Bimmerpost
4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK 320d problem refueling!
      12-16-2019, 07:24 AM   #1
marksandygill
marksandygill's Avatar
240
Drives: G20 320d xDrive F22 M240i
Hi everyone, had my G20 320d for 4 months now and I absolutely love it, better in every way than the previous 3 series!
Every way except when I refuel it, pull the handle all the way up on the pump and the fuel clicks off?!
Happens at Tesco (took me 5 minutes to put 2lt in), I can manage it at Sainsburys but only because there is a notch before pulling the handle all the way that I can hold it at!
Any thoughts? It's a company car that goes back in 2 months but just figure not looking into it is a bit jack?
      12-16-2019, 07:44 AM   #2
JohnBarny
12
Drives: BMW F36 420d + G21 330i
Sounds like it’s faulty
      12-16-2019, 10:01 AM   #3
Bumble
Bumble's Avatar
27
Drives: BMW 3 series. Aiudi Q3
I suggest you stick to Sainsburys for two months
      12-16-2019, 03:11 PM   #4
Cranester1983
77
Drives: BMW 330e M Sport
Happens in my C220d as well sometimes. Usually at Tesco as well! Just pull the pump out by about half an inch and it’ll work no problem... does for me anyway.
Thought I was the only one 🤣
      12-19-2019, 11:32 AM   #5
DayTimer
Drives: G20 320d M-Sport
I find this at Tesco too, also have a 320d, I find if I pull the hose out 1 inch so it locks on the next rivet of the metal of the nozzle it fills up fine. The nozzle is at a different angle in the tank exit in that position and only cuts out when full.
Gets me every time but only takes a second to get the flow going again.
      12-19-2019, 12:09 PM   #6
DomiGijzen
DomiGijzen's Avatar
Netherlands
70
Drives: BMW iX3 MSport High Exec (G08)
I have this problem too but only when the pistol has visible signs of abuse/wear or at one place modifications.
Grz D.!
      12-19-2019, 06:03 PM   #7
BMW_Belgier
BMW_Belgier's Avatar
Switzerland
101
Drives: E92 335xi n55
Same here... always the same pump when it happens...
BEFORE: 130i N52 (2006-2011)
NOW: 335xi N55 (2011- )
g20
