01-25-2020, 05:02 PM | #1 |
1861
Rep 2,554
Bucking in 1st
Hey all. I've noticed lately when I pull out of the garage and the cars stone cold, when accelerating on my driveway in first it seems to cut and add power in a surging form. Basically the only way to stop it is to clutch in and just grab second. Doesn't seem to do it on the road just under light acceleration in my driveway and only when the cars cold. Any ideas?
Car is a 335 6MT |
01-25-2020, 05:07 PM | #2 | |
160
Rep 741
but once the car is warm its fine, i just figured the car needs to be warm and problem solved....but it is worth mentioning before i did any kind of modifications i never had this issue. i have the 8 AT..
2016 435i xDrive F36 M Sport - ER CP | ER Catless DP | VRSF 5" FMIC | bm3 stage 2 93 oct | black double slotted grill | AWE axle back exhaust w/102mm diamond black tips | 437m wheels
01-25-2020, 05:09 PM | #3 | ||
1861
Rep 2,554
01-27-2020, 10:27 AM | #4 |
12
Rep 54
Same issue during a cold start. I believe (correct me if I'm wrong) the car idles at 750 RPM during a cold start. Once the engine warms up, it should drop down by ~200-300 RPM and you should be clear to take off. During the cold mornings in the east coast, I turn my car on and let it idle for about 5-10 minutes while I pack my breakfast/make coffee and it doesn't buck and isn't jumpy.
01-27-2020, 10:30 AM | #5 | |
1861
Rep 2,554
01-27-2020, 11:35 AM | #6 |
94
Rep 184
My bone stock 320i with 8AT does the same thing. Only does it once after backing out of garage and starting up the driveway. There's a stop sign about half a mile down the road and it never does it there. Only in the driveway.
I've also never tried letting it warm up first. Will give it a shot and see. |
4dirty512.00 |
01-27-2020, 11:46 AM | #7 | |
12
Rep 54
Curious, how long do you let it sit before driving off? |
01-27-2020, 12:00 PM | #8 |
11
Rep 16
I had same exact issue. 335i 6mt stage 1 tune. When cold in 1st car would surge forward like I forgot how to drive stick. Only happened when cold and in 1st. I had learned to live with it. Then my battery went out. After I changed my battery the surge completely went away. This was almost a year ago, it's still good.
I can't explain how or if the 2 are related but It's still not surging. |
01-27-2020, 12:07 PM | #9 | |
1861
Rep 2,554
01-27-2020, 12:19 PM | #10 |
11
Rep 16
I knew my battery was on it's last legs b/c it was taking a little longer to crank. The surging was happening more and more- even when the car was sitting for a couple hours. After I changed my battery and pushed the start stop I was like "damn that turned over super quick." Guess I got so used to the old battery haha.
Anyway- keep us updated. |
01-27-2020, 03:42 PM | #11 |
Respect My Authoritah
368
Rep 873
Same issue tuned with BM3. JaredG_F30 determined that a throttle recalibration fixed his issue. I tried it and it seems to work!
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
01-27-2020, 03:44 PM | #12 |
1861
Rep 2,554
Was thinking of dropping the Dinan tune for BM3. Just have to go through the haste of disconnecting everything. To be honest i May just take it to kies motorsports in Jersey to have him do it all. Cars equipped to run stage 2 so that would be sweet
01-27-2020, 04:26 PM | #13 |
95
Rep 279
My bet is battery is about to give up the ghost. I had exact same issue and my battery died a few months later. New battery fixed up cold start bucking and other odd issues. (I was tuned as well.)
13' F30 335i - BMS Intake -- VRSF DP -- VRSF CP -- VRSF 5" Stepped Intercooler -- Corsa Touring Catback -- JB4 -- H&R Springs -- Miro Flow Formed F25's
01-27-2020, 04:34 PM | #14 |
1861
Rep 2,554
01-28-2020, 06:13 AM | #15 |
BMW CCA 69606
86
Rep 227
What's the date code on the battery?
Connect laptop w/ISTA and read the state of charge of the battery. This is easy to confirm or rule out. Put a 10 amp charger on battery overnight. |
01-28-2020, 10:41 AM | #16 |
1861
Rep 2,554
I will check. I did an overnight charge last week and within a day it went back to a slow crank. And OB2 reader I attached claimed it's max potential charge was like 57% or something. I'm just going to grab a new one. It wasn't really a priority because the car is not daily driven and it sits in a warm garage yanno so I Never really experienced cold weather starts
01-28-2020, 11:04 AM | #17 | |
BMW CCA 69606
86
Rep 227
If you get the chance, try the charger again and see if the driveability issue disappears even if only for (1) drive. |
01-28-2020, 11:05 AM | #18 | ||
1861
Rep 2,554
01-28-2020, 11:05 AM | #19 |
421
Rep 842
I keep my Miata - another non-daily usage car - on a “float” charger. This type puts a small current into the battery WHEN NEEDED and shuts off until another small charge is needed.
01-28-2020, 03:20 PM | #20 | |||
93
Rep 338
2013 320ix N20 8AT|BM3 stg1|Muff Res Delete|HPB-LED-Amber-DRL's
IG: DadzBmer_N2o |
01-28-2020, 03:24 PM | #21 |
Stance to make her dance
711
Rep 2,004
I have noticed this happening more frequently in the colder months. Same thing though - I start the car, pull out of the garage and down the driveway, then the surge starts as soon as I take off. Theres a stop sign at the end of my street and it doesnt happen when I take off from that stop. So its just initially when its a super cold start. I think the car just needs to warm a little. My car is completely stock motor, no tune etc. just a BMW MPPK.
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2022 G80 M3 6MT, FEMTO, BM3, KW, AWE, MAD, lots of carbon |
01-28-2020, 03:26 PM | #22 | |
1861
Rep 2,554
