12-18-2019, 07:41 AM | #1 |
Administrator
40850
Rep 21,240
BMW iX3 Official Range: 440 KM (WLTP)
BIMMERPOST NEWS BMW iX3 Official Range: 440 KM (WLTP) The following global release does not contain U.S. specific market information. For a look at the iX3 prototype spied in testing, see: https://x3.xbimmers.com/forums/showthread.php?t=1530802 Entering a new era of electric mobility: The efficient drivetrain for the purely electric BMW iX3. Munich, Germany- December 18, 2019... The BMW iX3, the production of which will commence in 2020, facilitates locally emission-free driving in a novel and efficient form, whilst also being suitable for everyday use. A range of more than 440 km* within the legislative WLTP test cycle will be achieved with a net-battery size of 74 kWh*. The first purely electric Sports Activity Vehicle (SAV) is the trailblazer for BMW eDrive technology of the fifth generation, which, starting 2021, will also be deployed in the BMW i4 and the BMW iNEXT. For this purpose, both the drive system and the high-voltage battery unit featuring pioneering battery cell technology have been completely redeveloped. In the BMW iX3, the related advancement ensures brand-typical driving experience combined with outstanding efficiency and a novel balance of weight and range. The BMW iX3 is yet a further milestone in the consistent realisation of the BMW Group’s electrification strategy. In 2020 the BMW X3 will become the brand’s first model available both with conventional petrol and diesel engines as well as plug-in hybrid and purely electric drive. With this “power of choice” offer, the globally operating company is taking into account the various different requirements and needs of their worldwide customers worldwide as well as maximum effectiveness in the reduction of CO2 emissions. The BMW iX3 is produced for the world market by the joint venture BMW Brilliance Automotive in Shenyang, China. * = preliminary data The fifth-generation BMW eDrive technology is the key to future-oriented sustainability for vehicles with electrified drive systems. It is the result of consistent development work within the framework of BMW EfficientDynamics and the experience gained by the BMW Group in the field of electric mobility spanning more than 10 years. All powertrain components used for BMW eDrive technology were developed solely by the BMW Group. Moreover, the electric motor and the high-voltage batteries are produced in corporately owned manufacturing facilities. In this way, the BMW Group ensures it has a decisive influence on the product properties and the quality of each component. Furthermore, the drive unit and the high-voltage battery unit are flexibly scalable in terms of power and energy content and can thus be used in various different vehicle concepts and segments. EfficientDynamics at its best: New drive component with high efficiency and brand-typical power characteristics. In the BMW iX3, EfficientDynamics reaches a new level. The vehicle’s fifthgeneration BMW eDrive technology comprises a drive unit in which electric motor, system electronics and transmission are brought together into a central housing. As a result, the required installation space of the drive technology and its weight are considerably reduced. The ratio between motor output and weight of the drive system improves around 30 percent compared to the previous generation. The electric motor featured in the BMW iX3 delivers a maximum power output of 210 kW/286 hp*. The torque of 400 Nm* allows for high initial acceleration and keeps a high level even at the upper motor speeds because of exclusive BMW design measures. A further special feature of the electric motor being deployed in the BMW iX3 for the first time is a construction method that eliminates the need for rare earth materials. The electric motor used in the BMW iX3 transfers power to the rear wheels. This effectuates a further increase in drive system efficiency. Moreover, the range of the BMW iX3 benefits from the drive design conveying the traditional BMW rearwheel drive experience. High-voltage batteries with significant higher energy density and responsible use of raw materials. The high-voltage battery unit of the BMW iX3 is integral part of BMW’s fifth eDrive generation and is based on the latest evolution in NMC-811 technology in BMW typical prismatic design. The BMW Group has outstanding development capabilities in this field. This know-how flows into precise specifications with regard to the use of materials and battery design, according to which the battery cells are produced. Consistent research and development work not only raises energy density but also constantly improves all battery cell characteristics, in particular also durability and safety. In total, the BMW high-voltage battery shows the optimum of what is possible nowadays. At the same time the BMW engineers were able to reduce the share of cobalt contained in the battery by another two thirds. Compared to former technology used by BMW Group, the gravimetric energy density on cell level in the BMW iX3 is around 20 percent higher. With the BMW iX3 the raw materials Cobalt and Lithium for the first time are purchased by BMW directly and then handed over to the producer of the battery cells. In addition, scalability and the compact design of the high-voltage battery unit have been further optimised. The battery cells are grouped into modules at specialised BMW production locations and finally assembled as high-voltage battery packs aligned to each model. The high-voltage battery unit in the BMW iX3 is installed in an extremely flat position in the vehicle floor. Thanks to this arrangement, there is no loss of space for passengers and the luggage compartment compared to the conventionally powered versions of the BMW X3. Greater range thanks to high efficiency rather than a bigger battery With a net energy content of 74 kWh*, the high-voltage battery unit installed in the BMW iX3 achieves a range of more than 440 km* in the legislative WLTP test cycle. Within its segment, the BMW iX3 boasts not only a unique low power consumption of less than 20 kWh/100km* accordingly to the WLTP test cycle, but also stands for a novel ratio between battery size and range. Thanks to the favourable efficiency rating of the drive components and the high energy density of the high-voltage battery unit, the BMW iX3 achieves a range that is only possible for common electric vehicles with larger and thus heavier batteries. Positive environmental impact secured. The “real” ecological footprint of electric vehicles is sometimes questioned, particularly in markets still having a low percentage of green electricity in the public power grid. At the BMW Group every electrified model has to proof that for the entire cycle, comprising raw material procurement, supply chain, production and usage phase as well as recycling, its CO2 balance is substantially better than the one of a conventionally powered sibling. For the BMW iX3 the related advantage is more than 30 percent compared to a BMW X3 sDrive 20d when average European power supply is used during the car’s usage phase. If the vehicle is charged with green electricity the advantage is around 60 percent. Furthermore, in analogy with the BMW i3 Plug&Play technology, the high-voltage battery featured in the BMW iX3 is planned for a second life as a stationary battery pack for the period following the first long life in the car. This way the already positive CO2 balance of the BMW iX3 can be further improved. * = preliminary data
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
12-18-2019, 07:50 AM | #2 |
432
Rep 2,527
Would like to see an AWD variant. When would that come?
ron_jeremy513.00 |
12-18-2019, 07:54 AM | #3 |
3107
Rep 3,072
Drives: 2023 iX M60 Oxide
This sounds like a rather uninspiring vehicle. For an X3 I would want all AWD and some pep to get excited about an EV.
It doesn't compare favorably to something like a Volvo XC40 recharge that has a motor on each axle and can get to 60 in under five seconds. However, EVs do better in other markets. In the US people are largely not buying outside of California... at least for non-Teslas. I won't harp too much on the range, because it has been found that some cars are only tested at 80% battery and others at 100% when it comes to EPA range, but it sounds like it is roughly the same as the version 2 E-tron as far as WLTP which may mean ~225 miles EPA. https://www.greencarreports.com/news...-electric-cars |
12-18-2019, 08:17 AM | #4 |
16523
Rep 8,421
RWD X3= doa ‼️
12-18-2019, 08:31 AM | #5 |
Moderator
7515
Rep 19,368
There is nothing on the road map which likely (though not 100% positively) means it will not arrive for this generation of the vehicle. I say this because the G01/G08 LCI is 7/21 and BMW does not usually add new drivetrain configurations after the LCI. Now they did recently add the X1 PHEV (outside North America) after its LCI so it does happen from time to time. Still, I would not hold my breath.
That being said, the i4 and iX (iNEXT) are coming in 2021 with dual-motor AWD models available from the start. So, there is always the chance that the iX3 is a benefactor and gets upgraded at or near the time of their release. |
12-18-2019, 08:53 AM | #6 | |
111
Rep 1,772
Another question I have: how is BMW this far behind Tesla after having an EV out there for so long (the i3) and taking this much time to come out with the vehicle?! |
12-18-2019, 09:05 AM | #7 |
337
Rep 440
This looks to be an extremely useful all electric solution. I am not an SAV/SUV person, I am really waiting for the i4.
I am very happy that BMW is again pursuing and innovating on the EV segment. It is sorely needed.
E36 318ti
E46 320i E82 135i F87 M2 G20 330i |
12-18-2019, 09:06 AM | #8 |
243
Rep 445
Glad to hear progress here. Sadly we needed this from BMW 5 years ago.
ron_jeremy513.00 stein_325i25083.00 |
12-18-2019, 09:07 AM | #9 |
4338
Rep 6,196
12-18-2019, 09:20 AM | #11 | ||
Moderator
7515
Rep 19,368
12-18-2019, 09:23 AM | #12 | |
4654
Rep 6,031
I also recall when Jeep started adding rear wheel drive models due to demand in the southern half of the country. Sure, some sales will be lost now without AWD but as BMW assessed demand with only RWD versus their initial production capacity, I feel quite confident they developed a solid business case. These will be all over southern California, Las Vegas, Phoenix/Scottsdale, Dallas/Houston, Miami, etc. For the initial launch year or so, versus the production ramp, that may be more than enough. In future years, it won't be hard to add XDrive to the platform as demand and capacity expands.
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
12-18-2019, 09:25 AM | #13 |
513
Rep 985
This is just pathetic.
I have read the official letter from BMW ensuring that the IX3 is a AWD, now this garbage! It is just a joke, BMW are leaking alot of customers to Porsche and Tesla these days, IX3 is for many the last hope! Now i need to have a plan B...
3 series: E30: 89 325i, E36: 92 325iC, 94 320iC, 96 320i Convertible, 94 320iaC, E46: 99 320ia, E90: 06 318i Le mans, E91: 07 318dt
5 series: E39: 97 520ia, 01 530Dat, E61: 09 520Dat X series: E83 05 X3 2.0d, E84 10' X1 2.0 X-drive DA, F25 13' 2.0da X-drive. |
blue dragon1190.00 ///M TOWN16523.00 |
12-18-2019, 09:31 AM | #14 | |
3821
Rep 4,660
Drives: BMW
mkoesel7514.50 |
12-18-2019, 09:45 AM | #15 |
1190
Rep 1,544
Drives: '22 Tesla MY + '23 Tesla MY
No thanks BMW
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
12-18-2019, 09:47 AM | #16 | |
4654
Rep 6,031
Again, for those in situations different from yours, buying an SUV has long included thinking about rwd vs awd. Those south of the Mason Dixon line have been making that conscious decision for decades and manufacturers have responded with those offerings.
12-18-2019, 09:56 AM | #17 | |
4338
Rep 6,196
12-18-2019, 09:58 AM | #18 |
4654
Rep 6,031
BMW Canada's Sales team knows their local market and signs up for production accordingly!
MightyMouseTech4337.50 |
12-18-2019, 11:02 AM | #19 |
3821
Rep 4,660
Drives: BMW
12-18-2019, 11:25 AM | #20 | |
1113
Rep 1,904
I have a Taycan Turbo S on order (with an actual allocation) and folks are pretty miffed about the 201 mile EPA range on the Taycan Turbo (at least those NOT in denial)... Its the anticipated quality/performance of the Taycan that is drawing me away from the utility/range of the ModelX. But only barely... Particularly now with the dismal range numbers on the Porsche. Then as you typically charge an EV to only 90% on a nightly basis (to extend battery life), that would bring it down to about 180 miles of "daily" EPA range. (I get 219 "daily" on my ModelX P90D). My current EV is a ModelX and I also have an i8 Roadster. (I did once own a Chevy Volt and that was also a great car!) My experience is that the EPA Range estimates have always been pretty accurate for all three of my EV/PHEV's. Yes, BMW is VERY late to the game. Not sure why this is the case as I don't believe its a shortage of technology or talent. I just don't think they recognize the market appropriately. Just when you think they finally got the range a true EV needs they make a bonehead move and leave out the AWD in a crossover/suv type vehicle. I was originally looking forward to this car. Not anymore. BMW just fall back off my EV roadmap... BTW - for those of us still living with the Imperial system: - 440 KM = 273 MI (WLTP) - To approximate EPA (US) range from WLTP (Europe): 273 / 1.12 = 244 MI (EPA). https://insideevs.com/features/34323...epa-wltp-nedc/
The Jiggery-Pokery is Strong with this One
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 Last edited by evanevery; 12-18-2019 at 11:42 AM.. |
bobloblaw745.00 |
12-18-2019, 12:36 PM | #21 | |
16523
Rep 8,421
A Rear Wheel Drive BMW X3. X means nothing ‼️
12-18-2019, 02:23 PM | #22 |
BMW Client Advisor
1000
Rep 3,526
So you're telling me it's a rear wheel drive SUV with a range of less than 300 miles and less than 300 hp?
