12-11-2019, 10:07 PM | #1 |
'20 M2 Comp.
902
Rep 182
Drives: '20 M2 Competition DCT
N26 VRSF Downpipe Exhaust Leak
I installed a VRSF catless downpipe myself with my friends.
My car is a 328i with the N26. When my engine is running, I can smell the exhaust gas from the engine bay, not the rear of the car. I can still feel fair amount of exhaust coming out from the back, but I'm worried if I have an exhaust leak. People with catless downpipes, do you also smell the exhaust gas from the engine bay?
'20 BSM M2 Competition DCT
IG: @porky_m2c |
12-12-2019, 06:18 PM | #2 | |
32
Rep 117
Drives: F30 328i 6MT/ E36 M3 5MT
Alpine White 12' F30 328i 6MT (SOLD) Injen CAI | Bootmod3 Stage 1 | VRSF 5' Intercooler| Mishimoto Catch Can | 335i M Performance Exhaust | H&R Super Sports | HRE FF01 w/Hankook Ventus Evo2 | M-Sport Retrofit |
Jayden_F87901.50 |
12-12-2019, 06:43 PM | #3 |
724
Rep 943
Drives: F30 328i Msport
Did you change all the gaskets\clamps or reused the old ones?
12-12-2019, 08:52 PM | #4 |
'20 M2 Comp.
902
Rep 182
I reused the clamps on the top(manifold to dp).
IG: @porky_m2c |
12-15-2019, 04:31 PM | #5 | |
20
Rep 109
Now that my exhaust leak is fixed I have made the following observations: When you do a cold start with an exhaust leak, the car has exhaust note from the front of the car, instead of mechanical engine noise After it was fixed, it no longer smells in the car or the garage I couldn't use the A/C because the smell would come in the car, now it isn't an issue. Your car just sounds super LOUD |
Jayden_F87901.50 |
12-15-2019, 05:23 PM | #6 | ||
'20 M2 Comp.
902
Rep 182
For my car though, I can't smell the fumes in the cabin. A/C smells fine as well.
IG: @porky_m2c |
12-15-2019, 05:29 PM | #7 | |||
20
Rep 109
Basically a car that has no exhaust leak only produces exhaust note from the rear of the vehicle, and at cold starts it is most noticeable |
Jayden_F87901.50 |
12-16-2019, 11:39 AM | #8 |
BimmerPost Supporting Vendor
24198
Rep 190,805
Since you do not smell anything inside the cabin, it think you are fine.
That being said, it would not hurt to double check install
Jayden_F87901.50 |
12-16-2019, 01:19 PM | #9 | ||||
'20 M2 Comp.
902
Rep 182
IG: @porky_m2c |
12-17-2019, 08:02 AM | #10 |
15
Rep 65
I used same V band and the little cardboard asbestos gasket on the turbo when I installed mine. I also made sure it was very square on the turbo without nothing else on it and tighten it up but not quite all the way. Then I put the copper high temp silicone on the down pipe to the mid pipe connection using its original band. All worked good no leaks. With proper downstream O2 sensor spacing there has been no codes in 3000 miles. Now with BM3, which I have only had for about 200 miles, I think it might be clearing codes but I checked again before I flashed to BM3 and did not have any.
2016 328i 6MT, M Sport Brakes, Suspension, Steering and Track Handling Package
MODS: BM3 Stage 2/93 Octane OTS, Active Autowerke BMW F Chassis Intercooler, VSRF Catless Down Pipe, GFB DV+, Injen Evolution Intake, Red Line MTL for Transmission, NGK SILZKBR8D8S gapped at .24", Dinan Shockware, Cooper ZEON RS3-G1's and Hawk HPS 5.0 Brake Pads all the way around. |
12-17-2019, 11:20 AM | #11 | |
'20 M2 Comp.
902
Rep 182
Maybe I should do something like that just to make sure. I've been driving around 500 miles since install and still no CEL (yet).
IG: @porky_m2c |
12-17-2019, 08:33 PM | #12 |
81
Rep 2,046
isn't it recommended to buy all new V clamps when doing this ? it's like $20 per clamp
12-19-2019, 05:36 PM | #13 |
'20 M2 Comp.
902
Rep 182
I forgot to get them before install :/
IG: @porky_m2c |
12-19-2019, 08:43 PM | #14 |
277
Rep 558
I didn't get new clamps at first and the turbo-downpipe clamp loosened up extremely badly after a few thousand miles. I bought a new clamp and then lock-wired the clamp bolt just in case lol.
2017 F80 ZCP - Mineral Grey Metallic
Jayden_F87901.50 |
12-20-2019, 08:23 AM | #15 |
15
Rep 65
My car was fairly new and only about 18K miles on it so for the life of me I don't know what you would get out of new clamps. Mine were as about as new as you could get. Maybe a little loc tight on it might be a good deal on the V Band clamp...
Jayden_F87901.50 |
Tags |
downpipe, exhaust, n20, n26 |
