my steering wheel several cars ago. I had a pocket knife that was clipped to the right side of my belt, turned out the clip for the knife was rubbing the steering wheel as I dropped into the car. I switched to wearing it on my left side and the problem was solved. |
02-04-2020, 02:02 PM | #5 | |
1576
Rep 1,049
Moflow2484.50 |
02-04-2020, 03:26 PM | #7 |
10933
Rep 4,551
Drives: 2015 328d xDrive
NYC Bimmer259.50 Conissah1576.00 |
02-04-2020, 03:29 PM | #9 |
5566
Rep 2,301
Wedding ring. I'm guessing you keep your hand at the 12 o clock position when you drive.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
02-04-2020, 03:38 PM | #10 |
278
Rep 379
Thanks for the feedback. I wanted to confirm it wasn't a known issue with the leather... Based on the feedback it's probably just my clumsy ass that scratched it, somehow.
02-04-2020, 03:43 PM | #11 |
2865
Rep 3,843
It might help to moisturize and treat the steering wheel with some good products. I use Leather Masters. It doesn't make mat leather shiny.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
02-06-2020, 07:20 PM | #12 |
609
Rep 969
That looks like a scuff caused by a person. I did this on a previous vehicle when the zipper on my coat scuffed the steering wheel as I slid in. Depending on how the wheel was turned, when you rotate it back to normal, a scuff from a zipper or belt buckle down low could end up on the side or top of the wheel.
If it's happening a lot and in different positions around the wheel, it is most certainly a scuff you are causing and I'd suggest paying attention to what happens when you get in or out of the car to determine the cause. |
02-06-2020, 08:14 PM | #13 |
10702
Rep 6,945
Drives: 2018 M2 AW DCT
I had this on my wheel. Groit’s leather care made the scuff disappear. https://www.griotsgarage.com/product...ks&from=Search
