01-01-2020, 01:20 PM | #1 |
Rep 7
N55 Oil leak source help
I have oil spraying around the front driver side engine area. The leak has increased recently and I put a liter and a half of oil in over a week.
I did the first oil change on my CPO car 6 months ago and noticed the person who last changed the oil had 2 gaskets on the cap. Figured they weren’t paying attention and forgot they didn’t take the old one off. So I pulled both off and installed the new o-ring. Are any of you running 2 o-rings on the cap to prevent oil leaks? Doing some research I see the N55 has some possibly oil leak issues 1) oil filter housing 2) valve cover 3) PCV Before spending time and money replacing the wrong part how can I tell where the leak is originating. Photos attached |
01-01-2020, 01:31 PM | #2 |
221
Rep 445
If you're leaking that much it's probably the cap itself isn't on enough or something is up with your o rings. There's a big one and a small one you need. With it being that substantial(spraying) it should be quite obvious with the hood open and the engine running.
01-01-2020, 05:55 PM | #4 |
1615
Rep 3,953
01-01-2020, 06:10 PM | #5 |
3606
Rep 10,367
Clean up the oil as best you can and look for leaks/seepagr as you have someone rev the engine.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
01-02-2020, 07:35 AM | #6 |
481
Rep 1,572
I guess its possible the 2 o-rings, when the cap was tightened, deformed or cracked the cap and now that one is correctly installed the oil is blowing by the o-ring. Looks like too much oil in short period of time the be the OFHG gaskets, but never say never.
01-02-2020, 07:55 AM | #7 |
195
Rep 1,282
oil filter housing gasket. I had the exact same issue.
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
01-02-2020, 07:58 AM | #8 |
1615
Rep 3,953
So the other possibility is that the gasket is leaking but not "spurting". I'm wondering if the oil spray is due to air flow through the engine bay as he is driving on the highway.
01-03-2020, 12:46 PM | #9 |
198
Rep 351
It's probably spraying around because it's dripping onto the belt underneath the housing.
2013 335i M-Sport 6MT, MPE, VRSF CP and IC, BM3 Stage 1
2006 330i 6MT, Sport Package - sold |
01-03-2020, 10:03 PM | #10 |
224
Rep 832
Drives: Bmw 335i f30 N55 ( sold)
My valve cover is leaking right now and bmw is the one that saw it and it was leaking all around the engine bay around the cover on the left side towards back of engine. Nothing around the intake or anything. Idk if this will help you! I'm at 79k and this just happens but I'm getting it replaced under warranty
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
Tags |
head gasket, oil leak, pcv |
