Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Oil on chargepipe going into the EGR and oil in EGR cooler connecting to EGR.
      01-16-2020, 04:27 PM   #1
bmwdiesel
14
Drives: 335d 2007
basically I had intake off couple of times in the past week and now when I was taking it off, the oil was on the inner edge of a charger hose connecting to EGR and oil was also on the end of EGR cooler that connects into EGR. I dont remember there being oil before. I took few pipes around turbo out otherwise I was just fixing vacuum hoses, any idea what could cause it? and btw, I only started a car stationary which caused that oil leaks....
      01-18-2020, 01:07 PM   #2
bmwdiesel
14
Drives: 335d 2007
I did some reading and it gets oily, when either breather releases the oil through the air pipe 13717796370 to the turbo, or the turbo seals are leaking....
I checked the breather and it is dry.
What I did was I took off intake manifold to check vacuum hoses, and replaced some that were split at the ends. I connected all as they were supposed to be one by one.
I left opened turbo when I removed the air pipe 13717796370 for a few days while I was working on it, could something fell there am thinking??
so after I finished those vacuum hoses I started the car and let it run 10 minutes since it's cold then I wanted to drive and it was still weak I could feel it and brake pedal was stiff, so it lost vacuum that it had before...
I switched off the engine, went to re check all vacuum hoses and they were connected fine and also checked the diagram, all good.
then I went take off the intake and I noticed EGR cooler pipe, Black Charger hose and EGR valve were covered in fresh oil, but they were never oily before.....so what could happen??? Could I do something wrong? by taking out air pipe, intake ? I am clueless...
re vacuum, I didnt found any leak, but by accident I did another smoke test from the EGR vacuum hose and could see the small amount of smoke coming from the side of vacuum pump, but I dont think it's the main leak, or could be?? because I am sure it has been leaking for some time due to vacuum pump being covered heavily from oil and it had vacuum before. I am lost at this stage. lost all vacuum and oil appeared in intake charge hose...from bad to worse
      01-19-2020, 09:10 AM   #3
Mik325tds
Mik325tds's Avatar
806
Drives: 335d M-Sport
Some amount of oil in the charge pipe is normal as the PCV releases oil into the intake. But the amount of oil you are describing seems a bit excessive.
Your vacuum problem could have several reasons: A cracked reservoir or faulty vacuum pump. With what you're describing I'd start looking at the vacuum pump.
ddinse4.50
      04-21-2020, 11:26 PM   #4
DougNBodie
DougNBodie's Avatar
27
Drives: BMW 335d M Sport
2011 BMW 335d  [10.00]
I know BMW's "EAT" oil and that BMW actually has a guild on proper oil consumption amounts. I'm not sure what they are but it's a good thing to know. My M57 consumes about 1.5 l. of oil between oil changes at 7,500 miles and I've heard that is very light.
      04-22-2020, 11:07 AM   #5
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
There is a seal on the vacuum pump that AAR offers in his VCG kit. Pump might be okay but loosing oil there possibly from the seal. I need to reach out to him for the VP seal. Unsure if sold separately or only in the VCG kit.
      04-22-2020, 07:22 PM   #6
apexit4
Poland
1231
Drives: 335D M-Sport, X5D
Not sure if AAR sells one separately, but I just ordered one from FCP Euro with my last oil change supplies.
      04-22-2020, 07:23 PM   #7
apexit4
Poland
1231
Hmmm, that's interesting. The M57 in my 335D doesn't burn any between oil changes of 5000 miles.
