BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > Upgrade CCC Controller to CIC?
      02-01-2020, 02:13 PM   #1
Jakg
Drives: 335d
Hi,
I've just bought a 2008 E91 335d (pre-LCI).
The previous owner has had the CCC system upgraded to the CIC system, and I'm very impressed with how it works.
I think there are a couple of mods left to do:
1 - The previous owner mentioned they've not yet upgraded the controller to the CIC version - e.g. I have the one on the left.
On eBay these seem very cheap (£30). Is it plug and play? Do I need to do anything else to fit?
2 - Upgrade the maps to the latest version.
3 - Potentially replace the HDD with an SSD.
Apologies if this has been covered before - I've done stuff with ICE before, and done BMW "coding" (NCSExpert) on my E85 Z4 but all this iDrive stuff is new to me!
      02-02-2020, 10:23 AM   #2
smass
398
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
The controller will be a simple swap however you will need new console trim which is not cheap. The CIC controller just adds a few shortcut buttons. It does not add additional functionality.
Map upgrade links are in this same forum. Research how to create a FSC code and download maps to the usb.
SSD upgrades provide a minimal performance increase. If your hard drive goes bad, go for it. Low cost IDE SSD are now available and there is no longer a need for adapters.
      02-02-2020, 12:43 PM   #3
Jakg
Drives: 335d
Thanks - is it a straight swap? Or coding needed too?
      02-04-2020, 09:59 AM   #4
smass
398
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
Coding is not needed. I did get one where the software was much older than the CIC so I had to flash it with winkfp. But that is not normal.
