12-08-2019, 12:16 PM | #1 |
628
Rep 2,808
How are you putting higher offset winter wheels on the front of the M40i?
I’m guessing there’s only 5 mm or 1/5" of space between the brake caliper and my wheel right now! My pinky is 1 cm or 2/5".
I’ve seen a lot of people say they have put 8" wide / 35 offset wheels, and the outer edge would RETRACT by 11 millimeters based on the calculators. Tire Rack even suggests 8" / 32 offset wheels, which still retract 8 mm... Even 8.5" wide wheels with 35 offset would RETRACT 5 mm, which would be too close for my comfort... . |
12-08-2019, 12:41 PM | #2 |
168
Rep 223
Drives: X3 M40i (MY19)
You do know that offset is the distance from the center of the rim to the base that attaches to the car. See pic. Bmw have positive offset.
Jens Ejvinsson, Sweden
BMW X3 M40i (MY19), every option in the book, Pictures BMW X1 20d M-Sport xDrive (MY17), Nav, HUD Last edited by asyvan; 12-11-2019 at 01:07 PM.. |
12-08-2019, 12:44 PM | #3 |
168
Rep 223
It really doesn't matter. What clears the calipers is the design of the rim.
BMW X3 M40i (MY19), every option in the book, Pictures BMW X1 20d M-Sport xDrive (MY17), Nav, HUD |
12-09-2019, 10:01 AM | #4 | |
628
Rep 2,808
And I know what offset is. USUALLY the lower you go, the less brake caliper clearance you have as a rule of thumb. So I'm not going to take a chance, unless I have a decent idea it should fit. With TireRack, I know they guarantee fit, and I'm sure I can trust them, but I was hoping someone actually knows the answer to my question... |
12-09-2019, 11:04 AM | #5 |
168
Rep 223
Well I am not sure your question CAN be answered. Look at it this way, if you have a rim of a certain design that comes at different offsets to choose from. And if that design clears your brake calipers.... then that same design will clear the calipers no matter what offset you choose.
dkreidel244.00 |
12-09-2019, 11:19 AM | #6 |
244
Rep 596
A bigger concern on the M40i is tire/suspension clearance in the front. Some owners who added wider tires of the same diameter found they are either hit the upright, or are now dangerously close.
Another area of concern, especially on winter set-ups, is not simple static caliper clearance. Sufficient clearance between the caliper and wheel is required, as the heated caliper causes snow and ice to melt, and then re-freeze - essentially freezing the caliper to the wheel barrel
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option |
12-09-2019, 11:31 AM | #7 | |
168
Rep 223
On freezing calipers. Never heard of. I live in Northern Sweden though, so... 😎
12-09-2019, 12:09 PM | #8 |
Rep 14
Offset has less to do with caliper clearance than with the hub disk. A lot of manufacturers will ask you what car the wheels are going on, and this will allow them to provide you the proper sized disk. Depending on the wheel design (spokes, 1-3 piece wheels), you might be able to get away with low disk and lower offset on a bigger caliper like on the m40i. This is a risky way to do it.
These are the disk choices from WORK Wheels. You can see the part that meets the hub is larger for bigger calipers. |
12-10-2019, 01:56 PM | #9 | |
244
Rep 596
Rocks and small pebbles can cause problems even when it's warm. I think it's possible to have adequate clearance for when things are good, but have problems when the roads haven't been plowed and have 20-30 cm of snow and ice. I've spend some winter time in SE for work, and will put our Montana winters up to the worst SE can offer.
12-10-2019, 02:09 PM | #10 | |
168
Rep 223
Where I live we have snow from end November til end March and it reaches roughly 1 meter (roughly 3 feet 4 inches) deep in terrain. Temperature is usually around 5-10 below freezing, but can get much colder in periods.
12-11-2019, 07:48 AM | #11 | |
244
Rep 596
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option Last edited by dkreidel; 12-11-2019 at 08:06 AM.. |
12-11-2019, 12:21 PM | #12 | |
628
Rep 2,808
I went thru all this last year when shopping for winter wheels for my M2C, which has like 5 mm clearance between the calipers in the front and the wheel barrel. I'm down to 4 mm with the winter wheels set up. That's exactly why Apex doesn't list all their 19" wheels with the same offset as fitting my car... My OEM wheel is 9 x 19, ET 29, and not every 9" wide 19" wheel with 30 offset will even clear my calipers. What I've been trying to say is that everything else being equal (in other words if you had the same shape spokes between wheels), the lower the offset, the more brake caliper clearance you will have. . Last edited by Lotus99; 12-12-2019 at 11:42 AM.. |
dkreidel244.00 |
12-11-2019, 01:06 PM | #13 | |
168
Rep 223
Imagine these three rims/wheels being same width, same design and three different offsets.
Alias1431795.00 |
12-11-2019, 04:25 PM | #14 | |
57
Rep 104
Look at the picture above of negative offset. The spokes are FURTHER away from the hub, not closer, as in positive offset. |
scrammer421.50 |
12-11-2019, 05:18 PM | #15 | |
244
Rep 596
The only way to be certain is mount a wheel to the car and inspect for caliper and suspension clearance. On X3 AWD cars, there's another clearance concern point with the front suspension and inside edge of the tire if the tires have a larger section width and/or offset is too big.
asyvan167.50 |
12-12-2019, 03:20 AM | #16 | |
168
Rep 223
Alias1431795.00 |
12-12-2019, 11:50 AM | #17 | |
628
Rep 2,808
My stock X3 front wheel is 8.5 x 21, ET30. Getting a lower offset wheel, like 8.5 x 21, ET 25, will push the wheel OUT 5 mm. 25 is lower than 30. Which is exactly what Asyvan's picture shows. Smaller offset pushes the wheel farther out: |
asyvan167.50 |
07-01-2020, 09:45 PM | #18 |
Rep 1
