Bimmerpost
4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Maximum 330e charging rate with granny cable?
      01-28-2020, 05:17 AM   #1
Chuckyarla
Ireland
298
Drives: G11 730d M-Sport 2018
What's the highest rate that's advisable to use with the granny cable? Is 13amp ok or is it best to stick with 10amp?
      01-28-2020, 08:29 AM   #2
Quervo
Drives: E90 325I,F30 330E, G20 330e MS
The max rated amperage from a domestic supply in Ireland is a notional 13 amps, but its unlikely anything in normal usage draws that much. If you use the IV=P formula, 13*220=2860W. That's equivalent of almost 29 100W bulbs.
I'd reduce to 10amps max or get an electrician to install a dedicated outdoor socket direct from fuseboard with an RCD. Do not use an extension lead as electrical fires are a real danger in my opinion.
      01-28-2020, 10:49 AM   #3
joselrl
Portugal
33
Drives: BMW G20 330e 2019
The cable that comes with the car has a max output of 10A. You can buy a 16A one but make sure your house wiring/electrical box/plugs support it.
If you want 16A in your garage or something I would go for a wallbox honestly it's mote expensive but you coule already future proof with a 7.2kw or higher charger
      01-28-2020, 11:00 AM   #4
Quervo
There's a €600 SEAI grant available in Ireland to install a home charger, you have to have off street parking though.
I take about 4 hrs to fully charge car from a 3.6Kw home unit also the morning pre-heat is completed with no loss of range.
      01-29-2020, 02:09 AM   #5
Chuckyarla
Ireland
298
Thank you for all that info.
      01-29-2020, 02:31 AM   #6
wassap
wassap's Avatar
86
Drives: Volvo
Ive seen the wall boxes available on ebay for a couple of hundred aswell.
g20
