Bimmerpost
4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Family locked in car - 330i
      12-20-2019, 01:35 PM   #1
G20.rjm
Australia
26
Drives: BMW 330i
My 330i has comfort access with automatic locking enabled. Yesterday we stopped on a family road trip and I got out to buy something at a shop. I forgot that the key was in my pocket and the car locked. It was 35 degrees celsius (95F). I heard the car lock and stopped, luckily, waiting for the family to follow me but they were trapped inside. They were unable to open the rear or front doors using the handles. My 13 year old reached forward and pressed the unlock button on my door - nothing. The car was totally deadlocked.
I unlocked the car with the key and everyone was a bit panicked. I got them out, got in and had them take the key and lock the door to test this. No matter what I tried, I could not get out.
This is a ridiculous safety hazard. If I had not stopped to let them out, the temperature in the car car would have risen 20 degrees in 10 minutes and kept rising. This could have killed them.
What if they key fobs battery dies when we are all in the car? The car might no longer detect the key as soon as we turn off the vehicle and lock us in.
Is there any way to disable this insane "feature"?
In the interim, I'll be disabling the autolock feature.
      12-20-2019, 01:58 PM   #2
bimmer456
2966
Drives: 340i
You may have to exit through the trunk using the pass through in an emergency. Make sure everyone knows how to do this.
      12-20-2019, 02:04 PM   #3
VipinLJ
Petrolhead
VipinLJ's Avatar
1943
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
That’s actually a great idea. And extremely scary situation in the case of OP.
      12-20-2019, 02:07 PM   #4
haruny
97
Drives: 2020 BMW M340i
2021 BMW X5 45e  [0.00]
2020 BMW M340i  [0.00]
Can you flip the backseats from the interior?
2020 M340i RWD | C3Z | MAPQ | ZDA | ZDY | ZPK | ZPP | 1CR | 1PU | 688 | 6NW | 2VF | 316 | 4UR
Visit my Instagram
      12-20-2019, 02:08 PM   #5
G20.rjm
Australia
26
Drives: BMW 330i
Trunk was filled to capacity with luggage. Wouldn't have been possible.
      12-20-2019, 02:09 PM   #6
bimmer456
2966
Drives: 340i
Yes, you can lower the center arm rest and reach in to pull the levers on each side. I can do it on the F30 and I think it's the same on the G20.
haruny96.50
      12-20-2019, 02:35 PM   #7
bimmer456
2966
Drives: 340i
You could pull in the luggage into the passenger area was something blocking the pass through? You will have to pack smaller items in the back that can be pulled in and then reach in to pull the levers next time. Make sure this is possible after you pack but before you close the door.
      12-20-2019, 03:00 PM   #8
HighlandPete
6659
Drives: BMW F11 535i Touring
What is in your user manuals....? Something like this from a G20 330e User Manual?
WARNING
On some country variants, unlocking from the inside is only possible with special knowledge. There is a risk of injury or danger to life if persons remain in the vehicle for extended periods and are exposed to extreme temperatures as a result. Do not lock the vehicle from the outside when there is someone inside it.
A6bullet337.00
      12-20-2019, 03:05 PM   #9
530iDriver
530iDriver's Avatar
1708
Drives: 2017 BMW 530i
http://www.lockmasters.com/site/pdfs...%20article.pdf
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness....
      12-20-2019, 03:05 PM   #10
bimmer456
2966
Drives: 340i
Originally Posted by Poochie View Post
That's odd, what you described is a "deadlock," an anti-theft measure, which is decoded in all US-spec vehicles.
If the vehicle's occupancy sensors detects someone is still locked inside, it allows them to open the door.
In fact, I've tried a few times to lock my girlfriend in the car because she was annoying me and she was able to use the double-pull handle to unlock the door, after I locked it with the key fob from outside.
The US is very litigious country, where you not only allowed but encouraged to sue anyone for just about any possible reason, even its a result of their own negligence. There are people who would see getting locked inside a car in the same way most of us would look at a winning lottery ticket.
Frankly, I'm surprise this is even possible on a new BMW model but I would investigate it even further.
I'm not doubting you but there must be a way to open the door if someone becomes inadvertently trapped inside.
I thought they made it single pull on the G20 to unlock from the inside.
      12-20-2019, 03:09 PM   #11
bimmer456
2966
Drives: 340i
I think on the F30 the central locking button still works if locked with the key fob so it doesn't do much to lock someone in the car and I'm not sure what scenario you'd want to do that except to lock a carjacker in the car until the police arrive.
      12-20-2019, 03:10 PM   #12
530iDriver
530iDriver's Avatar
1708
Very old news but relevant to the topic..
https://www.google.com/amp/s/www.nbc...amp/ncna100881
      12-20-2019, 03:21 PM   #13
530iDriver
530iDriver's Avatar
1708
It won't work. Only solution in that situation is to smash the window. Very irresponsible of BMW to enable this deadlock feature into unsuspecting customers
      12-20-2019, 03:27 PM   #14
bimmer456
2966
Drives: 340i
WARNING
Can you lower the rear seat on the 330e or is the battery behind it?
      12-20-2019, 03:33 PM   #15
Poochie
Luxury at the redline :)
Poochie's Avatar
9105
Drives: 2016 M2
I don't believe they did, it's just there is a unlock button on the door now and vehicle also unlocks for itself, upon a stop, so it makes this 'feature' redundant.
I'm still pretty sure there is a failsafe way for a passenger to free themselves from a locked vehicle. I can't see BMW making such a glaring omission exposing them to liability, in this litigious climate.
I just need to confirm it.
      12-20-2019, 03:49 PM   #16
G20.rjm
Australia
26
Drives: BMW 330i
Even if I could pull the luggage through the small rear centre console, there is no manual release mechanism in the trunk of Australian variants.
      12-20-2019, 03:51 PM   #17
G20.rjm
Australia
26
Drives: BMW 330i
Totally agree. I also worry about being locked in myself now if the key recognition system fails or the key battery runs flat. This is a major safety issue that could cause death.
      12-20-2019, 03:57 PM   #18
G20.rjm
Australia
26
Drives: BMW 330i
I don't believe they did, it's just there is a unlock button now and vehicle also unlocks for itself, upon a stop, so it makes this 'feature' redundant.
Poochie when you figure out how to do this I would love to know how you did it. I have tried for a while now and it seems that once you are locked inside without a key, there is no way to escape without breaking the glass - something not easily done from the inside.
      12-20-2019, 04:03 PM   #19
alpinewhite3
alpinewhite3's Avatar
556
Drives: Currently searching
I know this is not a permanent solution or super convenient but you can make sure you that you and your family members all have downloaded the BMW connected app and linked the car to the app. If they ever find themselves locked inside without a key, they can just open the app on their phone and unlock the car remotely. I know this introduces new variables (eg. having your phone on you, having cell service, etc. ) and also you may not want all family members having access to these features at all times but at least it's still a decent back up option.
      12-20-2019, 04:10 PM   #20
ByronWalter
90
Drives: 2023 M340i xDrive
Can you use the BMW key card? I keep mine in the glove box and it might do the trick.
      12-20-2019, 04:11 PM   #21
bimmer456
2966
Drives: 340i
You also need the pin code. Might as well use the SOS button.
      12-20-2019, 05:09 PM   #22
TTG
TTG's Avatar
936
Drives: M340
This is a typical BMW feature that goes back many generations (E46 did that).
You lock the car from outside, no one inside is going out.
It is in your owners manual. Having said all of that, I have no idea what purpose it serves.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
g20
