Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin Synthetic Oil?
      01-15-2020, 09:11 PM   #1
TheRetroGuy
148
Drives: 2020 330i xDrive mSport
Synthetic Oil?
Do BMW dealers use strictly synthetic oil for the G20?
      01-17-2020, 07:03 AM   #2
TheRetroGuy
148
Foolishly, I posted that question thinking it was an easy question; is the answer to this one nebulous among BMW owners?
      01-19-2020, 10:08 PM   #3
ByronWalter
90
Drives: 2023 M340i xDrive
They better be using full synthetic as it's what BMW calls for.
      01-19-2020, 10:42 PM   #4
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
I’d be extremely surprised if they were using mineral/conventional oil!
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      01-20-2020, 10:37 AM   #5
TheRetroGuy
148
Does the owners manual specify that? I tried to view the owners manual for my VIN (still being manufactured) and it wasn't available yet.
      01-20-2020, 10:39 AM   #6
TheRetroGuy
148
That was my thought too, but then I read about folks changing oil at 5,000 miles, where most oil analyses I've seen show not much difference on the condition of synthetic at 5k miles.
Is there somewhere online I can read about specifics around oil changes for the 2020 330i? My car is being built so no owners manual yet.
      01-20-2020, 10:54 AM   #7
IndotagSwizz
IndotagSwizz's Avatar
525
Drives: F30 320i
Of course they do, cmon man, I can guarantee you 100% that they use the correct oil
      01-20-2020, 11:52 AM   #8
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Well yes. If you strictly change oil every 5k miles, I don’t think it matters much if you use synthetic or mineral. But BMW claims oil changes at 10k miles? I’d definitely stick to synthetic then.
Current:
      01-20-2020, 01:41 PM   #9
TheRetroGuy
148
Sure, I was assuming dealers use the correct oil, but my question is really asking (in part) what the "correct" oil is for these cars. Admittedly, my wording of the question wasn't optimal - I was trying to keep it simple.
Better wording would have been:
1. Does BMW recommend synthetic for all G20 cars?
2. Do dealers always put synthetic or do they cheap out during free maintenance period
Apologies for confusion / laziness on my part.
      01-20-2020, 01:42 PM   #10
TheRetroGuy
148
I thought that's what I had read elsewhere in this forum (10k). I know Lexus started doing synthetic 0w20 with 10k recommended change in their cars.
      01-20-2020, 05:23 PM   #11
IndotagSwizz
525
Drives: F30 320i
The correct oil is the one specified in the sticker under your hood, and bmw puts that exact oil in your car they don't cheap out
      01-20-2020, 05:26 PM   #12
IndotagSwizz
525
Drives: F30 320i
I don't understand what's so hard to understand, you should always put the oil that is specified in the sticker under your hood, so if it's specified synthetic you use synthetic why would you ever use a different oil?? The engine is made specifically for that exact oil, there are certain passages thru the engine where different viscosity of oil simply wont get thru as fast or get thru at all
      01-20-2020, 07:23 PM   #13
TheRetroGuy
148
Did you happen to notice my car listed with my name? Car is still on order, so I cannot see the sticker yet. I said nothing about wanting to use a different oil.
      01-20-2020, 07:38 PM   #14
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
I thought OP was asking whether the dealership actually uses synthetic oil or not. I know many places where they claim to use synthetic oil but it’s actually semi-synthetic or even mineral oil (and they bill you for fully synthetic oil). I didn’t think he meant he wanted to use conventional oil in place of synthetic oil.
And, I think, more than whether it’s synthetic or mineral oil that an engine “needs”, it’s the viscosity that matters. Why do I say that? The first car I ever owned (back in 2008) came with mineral oil from the factory and they used mineral oil for a few years before switching over to fully synthetic oil. But I’m no expert. That’s just what I think and if anyone can prove me wrong, I’ll definitely update my knowledge and be thankful. I don’t know if you can get mineral and synthetic oil with the same multi grade viscosity (I assume you can but again, I could be wrong, since this isn’t my area of expertise).
Current:
      01-20-2020, 07:43 PM   #15
TheRetroGuy
148
I'm just grateful someone fully read and understood my post
Yes, you've got a good grasp on what I was asking. In some of the second gen Lexus IS engines, there was a problem with carbon build up and a recall with corrected engine design, but it also came to light that the ones who never had the carbon build up were the ones running synthetic. By the third generation, Lexus was putting only synthetic 0w20 from day one.
But, those are naturally aspirated engines. I wasn't sure what the scoop was with the newer turbo charged 4 cylinders; just trying to learn as much as I can about the car before mine is delivered.
      01-20-2020, 07:49 PM   #16
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
I can assure you that that’s exactly why they switched over to fully synthetic in my first car too (though it was a Hyundai with a measly NA 1.0l engine (yes. 1.0l)). Carbon build up causing issues.
Current:
      01-20-2020, 09:30 PM   #17
ByronWalter
90
You will also find the correct oil specs in your manual. That's where I found it. Also when you pick up your car, get them to give you a spare liter (or pay for it if you have to). Just make sure it's the proper one for your car. My service person tried to sell me the wrong grade so I asked him to look it up, which he did, and that did the trick... but why he wouldn't know that is a mystery to me.
      01-21-2020, 07:14 AM   #18
TheRetroGuy
148
Thanks, that's a good idea. I'm making notes on things I plan to ask when I take delivery. Also occasionally tracking the production process to see if it will allow early access to the online owners manual (site says not ready yet).
      03-29-2020, 09:36 PM   #19
F32Fleet
F32Fleet's Avatar
3566
Drives: 2015 435i
Dealers use the BMW TPT in whatever weight is required for your vehicle. This oil is a "synthetic".
Due to the fact that the majority of sales are leases and maintenance is included in combination with the long interval BMW dealers can't get away with using the inappropriate oil. They would have a hard time explaining away sludged engines when they have on record all of the required oil changes.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      04-04-2020, 02:38 PM   #20
TheBingoBalls
TheBingoBalls's Avatar
3817
Drives: BMW
I have no idea why people are skeptical of the oil/fluids BMW uses - the dealership and/or BMW has nothing to gain from not using what they recommend especially if most cars are leases.
I'd be more concerned if they even did the work but if they do, I see no advantage of not using what BMW recommends especially if you work at a BMW dealership that provides you everything from BMW.
F32Fleet3566.00
      04-04-2020, 11:14 PM   #21
F32Fleet
F32Fleet's Avatar
3566
Drives: 2015 435i
I've heard dealers of other makes (I.e. VW) use whatever bulk oil they can buy, but BMW is a different animal.
      04-05-2020, 10:04 AM   #22
TheBingoBalls
3817
Drives: BMW
Which is weird because I'm sure companies like VW (and subsidiaries) all have parts volume bonuses so if you're buying fluids from VW to get those bonuses and don't use them, where do they go and what's the point? But like you said, BMW is a different animal if only for the fact of the no-charge maintenance and that they have strict purchase targets for the parts department.
g20
