01-31-2020, 02:15 PM | #1 |
15
Rep 31
Grinding noise when reversing with AutoHold
Hi fellow BMWers,
I am a new BMW owner for only 2 weeks, mine's a BMW 320i G20 M SPORT, this is my first auto car so I am still getting used to it. Everything seems fine except this one small thing, I noticed that whenever I put the gear in R and start pressing the pedal, the car would make a moderate grinding noise (similar to that noise you hear when start driving after car wash/rain). Sometimes the noise also occurs when I start the engine and start turning the wheel. After I start driving the noise will go away, no noise e.g. after waiting for a red light. This only happens when the auto-hold is on, if I turn off the auto-hold feature and do the manoeuvre (e.g. reversing) the noise also went away. Is this normal? Last edited by newway; 01-31-2020 at 04:01 PM.. Reason: typo |
01-31-2020, 04:02 PM | #2 |
6659
Rep 15,858
Is this on a very slow move off, as if the brakes are still partly engaged?
What if you are a bit quicker to move, still the same? |
01-31-2020, 05:59 PM | #3 |
15
Rep 31
02-14-2020, 06:51 AM | #5 |
X3M Comp is a beast
89
Rep 171
Mine tends to lock up the rear brakes when its cold out. I can put it in gear and it just sits there until I give it gas to break the brakes loose. I hope that is normal.
02-14-2020, 08:56 AM | #6 |
247
Rep 465
I think this is movement in the opposite direction when the parking brake is applied to the rotors.
Happen to me a few times in a huracan I left the parking brake on and tried to reverse. So im sure its the same concept |
02-14-2020, 09:20 AM | #7 |
Petrolhead
1943
Rep 3,521
It’s normal. All my cars do it when it’s freezing outside.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
11-24-2020, 04:31 PM | #8 | |
15
Rep 39
I have this issue when switching from R to D makes like a grinding noise , think it's the electronic handbrake |
11-25-2020, 03:40 AM | #9 |
6659
Rep 15,858
01-31-2021, 03:25 PM | #10 |
15
Rep 39
So when I switch from D to R the electronic handbrake isn't on . However if I engage the handbreak manually and then do the D to R no sound. So like you said the auto hold is forcing against the brakes but it does sound awful and still not right
Tags |
autohold grind grinding |
