Aftermarket swaybars on 335i? Worth it?
12-16-2019, 12:26 PM | #1 |
2001
Rep 3,731
On my 03' Mini Cooper S.....a larger aftermarket rear swaybar made a HUGE difference in handling. When pushing the car on curvy roads, it went from crazy understeer.....to a much more neutral type handling. It was a night and day different...bit it's FWD.
On my 07' 335i....I'm running 255 tires in the front, and 275's in the rear. Would I see any benefit on new sway bars for the front and/or rear? The car seems to handle very well already, but I know things can always be improved. Thoughts?
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
12-16-2019, 01:08 PM | #2 |
114
Rep 598
NO. They cost too much money or unknown tuning in car front and rear balance.
Just spend money on suspension kits. Anti sway bars are meant to tune the front and rear cornering balance for under and over steer. Better to spend that money on actual tuned springs and Dampers |
12-16-2019, 01:17 PM | #3 | |
2001
Rep 3,731
12-16-2019, 01:22 PM | #4 |
114
Rep 598
That's where you got it wrong. They are a TINY bit above the factory kit and charge arm and leg.
Their spring rate increase is negligible. 20-30% ? You want 250-400% spring rate increase, with dampers tuned to handle it, so you control without harsh ride. Harsh ride comes from dampers that are over controlling the springs. They do that in most kits to make you FEEL you have "sporty" suspension. Try www.meisterR.com ask for the E90 kit. You'll see real quality suspension without breaking bank. Trust me. They win touring events in UK. Website for US doesn't list E90 but 1 series. They have E90 if you call or email |
12-16-2019, 04:42 PM | #6 | |
114
Rep 598
Only for RWD. https://www.meisterr.co.uk/products/...ies-e90-06-on/ I've been on their CRD kit on my Miata NC for 34k miles, DD. Not a single issue, leak, noise, or ride harshness. Lighter than OE with billet aluminum for non-strut types. I'm keeping OE springs with Bilstein HD/B6 for my wagon for ride height. Wagon springs are plenty strong anyway. If you want to keep Bilstein, PSS-10 is the kit with actually strong springs, for $$$$ Last edited by Soravia; 12-16-2019 at 05:01 PM.. |
12-20-2019, 08:18 AM | #7 | ||
476
Rep 1,191
Drives: 2009 BMW 328i Wagon
12-20-2019, 01:38 PM | #8 | ||
1903
Rep 6,968
12-31-2019, 05:54 AM | #9 | |
11
Rep 109
12-31-2019, 08:25 AM | #10 | |
1207
Rep 2,026
12-31-2019, 09:57 AM | #11 |
3058
Rep 3,910
Roll stiffness is suspension geometry, CoG location, spring stiffness, sway bar stiffness, and damping...all at the same time. It makes sense that sway bars are the last thing to change in a setup, since they only really do one thing. But also, sort of by definition, they're really just a fine-tuning tool.
So, if you want more roll stiffness, the chances are you need to change your springs. If the end you need more roll stiffness/less cornering grip from is already stiff enough in bump, consider softening the other end instead. If that's not an option, you could fork out $ for fancy dampers, but you'd probably be best off changing the sways at that point. E9xs generally have a big bar on the front, and pathetic one on the back. This is mirrored by the spring setup (soft at the front, firm at the back), so the roll stiffness at each end is vaguely similar (maybe). Adding bar at the front does make them feel much more direct and sporty, giving the impression of better handling when you're not using all of the available grip...but when pushed, the front will push more, guaranteed. Adding bar at the rear is a band-aid for the generally lower levels of grip at the front; you're removing grip from the good end to help/match the bad end, rather than fixing the bad end. But if you need/want to do it, go for it, but there are other things that you probably should do first, which are more important. Having said all that spew about how things 'should' be done, the first thing I did after new bushings was an E93 M3 rear sway on my E91, and I'm pretty happy with this wrong decision Do what makes you happy. |
01-01-2020, 06:51 AM | #12 | |
11
Rep 109
Wouldn’t camber loss also be effected by the amount of suspension droop on the unloaded side- I would think that’s where you would get most of your benefits in reduced camber loss from ? Stiffer sway bar reducing body roll and thus protecting camber angle on the louded side even if it is already at full compression ? |
01-01-2020, 07:00 AM | #13 |
11
Rep 109
“ .but when pushed, the front will push more, guaranteed”
Is this from actual track experience or from text book theory? Not trying to be rude , just asking . Because I don’t pretend to be a track rat. I have only a little experience in the track but a decent amount of experience at auto cross . But I do like to talk to experienced track guys about set up . And surprisingly it is common practice for e46 m3 guys among others to run the stiffest possible bar up front and stock in the rear even if it means leaving the matched “upgraded” bar on the shelf in the garage . |
01-01-2020, 02:45 PM | #14 |
3058
Rep 3,910
Indirect track experience, yes. I mechanic for a team who run a 325i at the nurburgring in the VLN series. Setup on the car is just a constant balancing act, trying to get as much front grip as possible, without demolishing front tyres (4h races).
I have no experience of it, but doesn't the e46 have a comparatively flexible chassis? I think that's why e46 guys run firm front bars; they can't transfer roll stiffness from the rear in the same way an e9x can, and they may as well keep grip in the back end for low gear corner exit (and open diff). Also if the e46 rear bars are like the e9x rear bars, the M3 variety is a huge step up in stiffness from the non-m bar! |
01-03-2020, 11:38 AM | #15 | |
1207
Rep 2,026
