Rotor Set Screw Disaster
01-10-2020, 06:53 PM | #1 |
Aspiring 1'er
78
Rep 534
So had a good day today and decided to do brakes real quick. Had brakes off in 10 minutes, but unfortunately my rotor set screw stripped. I played with it a bit and then decided to grab an extractor set. the extractor I chose then decided to snap . So I shaved her down so I could get wheel and rotor on as the set screw serves no more purpose other than to keep the rotor in place. Anybody have any ideas on what I can do to fix it? My plan is really just to find someone who can weld it out at this point as I cant even get a drill bit through the extractor tip, but any advice is appreciated.
01-10-2020, 06:59 PM | #3 |
2124
Rep 2,758
I would have probably just drilled the head off first before trying to use the extractor, but yeah I'd say welding a nut/bolt to it is your next best bet.
01-10-2020, 07:09 PM | #4 |
Aspiring 1'er
78
Rep 534
So first thing I did was in fact just drill the head off. That allowed me to get the rotor off. Ironically enough, I was able to get some movement out of the set screw before it stripped. Unfortunately it wasn't loose enough for me to get any further movement out of it I guess, and that brought me to the extractor route.
IllSic_Design2124.00 |
01-10-2020, 07:14 PM | #5 | |
2124
Rep 2,758
01-10-2020, 07:16 PM | #6 | ||
Aspiring 1'er
78
Rep 534
01-10-2020, 07:51 PM | #7 |
2197
Rep 1,322
leave it until you need new rotors, then just be annoyed putting the new rotor on without having a screw to hold it in place. Then just deal with it when you eventually need a wheel bearing in 100k.
01-10-2020, 08:02 PM | #8 |
Aspiring 1'er
78
Rep 534
Haha yeah that's the likely outcome. Just hate the idea of the rotor being loose everytime I take wheel off.
01-10-2020, 08:08 PM | #9 | |
2197
Rep 1,322
If you really cared a good machinist could put it in a press, drill out the center of the screw, and probably clean the threads out. but unless its a buddy doing it pro-bono honestly Id just proactively put a new bearing in. The hub/bearing combo is like $120. |
Efthreeoh17365.00 |
01-11-2020, 09:18 AM | #10 | ||
Aspiring 1'er
78
Rep 534
01-11-2020, 09:19 AM | #11 |
2440
Rep 4,330
01-11-2020, 09:22 AM | #12 |
Aspiring 1'er
78
Rep 534
Good to know, I'll likely do the stud conversion anyways though 🤣
01-11-2020, 09:27 AM | #13 |
2440
Rep 4,330
01-11-2020, 10:02 AM | #14 |
Aspiring 1'er
78
Rep 534
I understand it still wouldnt be tight per say, but having something for the rotor to rest on is good for me. I frequently swap wheels anyways so studs are something Ive needed.
01-11-2020, 10:17 AM | #15 |
54
Rep 139
If it's the front rotor, I would remove the wheel bearing and try drilling it out from the back.
If the screw is already loose, it may spin out when the drill bit grabs into the metal.
Yngvejos.
2005 E91 325i |
Efthreeoh17365.00 |
01-11-2020, 10:19 AM | #16 |
Aspiring 1'er
78
Rep 534
Not a bad idea as well; will consider it later today. Just the 4 bolts that hold it on right ?
01-11-2020, 10:22 AM | #17 |
54
Rep 139
Just 4 bolts. Remember to remove the wheel speed sensor first to prevent damage to the sensor.
Yngvejos.
2005 E91 325i |
01-11-2020, 10:27 AM | #18 |
Aspiring 1'er
78
Rep 534
01-11-2020, 12:28 PM | #19 |
17365
Rep 18,762
Just drill through it with a 1/4" twist drill. The threaded hole it sits in is a thru-hole through the hub flange. It's really not that critical.
That said, after many years wrenching BMW brakes, I've learned three things about the rotor screws: (1) even if you buy a new BMW, first thing is remove the wheels and remove the rotor screws and apply anti-seize to them, then reinstall; (b) get new rotor screws when you do a brake job; and (c) do not use a cheap-ass L-bar Allen wrench, use a T-wrench, or better yet a butterfly impact air-wrench.
01-11-2020, 12:39 PM | #20 | ||
Aspiring 1'er
78
Rep 534
01-11-2020, 12:42 PM | #21 | |
Is it the shoes!?
3884
Rep 5,112
Use a little bit of anti-seize to help it stay on the hub and you shouldn't have much of an issue reinstalling wheels. |
01-11-2020, 12:43 PM | #22 | ||
Aspiring 1'er
78
Rep 534
Efthreeoh17365.00 |
