Transmission issue
01-24-2020, 01:57 PM | #1 |
2341
Rep 3,542
Transmission issue
Fellas,
2007 335i E92 RWD with ZF Automatic Transmission GA6HP19Z I have replaced transmission pan, oil, 4 sleeves, square adapter in September 2018. Issue: - For the past month, whenever i try to accelerate i hear a hollow whirling sound which is immediately followed by a jerk and partial loss off power. - I have to let go of the gas, let the rpms drop, and then accelerate again. - Seems to be happening in 4th to 5th gear, only when it goes over 2000 rpms on heavier acceleration. If driving lighting/moderately no issues are presented. I'm searching but i am not seeing this characteristic described anywhere. Car was scanned at the shop with following codes: (Printer was no good as you can see streaks all over) 0029F3 DME: Fuel low-pressure sensor, electric 002A12 DME: DMTL solenoid valve, activation 002A13 DME: DMTL leak diagnosis pump, activation 002A18 DME: DMTL heater, activation 004F82 EGS: Ratio monitoring, clutch B 005DBC DSC: Hydraulic unit: pressure sensor, plausibility 005DCC DSC: Hydraulic unit: Pressure sensor, plausibility 00A6CF JBE: AUC sensor Potential causes I would suspect: Solenoids, brass bushings, clutch plates I would appreciate some of your knowledgeable feedback. Thanks. Last edited by Wolf 335; 01-27-2020 at 08:04 AM.. |
01-24-2020, 06:30 PM | #4 |
28
Rep 222
Hi I experienced something similar on my 2007 335i when i would accelerate I would sometimes get a jerk and a hollow whistle type sound. Ended up carrying out a transmission service had the oil changed and all has been good over a year now. Hope this helps
01-24-2020, 07:46 PM | #5 |
2002
Rep 3,731
Use xHP to scan for transmission codes. Then shoot an email to ZF tech service and ask them what the codes mean, and tell them what it's doing. ZF is great about getting back to you..they can point you in the right direction.
Wolf 3352340.50 |
01-27-2020, 07:59 AM | #7 |
2341
Rep 3,542
01-27-2020, 08:00 AM | #8 |
2341
Rep 3,542
01-27-2020, 09:39 AM | #12 |
2002
Rep 3,731
One of the codes mentions solenoid function. The next thing I would do is pull out the valve body, and change all of the solenoids. My transmission is acting up.....and I'm getting ready to do the same thing. You can buy the new OEM ZF solenoids for around $200-ish for the whole set on eBay.
That's the cheapest thing you can try.....after that you are talking a new valve body and/or rebuild.....around $2,000+. Also, have you tried emailing ZF tech service with the info and codes? They are good about replying with info for you. |
01-27-2020, 10:09 AM | #13 | |
611
Rep 1,272
Not saying replacing the solenoids won't help. Just clarifying that is a complete misread of the code, and nothing in the codes points directly to the transmission solenoids. |
01-27-2020, 10:50 AM | #14 |
2341
Rep 3,542
iqraceworks, as relative4 mentioned, that solenoid code is for something else. It doesn't pertain to transmission.
I have just emailed ZF, we will see what they have to say. |
01-27-2020, 11:04 AM | #15 | |
2002
Rep 3,731
On a side note....when you checked the fluid level, was the transmission at the proper temp? 40c I believe is what they say is the correct temp to check it at, but I would double check that. Also....what ATF fluid are you running in it? ZF Lifetime fluid, or something else? |
01-27-2020, 11:31 AM | #16 | |
2341
Rep 3,542
01-27-2020, 02:42 PM | #17 |
204
Rep 525
subscribed. I sometimes have this exact issue. Just replaced solenoids and didn't fix it (already done a couple fluid changes with pan/filter, mechatronics sleeve and 4 seals). Shifts fine in manual mode, and in auto mode with very light or heavy throttle. It's only when it tries to do a "soft" shift that it can't grab 5th gear and the RPMs flair up.
01-27-2020, 02:52 PM | #18 |
128
Rep 256
01-27-2020, 02:54 PM | #19 | |
128
Rep 256
01-27-2020, 03:59 PM | #20 | |
204
Rep 525
Besides replacing the tranny, I suppose I have 2 remaining possible fixes: rebuild the valve body in case it's a ball valve, or dig into the gear train. Ugh. |
01-27-2020, 06:02 PM | #21 | |
128
Rep 256
Get some PD clutches and bushings at a minimum. I'll be posting up a guide soon enough, but there are plenty of vids on youtube on tearing down 6hps. Messy, but not very difficult if intact. |
IllSic_Design2124.00 |
01-27-2020, 06:27 PM | #22 | |
2341
Rep 3,542
If it is pressure related I’m assuming then it’s solenoids, correct? |
