Exhaust flap controller
01-23-2020, 05:48 PM | #1 |
Rep 31
Question for anyone who has created a diy flap controller, my control works fine when I turn the car on no problems with opening and closing the flap but while driving I can hear the vacuum activating.
Had the flap closed before driving and then I parked and went outside to see if I could hear the flap open when I pressed the open button, but the flap was already open and my control was not working. After turning my car off and on it was working again. I have my relay set to be closed on startup. |
01-23-2020, 07:03 PM | #4 |
2002
Rep 3,731
It's got a button to open and close the exhaust flap?
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
01-23-2020, 07:57 PM | #7 |
Rep 31
Pretty sure the exhaust flap is set by default to open at a certain rpm and the control works fine at at start up until I start driving, if there was a vaccum leak wouldn't the exhaust flap not work at all?
01-23-2020, 09:36 PM | #8 |
45
Rep 52
on my 09 the flap is closed on cold start, when it warms up the flap is open at idle. It only engages (closes) around 1.5-2k rpm when you start driving. It then opens again around 4k+ rpm.
It's not permanently closed or open when controlled by your car. That's why when you stopped and tried to open it, it was already open. Normal operation for it |
01-24-2020, 12:15 AM | #10 |
Rep 31
Golf tee mod doesn't solve my problem, also refer to my op that says this is a question for people who have done the same thing I have. I appreciate tbe input but its clear you don't know what im talking about.
01-24-2020, 12:19 AM | #11 | |
Rep 31
What I have now is a valvetronic type controller but I made it myself. Its supposed to stay open when I open it and closed when I close it. I plan to get a drivers side muffler delete to basically duplicate a valvetronic exhaust but at a fraction of the price. I have full control over my flap with a wireless remote but its not working properly while I drive thats why im looking for someone who possibly knows why its not working properly. |
01-24-2020, 08:31 AM | #12 |
449
Rep 823
I did exactly what you're describing on my E60. I gutted one of the mufflers and wired a switch to the flap. It works perfectly. If I were to guess why yours isn't working properly, I would say you tapped the wrong wire for the solenoid, or you didn't run the switch to a constant +12V source. I can't remember exactly what I had to do, but 1 of the 2 wires going to that solenoid gets switched on and off by the car's normal operation. So you've got to cut that wire and run it to a constant +12V source, with your switch in between to control it. I used a 12V accessory socket in my trunk. Does this make sense? Forgive me if this is exactly what you've already done. I just can't imagine anything else causing your issue.
01-24-2020, 08:49 AM | #14 | |
Rep 31
01-24-2020, 08:58 AM | #16 |
641
Rep 1,245
The stock valve defaults open when you shut the car off, only vacuum will close it.
So when you start the car, it will be open and if you have a controller for it, youll have to close it if you want it shut. Very annoying. Ill be swapping to a default closed valve eventually on mine so itll be shut for cold starts and I can open it when I want only.
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50 11.61 @ 117.5 New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets |
01-24-2020, 08:50 PM | #17 |
Rep 31
01-26-2020, 08:28 PM | #19 |
449
Rep 823
Sorry I took an extra day. I just wired up mine and it's backwards from what I thought. The red wire to the solenoid gets +12V constant and the white one is switched on and off with -12V. So, to get complete control you've got to cut the white wire and run it to your own switch that's connected to ground. I think the key here is to make sure that white wire is severed from its factory connection.
I did just noticed you mentioned using a relay in your original post. Depending on how it's set up, that could also be your issue. I didn't use a relay since the solenoid isn't really pulling much current anyway. |
01-26-2020, 09:00 PM | #21 |
2440
Rep 4,330
bird shit still holds.
what did you weld it with? i'm 50/50 on buying a stock muffler on ebay and cutting it up. is it mild steel that the shell is made of? |
01-26-2020, 09:11 PM | #22 |
449
Rep 823
I used my Harbor Freight flux core welder. The shell isn't magnetic, so I'm assuming it's stainless? I used the same cheap flux core wire I use for all other steel work (that makes it sound like I actually weld regularly, which it's quite apparent that I don't). In the absence of a decent bi-metal saw blade, I used a cut off wheel for all the gutting. Wouldn't recommend it as it was so much more work.
