01-29-2020, 11:44 AM | #1 |
2684
Rep 7,300
BMWPartsPros.com l BMW OEM RETROFIT CHARGING DEVICE
Replace your non-rechargeable tray with the BMW OEM retrofit charging tray. Eliminate cords in the center console area to charge your phone. Easy DIY install with a quick plug and play. LINK:https://www.bmwpartspros.com/oem-par...MtMGwtbDYtZ2Fz Last edited by PARTS@STBMW; 12-28-2022 at 12:57 PM.. |
04-07-2020, 01:05 PM | #3 |
2684
Rep 7,300
Hello and thank you for contacting BMWPartsPros!
Looks like our back-end changed it on its own, but the item is still available to order. I have changed it and the link has been updated. Thank you, -Britney |
05-13-2020, 01:25 PM | #5 |
2684
Rep 7,300
11-18-2020, 05:10 AM | #6 |
Rep 7
Drives: BMW 330i M Sport
I'm looking to buy this for my 330i to swap out my NFC Reader. It mentioned "Hardware Required". Is there a part # or link to the hardware I need?
**Edit: are there also published install instructions? Thank you! |
11-18-2020, 02:30 PM | #7 | |
2684
Rep 7,300
BMW upgraded these charging trays over the last couple of months, so no additional hardware is required anymore. Unfortunately, this does not come with instructions but can be found on YouTube. -Brit |
BOS_BSM_G203.00 |
09-18-2021, 10:07 PM | #8 |
51
Rep 104
Drives: M4
Interesting in buying but I'd like to look at the pdf instructions. I don't see on your site. I have a 2022 M340xi that didn't come with NFC or Wireless tray.
09-20-2021, 02:38 PM | #9 | |
2684
Rep 7,300
This charging tray is unfortunately not available with a PDF instruction manual since it is considered a "retrofit" for your model. Many clients of mine have upgraded this charging tray on their models by watching YouTube videos on how to install. -Brit |
03-01-2023, 12:14 PM | #11 |
2684
Rep 7,300
04-22-2023, 01:49 PM | #12 |
Rep 3
I am attempting to do this on a G23 but the factory NFC tray seems to be anchored to the car some how. I was able to lift it only about 1mm... is there a secret here that I am missing? edit- there are two tabs that you have to pull considerably towards you.. they dont SEEM to do anything but if you pull both AND push up on the whole unit, it will lift out easily
