BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > CIC UPDATE on 2011 Alpina D3 Biturbo E91
      01-02-2020, 08:25 AM   #1
RichG25
RichG25's Avatar
Drives: Alpina D3 Biturbo E91
Hi Im trying to update the CIC on my 2011 Alpina D3 Biturbo E91 as when I connect via bluetooth to my Samsung S8+ no song data or DAB data is shown on the screen, although strangely a couple of times it has?
I've downloaded UPD01008.bin to a FAT32 formatted memory stick and plugged it into the USB drive in my glovebox as I don't have one under the armrest, just an AUX port and cigarette lighter. I've gone into settings but software update does not appear. I've noticed that if I go into BMW Services>Service Status>Update BMW Services and go back into Settings, software update appears but won't actually let me start the update. Once the BMW Services Update has finished the software update option disappears in the settings menu
Nearly all instructions say to use the armrest USB but as I dont have one there is there an alternative way? Any ideas please?
Cheers
      01-02-2020, 09:52 AM   #2
opjose
opjose's Avatar
242
Drives: 335xi
Have you checked to see if you have a Combox?
If not, which is likely, you cannot stream music over Bluetooth.
The .bin file does not upgrade the CIC, it merely updates the USB recognition tables so that the USB interface (mulf?) knows how to talk to newer devices.
      01-02-2020, 11:10 AM   #3
RichG25
RichG25's Avatar
Hi opjose, the Bluetooth works absolutely fine as, far, as listening to music and telephone calls etc it's just the data foe each album, song, dab radio station isn't present. I just get an unknown displayed on the screen. How do i check for a combox please?
Cheers
      01-02-2020, 01:30 PM   #4
smass
398
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
The screen shows teleservices update. I think that is an over the air update and not a USB one. In the US, older tele-services devices no longer connect to the servers as they are obsolete. You may want to try to disconnect the bluetooth devices and see if you can get that one to kick off.
A combox will be in the trunk under the floor cover close to rear seat edge. Post pictures of what you find including the connectors. I am curious if anything is plugged into the round USB connector
      01-03-2020, 05:30 AM   #5
RichG25
RichG25's Avatar
Ok so having looked in my boot/trunk this is what I found......
      01-03-2020, 05:32 AM   #6
RichG25
RichG25's Avatar
It's also been mentioned that I may have to install older updates to enable me to install the latest one, is this correct please?
Cheers
      01-03-2020, 06:52 AM   #7
RichG25
RichG25's Avatar
Having checked it seems my usb ports aren't being used on the combox, am I able to simply buy an aux/usb socket and connect to the combox (I think using a Fakra HSD Z to B Female Decar 353 cable) and install the update that way?
Thanks
      01-03-2020, 07:36 AM   #8
zoky099
Drives: BMW E91
@RichG25, u have Combox in your E91, can you normally stream music via bluetooth?
Can you post pic of part number combox ?
      01-03-2020, 07:47 AM   #9
RichG25
RichG25's Avatar
Hi, yes I can stream music and telephone calls via Bluetooth. Where will the part number be please? Cheers
      01-03-2020, 07:59 AM   #10
zoky099
Drives: BMW E91
Hm, it's must be on side or under combox
      01-03-2020, 08:59 AM   #11
RichG25
RichG25's Avatar
Hi zoky099, here's a couple of photos of the labels on the combox
Cheers
      01-03-2020, 10:14 AM   #12
smass
398
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
Thanks
Something like this should work https://www.ebay.com/itm/For-BMW-3-Z...parms=ispr%3D1
There is a slight chance something is disabled on the combox and needs coding to be enabled. Just to be clear, UPD01008.bin is not a CIC update. It is a combox update that is only for external devices. Before you buy wiring, see what version you are on now. This is a one time update and there probably will not be any future updates. The below picture is what the current update looks like.
      01-03-2020, 11:39 AM   #13
RichG25
RichG25's Avatar
This is part of the problem, when I go into settings, I don't always get the option to for software? I only get it when I set the BMW Services Update away and when I go into settings the software version comes up as this......
      01-03-2020, 03:01 PM   #14
opjose
opjose's Avatar
242
Drives: 335xi
Neither of the USB ports on your Combox are plugged into anything. Normally one of the connectors hooks up to the center console interface and Aux connector.
As mentioned the update you are trying to install is for the Combox not the CIC.
You may want to post the last seven digits of your VIN number so we can see what hardware is installed in your car.
      01-03-2020, 04:05 PM   #15
RichG25
RichG25's Avatar
So if this updates the combox is there a way/need to update the CIC or is that not possible?
And should this combox update resolve the original problem that I have ie no data is being displayed like dab radio station name, song title etc when connected via Bluetooth?
Vin no is A926611
Thanks
      01-04-2020, 08:54 AM   #16
smass
398
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
DAB radio station name could be related to the CIC. There is a setting to turn it on or off so check that. To get that firmware updated, you need an ICOM fiber interface. Or just pay your dealer to do it. The dealer can read your key and view what firmware your car has for no cost.
Combox update is mostly for bluetooth connectivity. I am not sure if it affects song titles. Do any apps display song titles? Since the cable is cheap, it is low risk. Try plugging in a USB and see if you can run the update. It is odd that it only shows telephone and not multimedia.
      01-04-2020, 10:40 AM   #17
RichG25
RichG25's Avatar
Sorry, I should mention that I listen to Dab radio from my phone via Bluetooth, I don't have Dab in the car and I don't have any settings for displaying names either. As per my op I do very occasionally get a Dab radio station name/album name etc displayed so I know it can do it!
Yes, I agree that the USB cable would probably be the easiest option at the moment. I'm going to order this as it's cheap and will be here next week:
https://rover.ebay.com/rover/0/0/0?m...2F233084202970
Thanks for your help
      01-05-2020, 03:15 PM   #18
opjose
opjose's Avatar
242
Drives: 335xi
Vin no is A926611
Thanks
No the update is NOT a firmware update for the Combox hardware.
It merely updates the Bluetooth recognition tables which could fix your original problem if communication with the Combox is working properly.
To install the .bin file however, you must have a USB connection via the missing black port connection.
As previously mentioned firmware updates are done either via an iLevel update or via Icom. That is completely different.
You should be seeing the multimedia stuff in CIC.
      01-05-2020, 04:32 PM   #19
RichG25
RichG25's Avatar
Thanks opjose, I've ordered a USB connector so will give it a go next week.
      01-10-2020, 10:36 AM   #20
RichG25
RichG25's Avatar
OK so I've plugged a USB connector into both the black and blue ports on the Combox but it's not showing up at all in my multimedia screens nor am I getting an option to do an update through my settings screen when I plug the USB stick with the bin file on in? I've tried plugging my phone into the new USB connector and it does charge my phone so pwer is getting through. Any ideas please?
      01-10-2020, 01:27 PM   #21
smass
398
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
First, make sure you leave the thumb drive plugged on in for 3+ minutes. It can take a while to start the process. Next, make sure your thumb drive is formatted the correct way. I think Fat32 is what you want. Also make sure the update file not compressed and the only file on the root of the drive. And if neither of those work, you may need coding to enable the USB on the combox and/or CIC.
Coding would be something like this:
Step One – Adding $6FL
Open NCSEXPERT and load profile  Expertenmosus (Werkseinstellung).
Press VIN/ZCS/FA (F1)
Press ZCS/FA f. ECU (F3)  Choose the E89 chassis  Choose CAS or NFRM
Press Enter FA (F2)  Choose E89
Add $6FL  OK
Press Back (F6)
Press Process ECU (F4)  Choose CAS
Press Change Job (F2)  Choose FA_WRITE  OK
Press Execute job (F3)
Press Change ECU (F1) –> Choose NFRM
Step Two – Code changes to CIC
Open INPA and verify that it is connected properly.  Close INPA when verified.
Press Back (F6)
Press Process ECU (F4)  Choose CIC
Press Change Job (F2)  Choose SG_CODIEREN
Press Process ECU (F4)  Choose MEDIA
Done
      01-10-2020, 01:34 PM   #22
RichG25
RichG25's Avatar
Thanks smassey321, these are the steps that I have followed so I think my Combox may need coding which I have no idea on how to go about the coding that you mentioned (but thanks again!)
When I plug the USB connector into the Combox should I be able to see it as an external device in my multimedia?
Thanks
