No Heat or AC
01-22-2020, 07:58 AM | #2 |
107
Rep 202
I have a perpetual 9C53 code that won't go away and it indicates a fault with the electronic heater booster. Doesn't effect the rest of the climate control system though and I'm in no hurry to fix it as I don't live in a cold enough climate to care about having a functional heater booster.
When you say "nada from climate control system", do you mean the entire unit has gone dark? If so, check your fuses. I can't remember which fuse it is specifically, but I once blew it by accidentally shorting a lead to ground when changing the trunk compartment interior light bulb. Apparently interior lighting and the climate control system share the same fuse.
BRR Tuned
01-22-2020, 09:13 AM | #3 | |
274
Rep 1,054
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
01-22-2020, 08:23 PM | #4 | ||
671
Rep 1,442
01-22-2020, 09:20 PM | #6 |
765
Rep 3,556
Hi Chief - I had to take my full delete car into dealer for FRM module replacement. The good news was they did the work for free. The bad news was they reprogrammed my ECU and I had to get it reflashed by tuner. I would think a heater repair wouldn’t involve programming a module. But, it is a BMW. Good luck.
04-29-2021, 12:31 PM | #8 |
177
Rep 180
I have the same code but everything works apart from hot air it's warm at best. Anyone know what it is I'm taking the car apart to check the actuators but it's very tight to get them out and have almost quit as I don't want to take the whole dash out.
